Hyundai Sonata Interior Lighting
If I have any complaints regarding my Sonata it is the interior light switches. I have a sun roof and this puts my ceiling light switch to far to the rear to reach, and the lights switches over the center column are not lighted and I can not find the D** things when it is dark. Other than that, I am very happy with my 06 Sonata.
What are others doing with there light sw. at night?
Also how about turning the dome light on when you turn off the ignition? I have had my sontata for almost 2 months now and still am surprised that it doesn't come on till you open the door.
I agree with your assessment of the Sonata interior lights.
What drives me up the wall is the fact that Hyundai did not use some method to light up the over the dash interior lights. I can not see in the dark. And it is dangerous driving at night to take your eyes of the road and fumble around trying find the over the dash light sw, And my center ceiling light is unreachable in my sun roof car. They should have done a better job.
It is puzzling when you understand what a great job they did with so many of the different systems and then to not take care of such an important item that should be simple to fix!
It really makes you wonder. And this problem has been around for some time now.
Other than this small gripe I really like my I4 Auto 06 Sonata. Good millage, decent power, comfort and room. Great car!!
Hyundai.....fix the interior lights!!!
That doesn't sound right. I have a 2008 SF Ltd with sunroof and both the roof light behind the sunroof and the map lights come on when I open any door. Here is the info direct from the owner's manual:
The light comes on when any door is
opened regardless of the ignition switch
position.
If a door is opened with the ignition switch
in the ACC or LOCK position, the light stays
on for about 20 minutes. However, if a door
is opened with the ignition switch in the ON
position, the light stays on continuously.
When doors are unlocked by the transmitter,
the light comes on for approximately 30
seconds as long as any door is not open.
The light goes out gradually after approximately
30 seconds if the door is closed.
However, if the ignition switch is ON or all
doors are locked, the light will turn off
immediately.
• : Push in the map light switch to turn
the light on or off. This light produces
a spot beam for convenient
use as a map light at night or as a
personal light for the driver and
the passenger
The interior courtesy light has two buttons.
The two buttons are:
o DOOR
The courtesy light turns on when a door is
opened or when a door is unlocked by the
transmitter (if installed). The interior light
goes out slowly after 30 seconds after the
door is closed. However if the ignition
switch is ON or all vehicle doors are locked
when the door is closed, interior light will
turn off even within 30 seconds
o ON
In the "ON" position, the light stays on at all
times.
My wife has an 09 Sonata Ltd and the interior lights work the same as my SF. Double-check the manual and make sure the "door" button is pressed on the roof light.
However it does not address my complaint regarding the placement of the center ceiling light. (I must lower my seat back to an unsafe position to be able to reach the switch while driving)
And the over the dash lights are not illuminated so I must fumble around trying to turn them on in the dark, not good while driving at night.
My center ceiling light works just as you posted. However my over the dash lights do not come on with the ceiling light when the door is opened.(not really important to me)
To at least have some light available while driving, all the company would have to do is make the over dash light sw illuminate just as the other sw in the auto are when the head lights are on. Also putting a sw on the dash allowing illumination of the center light would be good.
Again, I appreciate your post, thank you.
Rereading your post I see one other item I will address. We own a 2006 Honda Civic and there IS a way to allow both the ceiling (or roof) light and the map lights to function when the door is opened then they go out together in "fadeout" fashion. The car was in the shop recently and the service techs must have disabled this function for some reason because when we got the car back I immediately noted how dark the interior was (we also have a sunroof which places the roof light to the rear of the car) so I re-read the owners manual and sure enough there is a way to have both the roof and map lights come on when the door is opened. I did that and now all come on. I'd guess Hyundai has some provision for that as well.
I think I have found a possible answer to my problem. I carry a small high intensity flash light in my glove box. I will put this flash light in the small compartment just under the radio (so I can reach it easier) and us it for those times I need some momentary light.
Thanks to everyone for your input.
Sometimes the simplest ideas escape us!!
http://www.hyundai-forums.com/index.php?showtopic=16097&hl=light
To me, 2009 Sonata owner, its not a big deal and easy for me to reach both lights while driving. Although I don't tend to use the rear light often, but have used the map lights once or twice. You just need to consider the traffic or surrounding area for a few seconds before reaching up for the light.
every other car i ever had you could see inside when you opened the door at night. the sonata is poor at best. i have had map light before as well as a dome light in between them...
i just think that hyindai needs to pay a little more attention to interior lighting.
As an older car guy, I remember when almost all cars had an interior light sw between the two doors about 3/4's up the side post between the front and rear doors. Easy to reach from the outside of the car. Up was on, down was off.
My old 87 Chevy 1/2 ton PU has a head light sw on the dash that pulls out to turn the headlights on, you can rotate it to adjust the dash lights and by turning this pull sw all the way to the right, turn on the over head lights. Nice and easy. Almost all cars at one time worked like this. It made the learning curve of adjusting to a different auto easy.
Not all the new stuff today is perfect!
