Just an excuse...
Jeep/Chrysler?Dodge will not stand behind any of their junk...
Get a repair manual and follow the directions replace them yourself or find a real mechanic...
By the way if you do go off-road with you Jeep broken leaky things are just part of the game...
Quit taking it to the dealer.
They only want to work on street-wheelers anyway.
I love my Jeep.
I hate my Jeep Dealer.
Of course, I rarely floor it, I inadvertenly pulled out into some traffic and needed to speed up quickly.
Excessive heat is often caused by towing, aggressive driving especially offroad or on mountainous roads, and long periods in low range (high rpm/low road speed).
Fluid contamination is usually water (driving too deep) or particulates, which can come from poor cleanliness when servicing or wear particles from worn internal components, which usually come from a lack of servicing or just general wear and tear due to high mileage.
Servicing is very important, but also very easy. It consists of dropping the pan, draining the fluid, replacing the filter, adjusting the front and rear bands (very important and often overlooked), cleaning and replacing the pan, then filling with fresh fluid.
Does any of the above apply?
and if it's a D44 it will look like this:
These of course are rear axles. Your front one will be a D30, and look like this:
With regard to your 4" Skyjacker lift, if no other mods have been done to correct the driveshaft angle, then they're most probably correct about the pinion housing leak. You can also expect premature failure of the universal joints.
Few major modifications come without side effects, one of which is that they can put stress on related components, and another is that consequent warranty claims connected to the modified components can be denied.
Success at last..... After changing the complete ignition system, crankshaft position sensor, catalytic converter, fuel pump etc. and getting NO codes, I decided to look into the exhaust manifold a little closer. In order to see if it was causing the O2 sensor to get false readings, I took the O2 out of the equation by unplugging it. While it won't be good for fuel economy, it did stop the problem. I am ordering a new manifold to stop the leak and will probably install a new O2 sensor. Don't know if it would be your same problem, but the problem seems to be resolved on mine. Let me know what you find on yours.
Steve
The best reference is the Factory Service Manual (FSM) which costs about $100 (or two tanks of gas). Alternatively, you can have twelve months unlimited access to the FSM for $25 here at: AllData
I've serviced the transmission, and although I'm not sure what the manual says, once under 49k should be enough.
Wonder if the bands were adjusted?
I can tell you it's a heartbreaker to give up your Jeep, but ours was going to start costing us more money than I wanted to get into with the roof leaking, potential rust issues, the cracked manifold that will eventually need to be fixed, etc.
Anyway, best of luck with yours. Sorry I couldn't be of any more help with this.
If the noise suddenly appeared, or if other Jeeps don't make it, then it's not normal and needs to be addressed.
Thanks in advance.
You might need to shim the bumper down. This happens some times.
Oil the hinges...10w/30 works ok.
The trail gates on theses seem to need a little maint. now and then.
The hinges on the TJ's are pretty sturdy but don't hang a tire bigger than a 10.50/31. If you hang anything bigger they will self distruct.
Check the torx screws around the latch on the gate. Blue LockTite is a Jeepers best friend.
Check the bolts on the hinges.
As for realignment...probably not needed...
If all else fails get an 8lb BFH (Big Farmers Hammer)
Thanks - but hey the bumper does look good....
Enjoy.
Kevin
The short version is to remove the instrument housing and tweak the connector pins on by about 10º. Then inject a little dielectric grease into each of the corresponding sockets (about 20 in total). Re-assemble and the job's done!
Steve :shades:
Every time I drove it down a bumpy road...
The problem was the connectors on the insterment panel.
The panel is a fairly straight forward removal.
Just take the dash cover off and pull the inst panel out.
The connectors need to be shimmed up so that the make positive connection. A little diaelectric grease couldn't hurt too.
Jeep knows about this.
There was a recall and service bullet. Fat chance getting them to admit there is a problem as the recall only involved a small number of VIN.
Love my JEEP...Hate JEEP service...
Thanks again
kc
90 Wrangler
90 Wrangler
I sometimes think that they start with the heater core, then build the rest of the vehicle around it!
The first generation BMW sevens were far worse; you have to remove the console, the A pillar covers, and the dash pad. Nine hours. :surprise:
Always nice to hear of someone getting good use from their Jeep. Was it a reliable 160K?
