Chevy Blazer Battery Charging Problems
damien96blazer
Member Posts: 2
in Chevrolet
g ha`scanged .I took the alternator to the Auto Zone to have it checked to see if something was wrong with it , I was told that it was fine. I am trying to find out what could wrong with my truck my battery is not getting a charge. Can someone please help?
I have a little Deltran 800ma Battery Tender I keep attached to the battery in my Blazer when it is not running even when I have a new battery. The light on the battery tender indicates if there is a excessive battery drain because the indicator light will remain yellow and never reach the green maintenance mode indication. That is how I found a bad power door lock relay. .
thx
Have the battery load tested and see what the results are. Can I guess that this battery is about three years old?
2. When the fuel pump in the tank was replaced, was the harness and strainer also replaced? The better quality fuel pumps include a new wiring harness and it is Airtex WH 3006 for $10. You must purchase the fuel pump strainer (not the filter) separately and it is AC Delco TS29 and costs $15 It is recommended that the fuel pump, wiring harness and strainer be replaced as a complete assembly especially since they are inside the fuel tank.
3. Load test or replace the battery. AC Delco 72-60 and it costs $100.
4. Replace the fuel injector pressure regulator assembly, AC Delco 217-2251 and costs $61 or replace the complete fuel injector assembly (spider) and it is AC Delco 217-3028 and it costs $312.
5. Replace the ignition coil, AC Delco D577 and costs $46 and you will need the coil bracket which is AC Delco 10457978 and it cost $18.Tha tis because the original ignintion coil may be riveted to the original coil bracket.
6. Replace the ignition control module, AC Delco D579 (4-pin) and costs $101.
7. Replace the VSS (Vehicle Speed Sensor) Delphi SS10299 (4WD) it costs $125 or the Delphi SS10302 (RWD) it cost $23. A diagonstic code 72 is a VSS singnal loss and will cause bucking, jerking and stalling just as you describe.
Those parts are plus labor cost. It would be best if you could check the more expensive parts before they were replaced. Sometimes if you do the work yourself, you must fix a problem by the process of elimination, which is nothing more than a crap shoot... or purchase $5000 worth of diagonsitic equipment and learn how to use it. . Fixing a problem that in that manner is not the most economical way but an auto repair shop diagonsitic will cost $90 up-front and there is no guarantee what they find will fix the problem. You will still have to pay for the parts and labor.
Look on the bright side, if you replace various parts that does not fix the problem and the last one you replace is the one that fixes the problem, at least you have some new parts on the car that probably needed replacing anyway just because they are old and may fail at anytime. Heck...sometime I have replaced a part just because it is dirty and looks bad.
SUVs and Smart Shopper
