Chevy 2007 Tahoe emergency flasher kill battery
I've discovered that when I turn on my Tahoe's emergency flasher my battery dies after they're left on for about 20 minutes. After my Chevy dealer couldn't figure it out, I filed a case with GM and the case worker came back a week later and stated that this is a "normal" situation with this vehcle. This stunned me, and my local dealer.
I consider this dangerous especially since I travel in the upper midwest. I hope i don't have any flat tires, etc, at night while i'm traveling!
is anyone else experienced this?
let me know.
let me know.
SUVs and Smart Shopper
Drawing 15 amp, for 1 hour, is only 15 amp hours. There's no way that should draw down your battery.
Something else would have to be causing the problem, perhaps daytime running lights or radiator fan if you are leaving the key in the ignition. Or perhaps the body control module is sensing you are still in the car, and keeping everything powered up. Is the key out of the ignition, when you have this drain-down?
Other things that have happened since I bought it a year ago, pre-owned with one owner, but seemingly in perfect condition: Transmission went out in winter, got new transmission. Radio and blinker stopped working suddenly a couple of months ago, they replaced radio. Windsheild wipers went on automatically and squirted out all wiper fluid without stopping several times. I think the electronic stuff is all related but they don't know how to fix it. By the way, it only has 38,000 miles. I have been in the shop atleast once every couple of months for the last six months. I love the comfort of the ride and the look of the car inside and out, but it has been so unreliable. I don't know if I should trade it in for something else or if maybe this is the end of the problems? Any suggestions? This is the first pre-owned car I have owned. I saved $17,000 buying it this way but I am hesitant to buy used again because of these problems.
- accessories turning off, I believe that is normal to keep the battery from being drained down. That's controlled by the BCM (body control module) which is the computer that controls all of the lights and internal body electricals. I believe all of my vehicles do this (I know for certain a Ford and a Toyota I have both do). I've never sat in the Sub that long after stopping. I'd check the owners manual, I'm pretty sure this is working as it's supposed to.
- I don't know what you mean by "automatic rear door release". If you are talking about the rear tailgate, and it not raising when you push the overhead button, you must be in park for that to work. Read the manual. Keeps you from ejecting the kids or your luggage while driving down the interstate.
- Windshield wipers going on automatically. I believe this is trim level specific with the higher trim levels having automatic wipers (I know my LTX has this), is that there is a sensor on the windshield above the mirror. If the windshield stalk switch is turned on to one of the slower positions, the windshield wipers will come on when the windshield sensor detects water on the windshield, or something passes over the sensor (like your hand, or a squeegie). Check the position of the switch. I don't know that the washers come on though, I don't remember that happening.
- What trim level is your vehicle? LT, LS, LTX, etc
I have a 2007 LTX and yes the windshield wipers are supposed to come on automatically when they detect moisture but not so long without stopping that they drain all the windshield wiper fluid. As far as I could tell, along with the passengers in my car, there was no moisture on the windshield. Since they fixed it this has not happened again, but I'm not holding my breath.
I was talking about the rear tailgate that opens with the press of a button. It is always in park when I use it, and it was working fine until recently. Now when I press the button nothing happens. At first when this stopped working I did hear an electronic hum but the hatch would not automatically open as usual. Now the noise is gone and it is just like any other rear hatch that you have to manually open.
I really don't think there should be this many problems with a car. I don't have time to take it in every month and even though it's under warranty not everything is covered, such as the battery.
I don't believe the flashers are turned off after a period of time, just the non-essential items and lights. Again, I'm pretty sure this is all described in the owners manual.
I know in two of my other vehicles I've sat and waited in the vehicle and both of those have turned off the power after some time limit. I've never been sitting in the Suburban that long to notice it turning off. I think you'll find this pretty standard in many of the newer vehicles (it's been in every vehicle I've bought since 2004 model year). I don't exactly remember anymore, but I believe my '97 Sub shut the power off immediately when you turned the key off.
