2008 Subaru Forester Revving With Clutch In
The idle of my 2008 Forester oscillates (between 1000 and 2000 RPM) indefinitely when I push in the clutch with the transmission still in gear. As soon as I take the car out of gear, the idle drops back to normal. I took the car to the dealership who was able to reproduce the problem but, because they didn't have a fix for it, their answer was that the car is behaving as designed. The service advisor more simply described it as a design flaw. I wonder if anyone else has the same problem and if they've had better luck getting it resolved.
Call 800-SUBARU3 and open up a case. They can help your dealer get to the bottom of this.
The ECU sets the idle speed, so I bet one of the inputs is malfunctioning - a sensor or something.
As Ateixeria mentioned, could be bad sensor or faulty ECU.
If dealer gives no satisfaction and no other dealers are available, try opening case with Subaru.
There's definitely something not working right though, the idle on a warm engine should hold steady at 750 rpm, regardless of whether it's in gear or not.
-Frank
The dealership mechanic who worked on the problem, having exausted everything he could think of, did open a case with Subaru. But they weren't able to help him.
The problem can be duplicated at will and occurs any time I push in the clutch while I'm in motion in any gear, incline, or speed, with or without air conditioning.
Strange eh?
-mike
Have your keyless remote ready and lock and unlock a few cycles to reset the alarm.
-mike
*By unstable, I mean that, when coasting in gear, the idle would settle to around 1000 RPM until I took the car out of gear, at which time it would return to normal (about 850 RPM). Same problem but less pronounced.
#11-89-08 Reprogramming Files For High Idle When Clutch is Disengaged
http://www.thel7.com/TSB/11-89-08.pdf
Also on a different board, someone reported a similar issue that turned out to be the accelerator pedal position sensor (in an 05 model).
I drive a 2008 black subaru forester manual base model.
My car did the exact same thing all time and i asked the dealer what was going on.
They were unsure at first and told me that they would contact subaru and get to the bottom of it.
I recieved a phone call three days later saying that there was a Re-flash available
I drove in the next day had the re-flash done and all was well.
I read the report about disconnecting the battery on here and then the problem came back
i found out that:
WHEN YOU DISCONNECT THE BATTERY IT RESETS THE COMPUTER AND ERASES THE RE-FLASH.
PLEASE IF YOU HAVE HAD THIS RE-FLASH DONE DO NOT DISCONNECT THE BATTERY. OR THEY WILL HAVE TO RE-FLASH IT AGAIN.
Good work and thanks for the advice
-mike
Subaru Guru and Track Instructor
I phone the technical department for subaru and they even confirmed that this is the case.
-mike
Curiously just today I received email regarding Service Program WVN-24, regarding a ECM reflash and one-way valve removal to prevent possible catalytic converter damage. I wonder if the reflash I received four days ago covers this? Annoying.
I hate the dealership where I bought it and had it serviced for the first 40k mi. I'll take it to the other dealership in town next service and see what they say.
P.S. It doesn't do it when the engine is warm but not yet up to full temp. Maybe a colder thermostat would help?
Wish Subaru would publish something so I would know for sure.
http://townhall-talk.edmunds.com/direct/view/.f124065/21#MSG21
