99 Malibu fuel gauge and A/C trouble
Hi I am new here, I just picked up a 99 Malibu in Immaculate condition for $1,200 with 78k miles. I knew the the last owners it was a old mans car. The car runs and looks great, i do have just 2 problems with it that i was aware of when i bought the car.
The first problem is the fuel gauge, with a full or 1/4 tank or anywhere in between the gauge drops to empty then up then empty. as a guess i would say fuel sender switch in the tank. is this a common problem with this type of car and has anyone had this problem and fixed it? i hate to spend $300.00 on a sender switch if other people had this problem and it was something else.
The Second problem is the A/C is on and blowing cold then just shuts off any idea's ? any help would be great
thanks in advance, Wally.
hope that helps...
oh, and the deal with the AC- mine does that as well- its done it from the time i got it which was about 6 years ago- while it was still under warranty i had it in and out of the shop about a dozen times and the mechanic told me there was nothing wrong with it... i have since replaced all the fuses, changed the plugs and wires, and even had some other routine maintence work done to it and it still has the same problem. whenever it does it to me, i turn the dial to off leaving the AC button alone and then turn it right back to 5 and it usually doesn't give me any more problems for that trip.
one problem i have with mine is that positions 1 and 2 have never worked- how about yours?!
I've had it in to the dealer and they replaced my battery. Next day same problem. I had to have it towed in and of course they were closed at the time. When I just called to see if they fixed the problem, they say there;s nothing wrong with it.
Any help would be greatly appreciated.
I apologize that your vehicle is experiencing concerns. How long has the concern been present? Does anything come up on the DIC when this happens? Is the concern intermittent? Thank you,
Mariah GM Customer Service
Passlock security problems are common on GM cars. Read my solution on my website:
http://www.bergerweb.net
Dick Berger
