GMC Yukon Denali/XL Autoride Suspension
I have owned an 03 Denali for two years. Recently whenever I start up, I hear a motor running which sounds like a compressor from under thr rear of the car. I believe this is the Autoride feature. Thing is, when I first bought the car, it would only run if I had a load in the back, or put a trailer on. Now it runs every time I start up. Ideas?
Looking To Do-It-Yourself?
How To Replace Air Shock Compressor Motor
Thanks for your help.
My choices?
1. repair and keep the car til it dies a miserable death b/c fixing the suspension will get me at LEAST another 75K miles!
2. Trade it in and buy a new-to-me one (maybe an '05 or '06) b/c the cost of repair is more then I should pay given the value of the car.
3. Other -- b/c there is always an other
Help! What would you do and why? Thanks for the help!
Anna
Assuming you only need to replace all 4 Autoride shocks (no air line leakage or compressor and position sensor issues), you may consider an option #4 if you feel up to it, that is to order your own parts/shocks and have the mechanic replace them for you. Check out the store in the URL below (just found this place a couple of days ago...) where you can purchase the exact same OEM shocks for the front (Part Number 00GMOEF) and rear (Part Number 00GMOER)... Good Luck to you!
http://www.arnottindustries.com/part_GMC_Air_Suspension_Parts_yid15_pid95.html
Jim
SUVs and Smart Shopper
http://www.arnottindustries.com/part_GMC_Air_Suspension_Parts_yid15.html
2002 Denali XL 145,000 mi.
PS. Besides the fuse, have you also verified the ALC Relay under the hood (in a black relay/fuse box)?
RTD autoride ( real time damping ) would this be the right relay?
I phoned GM and the service person said she would look into this and get back to me, but never has.
This vehicle has been in for recalls, and warranty work since the day I got it, on a very regular basis, and as much as I love it, I'm really getting fed up. :lemon: ?
Hopefully someone can enlighten me on the life expectancy on shocks.
Thanks for your reply.
http://www.powerblocktv.com/site3/index.php/trucks
Are there any displays that let me know it's active if the conditions get bad?
http://www.arnottindustries.com/part_CHEVROLET_Air_Suspension_Parts_yid11_pid92.- html
jim
http://www.bilsteinus.com/contact.php
http://townhall-talk.edmunds.com/direct/view/.f0af225/18
http://www.fullsizechevy.com/forums/general-discussion/technical-maintenance/291- 516-autoride-disconnect.html
What is the sensor looking for on the front shock? There is no air line to it so does the sensor control anything? Why not cut off the top of the old shock and plug in the sensor to the cut off piece of the shock?
Jim
