yahooligan is completely correct. Brake fluid is not a "lifetime" fluid. BTW, I'm also going to have the transmission fluid changed in our town & country at the next service visit. I don't believe ANY fluid in a vehicle is "lifetime."
For the brakes, including the originals i'm on my 4th set and have 51K miles. Already hear the grinding going as if the caliper is stuck closed again. Chrysler did a recall, I used twice, so only paid $150 in total for brakes as they did reimburse each time. But now with higher mileage that isn't going to happen. My mechanic says the 2008 were a newer and worse design they did, and will continue to fail.
Newest issue is oil light comes on when i hit the brakes, oil is good so is brake fluid. I change oil every 3500 miles with tire rotation every 3rd. The brake fluid was drained last year when my guy had to work on the caliper which was stuck.
Had an issue with the A/C each spring, another recall they fixed for free as it seems to be prone to leak over the winter. This past spring no issue and it was hard winter in NE, so I think that problem is gone.
Other than that I actually love the damn thing with all the room for the kid's gear, sat radio and dual DVds for road trips.
Are you all signed up to get the recall notices? not quite sure how i'm getting them, but they mail it to me and I let the dealership deal with it.
I sent an email to the swedish chrysler agent with a couple of questions about the brake issue and any possible good-will. They didn't even bother to answer me. This was my first and last chrysler, that's for sure.
The root cause of the problem is that it´s a design fault with the brakes. The brakes are simply too small for the car. This apparently was changed in late 2009 or 2010 and the problem has been resolved. However, the people who have the 2008/2009 models with the brake problem are more or less screwed.
Our dealer says it is not uncommon to have to change the brakes and rotors on these cars every 20-25k km....which is basically insane. With that said, I think your best bet is to buy some aftermarket performance brakes...like EBC ultimax with yellow pads....these brakes are drilled and slotted and will take heat much better than the current OEM parts from Chrysler. The performance parts are expensive but they are about the same price as the original OEM parts which are no bargain either.
So in the end, there is no solution.
There is however a class action lawsuit regarding this problem which can be found here:
lemberglaw . com/class-action-cali.php
Thanks for your reply. Yes, no doubt there's a design flaw. Unfortunately however I don't quite buy that it is just the brakes that are too small. At least not on ours. All four brakes often get hot (and I mean hot) even when they have not been used. Some times I have noticed that they are so stuck when driving away that I noticed the car is "heavy" and stops way to quick if I just release the gas. Brake performance also indicate there is no real problem with the size of the brakes. Hitting the brakes hard and the car stops real quick.
As you say, the solution is to change the brakes. However, I believe the problem is just not with the calipers, pads and rotors, but might also be with the master cylinder or other parts further up in the system. I've sent a question to brembo on what parts I would need from them to replace the whole system. But it doesn't seem like they care to answer.
Our car is around 45k miles without changing the rotors, so compared to others we are fairly lucky anyway.
EDIT: However, I just looked up a set of rotors for the 2008 and 2010. They are the same part numbers. So I think somebody fed you false information.
I had the thought that we could swap out for something like Cherokee SRT8 brakes. I haven't been able to figure out yet if this is even feasible, though. Don't know if they would fit within our stock wheels or even mate up with our hubs, etc.
Pam
Will let you know how they look after 5k when spring rolls around.
BTW I had bendix ceramics on front and a different brand on the back. I had raybestos rotors. Fronts gone in 11k miles this time. Backs look half gone but I didnt change them out. Stealership gave me a 1/2 truth when I had the van in for the recall on a vent tube. Said I needed brakes all the way around. Very sad.
Just checked the caliper listings and, for at least the first manufacturer I pulled up (A1 Cardone), the calipers are the same part numbers for 2008 as 2011.
http://www. ebay. com/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=drilled+slotted+chrysler+- town+country&_sacat=See-All-Categories
However, thanks for the tip. I did find EBC brand on Ebay. They do cost over $400 for the set of rotors only.
So you've had them on since August? How are they working out for you? How many miles? What condition are the rotors and pads in now?
What was the brand name of the parts you received?
What do you think about what this guy says? It makes sense to me. I am really wondering what your experience is with the parts? Right now I have EBC Yellowstuff pads on the front we will see how that works out with raybestos rotors which have now been cut after just 11k miles.
Chrysler Dodge Journey Owners and Lessees File Class Action Lawsuit Complaint Against Chrysler Over Alleged Defects In the Dodge Journey’s Braking System’s Brake Pads and Rotors.
A class action lawsuit has been filed against Chrysler Group LLC (“Chrysler” or “Defendant”) in the United States District Court for the District of New Jersey (styled Gabriella Tatum and Jamie Meyer v. Chrysler Group LLC, Civil Case No. 2:10-cv-04269-DMC -JAD) alleging, among other things, that the 2009 and 2010 Chrysler Dodge Journey suffers from a design defect in its braking system in that the brake pads and rotors are too small and thin to handle the braking duties required by the size and weight of the Chrysler Dodge Journey purportedly resulting in an increase in brake wear and causing brakes to potentially fail as early as 12,000 miles, requiring early replacement of brake pads or shaving or resurfacing of brake rotors, according to class action lawsuit news reports
http://classactionlawsuitsinthenews.com/class-action-lawsuit-complaints/chrysler- -dodge-journey-class-action-lawsuit-complaint-filed-over-chrysler-dodge-journey-- brake-pads-brake-rotors/comment-page-1/
http://www.lemonlaw.com/wordpress/dodge-chrysler-brake-problems/
If we all file Lemon Law then Chrysler would have no choice but to deal with the issue!!
