MINI Cooper Tire and Wheel Questions
I have a 2006 Mini Cooper with 15" wheels. Would 16" wheels from a 2008 "S" fit without modification?
Background: Just got a "S" Clubman, has 16" run-flats, no spare. I wanted a spare for 2 reasons: (1) If I get a flat, I need a wheel/tire while the run-flat is being repaired or replaced; (2) Just peace of mind to have a spare on-board anyway.
So I got a non-"S" 15" spare from MiniMania. This will fit on all 4 positions of the base Hatch & Clubman, and only on the rear of the "S" models. The "S" front brakes are too large for this spare to clear. If I get a flat on the front, I would swap around so that the 15" temp spare is on the back (should always put temp spares on the back of a front-driver anyway....).
The bolt pattern is the same, so 16" wheels should indeed clear the brakes, etc. on your 15" Hatch. The opposite isn't true.
As previously said, typically wear items are not covered - and by wear items, it means the "wear" part is not covered. If there is a problem with the part itself, then it would be covered. But sometimes, dealers will replace wear parts under a "goodwill" type of situation.
Do I have to get run-flat replacements (esp. since I do not have a spare)? The dealer recommended run-flats for handling as well as the no spare issue, but run-flats are 2X as expensive (I'm looking at at least $1000 for 4 replacements).
If I have to go run-flats, what do you recommend? I generally like the handling with the original Dunlops, but they seems to grip ridges in the road a lot, sometimes making for a real strange feel on bumpy/ridges surfaces, esp around corners.
Are there others out there who've converted from run-flats to standard tires? What's the down side? Most reviews of run-flat tires mention that they don't last long.
By the way, what's the Slime kit? Something you pump into a flat tire to "repair" it on the fly?
She usually pays for her car/maintenance herself, but I told her I would pay to have the GFT's swapped out for RFT's if she didn't like them. And, I also bought her a Slime tire repair kit, just to give her more comfort in leaving RFT's behind.
That was 3 weeks ago, when she had a set of General GMAX AS-03 tires installed.
There was an immediate and quite noticeable difference in the ride. The "harshness" that used to be there when hitting bumps at low speed is completely gone. Also, tire/road noise is greatly reduced, although I would expect that with any set of new tires.
If anything, the car's responsiveness in handling seems, to me, to be improved, but I that's just my take on it.
Best of all, my wife really likes the new ride. She says its almost like having a new car, ride-wise...
