Hyundai Headlights
I have a 2004 Santa Fe. I am having a problem with the headlights not coming on when I start the car. I have to wait 5 to 10 minutes sometimes before they suddenly come on. The headlight switch is completely on. I can turn them on and of but they still will not come on. I have had the car into the dealer and they have told me they have to have it do the same thing to them. However every time I take it to them the headlights always come for them. I am really frustrated can anyone help me out. Thanks
thanx in advance
:-) and see if you have enough room to turn with your thumb and pointer or middle finger... the cover is not like the headlight covers - think of how you would turn your key in the ignition but left to loosen.
If you have small hands, you could probably reach in and rotate the base of the turn signal bulb socket 1/4 turn counter clockwise to remove it.
Here are some pictures that should help - Santa Fe Headlight Bulbs Replacement
The owner's manual says to "just" remove the 10mm bolts on top and pull out the assembly. That didn't work. I was able to replace the headlight bulbs from the rear but the turn signal bulb is tricky without pulling the assembly out.