I contacted this atlautosports myself yesterday to inquire about their brakes. They do offer slotted, crossdrilled rotors for the T&C... HOWEVER, that is only because they take OEM rotors and slot and drill them themselves. So if you want the same crappy OEM rotors, then that's the place to call. I won't be ordering from there.
I'm going to see if I can get a rep on the line at Brake Motive. From what I've read, they sell Stoptech rotors for our T&C for cheap.
I found a place called cquence brakes that I found many good reviews for on, of all places, Corvette forums. I figured if it is good enough for them, it should be good enough for our minivan.
Got THEM on the phone on the first try. Ordered up their top-of-the-line crossdrilled and slotted rotors for all 4 corners. Total was a quite cheap $214 shipped. They arrived a couple of days later.
They seem to be very nice. They are quite heavy. I also purchased ceramic/metallic pads from Amazon (the cquence pads were quite pricey) and changed the fluid while I was at it. So far I can report that the van stops amazingly well now. No vibrating, of course. The brake feel is improved greatly and the pedal height and bite is very consistent (which I can't say about the stock brakes). Hopefully they will hold up over the long term.
EDIT: Ok, a quick google search and this is the first link that popped up: 2005 Grand Caravan cabin filter replacement
I changed the calipers up front this last time around (had to change again at 7k miles)
Looking at everything I am begining to wonder if the steel wheel-hubcap combo isnt making the problem worse. The car is pretty low to the ground and there are very few holes in the rim for venting air into the brakes. It seems like Dodge designed a nice little oven in there.
I wonder how many people with sub 20k brake wear problems are using this wheel combo verse the alloy star type rim that allows a lot of air through.
If we want anything to be done with all these complaints about the brakes - YOU MUST FILE COMPLAINTS WITH National Highway Traffic Safety.
I just replaced my brakes for the 3rd time with 45,000 miles on 2008 van.
I had 1 mil left on the brakes with very little warning!!! The repair shop said I could have been in an accident from brake failure. I have two small children - this van is dangerous!
Chrsyler refuses to acknowledge the problem and after an hour on the phone with them - the rep told me that only NHTSA has the power to do another recall on the brakes!!!!!!
My van is out of warranty and they WILL DO NOTHING TO HELP ME.
Every complaint is researched and acknowledge. Even if it was awhile ago - you must report it!!!! Chrsyler is not giving them the information.
I did the work myself.
In using EBC Green Stuff Pads I found that the part number for a 2008 T&C is the same as for a Jeep Wrangler 3.8 and a Dodge Nitro 3.7. Both of these vehicles weigh less than the T&C. This could be why the brakes wear out so fast.
I used EBC DP71798 pads in the front and DP61840 in the rear.
EBC slotted and dimpled rotors. Front GD7442, Rear GD7443.
Also installed new hardware from rockauto.com.
Raybestos H5774A Disc Hardware Kit Front qty 1
H5819A Disc Hardware Kit Rear qty 1
H15176 Caliper Bolt Front qty 2
H15234 Caliper Bolt Rear qty 2
Got Speed Bleeders from https://ssl.zoovy.com/c=RRXvJj9QZX0RlN7CQORNdB38l/s=www.speedbleeder.zoovy.com/
This makes bleeding the brakes and easy one person job.
I used the Stainless Steel ones model SB1010-SS
And flushed the low quality brake fluid that came on the van (this is what is causing the calipers to freeze up) with ATE Super Blue Racing Brake Fluid, (very high boiling point).
When you use the Blue you can see that the old has been flushed out. They also make an amber with the same specs so that the next fluid change you can see when the blue has all been flushed out.
Last but not least go to Autozone and borrow brake setting tools for the rear brakes.
You will need some lube for the caliper pins and neversieze (spell?) for the bolts and on the hub surface where your rims touch the rotor.
Google how to change brakes on a 2008 T&C.
Took me two hours by myself including the brake bleed.
I was lucky in that my brakes went before 12,000 miles. I also received a letter from Chrysler saying they would pay for front brakes under warranty (12,000 or one year). I billed them for the for fronts, plus labor at the dealer rate. I got a check less about $2.00 for the repair.
And there is now ONE report of problems with one Odyssey that we know about, against how many T&C's and law suits, globally?
Don't try to belittle the T&C brake problem just because another car is reported with warped rotors. Lot's of cars end up with warped rotors sooner or later, that does not mean the model have huge brake issues, like the T&C does.
I'm not belittling it, but I'm also not blowing it out of proportion like some other posters.
I replaced the front calipers on the advice of a "Dodge Expert" who claims that they have a "known" problem with the front calipers not being bad but hanging a little to much and not releasing. I have around 2500 miles on the brakes now and will check them again at 5k. We will see what happens.
Every car is only a machine and yes all machines will eventually have problems despite the best marketing of the manufacturer. Dodge under engineered brakes on a FAMILY vehicle. To me that is next to a crime and may actually be one if people lose their lives due to that fact. The last place anyone should cut costs is the brakes.
If you keep having a problem no matter what you install, I also wonder if, as you posted a while ago, the wheels are causing cooling problems for you.
kcram - Pickups/Wagons/Vans+Minivans Host