I have experienced what seem to be "power surges" when decelerating. It occurs while I am driving and apply the brake to either slow down or stop.........
I can only give you straws to clutch at I'm afraid. The first (which you won't like, but do think about it) is that the main cause of this problem is just catching the throttle pedal with the edge of your shoe when you brake. We very often make the minimum of movement with our foot from the 'go' to 'stop' pedal, and it's usually only evident when you look at the wear pattern on the brake pedal.
I know I'm at fault on this.
The second reason is much less common and concerns a fault in the brake booster. What happens is that the booster uses, or allows to bleed off, more vacuum than is normal. This has the effect of mimicking an inlet manifold leak, a symptom of which is to increase engine revs. This can be a constant or intermittent fault.
Sorry I can't be of more help, but it's especially difficult to diagnose an intermittent problem.
Good luck!
I loved that Jeep and was very heartbroken to have to trade it in. I always kept up with the regular maintenance on it and it never had any major problems. The only reason I traded it in was because I drive so much I would have been over 200,000 within the next 6 months and it would only be a matter of time before I would have to start dumping money into keeping it running. I also figured it would be in my best interest to trade it now while it was still in great condition and could get a good amount for it and also get a great deal on the overstock 2006 Jeeps.
Thanks so much for your thoughts on this problem. (It is funny you should suggest it could be my foot because my brother said the same thing; however, I can tell when I "bump" the pedal and unfortunately that is not the cause of this issue.) I guess only time will tell if it will be on going problem or if it can be fixed. Thanks again.
Thanks for the information. I will definitely do some more research now that I know others have experienced similar issues. I sincerely hope that there is a way to fix this problem though... I spent a lot of money custom ordering this Jeep and expected it to be in perfect condition. I am concerned that it is having this safety issues already. Thanks again!
I have a '94 Wrangler Sahara, approx. 125K miles, 4.0 6cyl.
I'm about to make a transcontinental trip and would like to diagnose and fix this problem before I head out.
The Jeep starts up fine when cold and runs well on short distance runs. However, once it warms up, it tends to run for about 20 miles before it starts stalling out. Sometimes it does this while driving at speed; other times it does this when I take my foot off the gas preparing to stop.
After stalling out, I wait about a minute or two and the Jeep starts right back up again.
As I'm in the California desert, I should note that summertime temperatures tend to run in triple digits when the problem seems most prevalent. However, it has happened in the winter especially during wetter weather.
Needless to say, I don't want to start cross-country and have the Sahara die out on me. Unfortunately, I'm not mechanically inclined; so, I'd like to have some ideas before a mechanic looks the vehicle over.
Also, would I be wise to let a dealer perform the diagnosis -- not usually my first choice since they tend to diagnose problems other than the usual cause -- however, considering my situation, I might go that way.
Secondly, can someone tell me what kind of fuse I need for the cigar lighter/radio in the same vehicle? Is the heater on the same fuse? (I would think not, but I'm dumb when it comes to this stuff.)
Any suggestions would be helpful.
Ciao for now!
Mike
Can't help with the fuse, but it's always worthwhile to have a workshop manual, which is sure to carry that information.
My best advice is to take it to an independent transmission shop for diagnosis.
Bottom line..can I routinely go back and forth between 2 and 4wd even though I may have to do it many times during a short trip or a long one? I read where one test driver said he used it when there was a LOT of water on the roads and it helped with no apparent damage. TIA
On black ice there's virtually no traction with regular tires. No system of 4wd/awd/abs/traction control/stability control etc., will help when there's no traction. The only way it can be predictably driven is with chains or studded tires.
.......can I routinely go back and forth between 2 and 4wd even though I may have to do it many times during a short trip or a long one?
If you feel you must. The biggest practical problem with engaging 4wd on the highway is finding that you can't disengage it without stopping and reversing. This is because you've driven on a dry part of the road for too long. If you continue for too long, steering will become progressively more difficult and the entire drivetrain will be placed under excessive strain, though the damage is liable to be longterm rather than immediate.
The real answer is that if you're driving in conditions that are liable to cause you to lose traction and spin out, you're going too fast........slow down!
As for driving in snow, the Wrangler is quite capable but is hampered by its short wheelbase. It also handles differently between 2wd and 4wd, and also if it has an LSD or locker. The best way to get comfortable with its manners is to go and practice in a big empty snow covered parking lot.
