Internal air without turning on A/C?
bradpennock
Member Posts: 32
There are times I am behind a smoking car and don't want to breath its fumes, but when I click on the internal air button the air conditioning automatically comes on.
I'd rather find a way to just switch to internal air and NOT have the air conditioning come on, but I can't find the right button or button sequence to push to get this to happen.
Ah, and I have the super swanky 2009 SL with Tech, Nav, and Premium packages.
Anyone have a clue? Thanks!
Ok --- if you hit the recirc button the ac will engage but you can adjust the temp of the air by moving the degree button to warm it to whatever you prefer.
I did a little digging and found this message thread on another Murano forum which better details the reason WHY the A/C comes on when we choose to shut off outside air:
http://forums.nicoclub.com/zerothread?id=378565&postid=4156000
It's the way Infiniti's are set up. Same with Nissans. The Murano I had before my EX was the same way. I believe the main reason they do this is if you have re-circulated air on (especially if it's cool or damp outside) then the inside air that you're breathing in and out gets damp, so without a/c on (which removes moisture from air) the air inside the car would get more and more moist, and would steam up the windows. Also if you press the front defogger button it automatically turns the a/c on to ensure it's blowing only dry air onto the front screen.
