Nissan Pathfinder Oil Consumption
My 2002 well maintained Pathfinder w/77,000 miles on it is burning oil like crazy. It has always used oil but recently has started to use a lot more. I have put 4 qts. in since the last oil change about 2,400 miles ago. I have changed the oil on this vehicle every 3,000 miles. It has never been abused.
I have discovered that the baffles in the right valve cover has been known to clog resulting in oil being sucked into the PCV valve to be burned by the engine. The only fix is to replace the valve cover with a newly designed one from Nissan. I am currently having this done.
I was wondering if anyone else has had this problem and does this fix work?
Kz
Kz
I am having the same problem with my 2002 Pathfinder with 84000 miles. I have seen other blogs recommending this fix. Has it corrected the issue for you? Please let me know as I dont want to make a blind investment in fixing this.
I was going to get the valve cover replaced this week.
Did you ever get an answer to your question? (if the valve cover fixes the problem)
Did you have it replaced? I assume you have seen this site:
http://www.netcrafting.com/car_mx/pathfinder/oil.html
Based on that, it looks like the cover will fix the problem, but not permanently. Looks like we'll all be doing it again someday, if that's another 70,000 mile away that might not be too bad (vs. buying another car)
Turbino
I had the valve cover replaced at the dealer at 65,000 miles, that cost about $900.
I unfortunately just bought the truck since my car was totaled. I bought it a few months ago with 60,000 miles on it. I noticed the oil light came on an the dipstick was dry, that is how I discovered this thing burns oil and I bought a lemmon. So I dont know the history on this truck and how long and how much oil is was burning before I was a sucker to buy it.
**** FOR ME, REPLACEMENT OF THE VALVE COVER DID NOT SEEM TO MAKE ANY DIFFERENCE IN OIL CONSUMPTION. IT DOESNT SEEM ANY BETTER OR WORSE. I LOOKED AT THE OLD COVER, THE DRAIN WAS NOT CLOGGED. SO MY PROBLEM IS EITHER RINGS OR VALVES.
The truck does not smoke and seems to run ok. The gas mileage is also OK. I'm getting about 17-18 MPG in city driving, that is normal per the EPA estimate on the sticker. My truck is a manual tranny.
I now just keep a couple quarts of oil and a funnel in the back. I check the oil and top it off about every other gas fill up. It sucks but its not too big of a deal for me as long as it doesnt get worse.
My problem is similar to yours: my truck is consuming that much of oil although it does not smoke (no oil leaking from the valve cover nor trace of oily deposit on tail pipe) and it seems to run good, and this makes me wonder where the oil is going. Granting that either the rings or valves are bad oily deposit should at least show on the tail pipe.
I am stumped and do not know what to do at this point to fix the problem so I will keep a couple of quarts of oil and funnel in the truck just like you and top it off to normal oil level when necessary.
He added that the problem I have with this engine is "normal" and not due to the engine valve cover design. This engine, by spec, is supposed to burn through ".75 liters of oil every 1,000 miles." Those were his exact words. His recommendations were the following:
1. I check the oil periodically and top it off when necessary. At around 1500 miles use a supplement that will cut and eliminate any sludge in the engine to keep it running as clean as possible.
2. Use a Nissan branded oil filter at every oil change.
3. Don’t waste money on synthetic oil as the engine was not designed to take advantage of it.
If this problem does not exceed the specs above, the car should pass emissions with no problems at all. If it does not pass emissions because of excessive oil burnout then you have another problem.
Because I depend so much on this car, I have chosen to take the safest route possible.
1. I use synthetic oil. Valvoline 10w30. I know he recommended against it, however, I want the additional protection synthetic has to offer. If I’m on a long trip and I get low on oil, I need to be sure I can get home with that synthetic protection before permanent damage is done.
2. I keep a case of oil and funnel in my garage. It’s a pain but necessary.
3. At 1500 miles I use a “Lucas” brand add in to the oil to keep the engine clean.
4. I have the Nissan filters but have yet to use one. Will do on the next change and will report back if I see any change at all.
By the way this problem can give your cars emission system several false positives on problems. Let me explain why. Several of the engine sensors are driven hydraulically. The hydraulic fluid is the engine oil. If it gets too low, your check engine light may come on before you low oil lamp. If you take it to a shop to get tested, the test will conclude that one or two of your sensors are shot and must be replaced. I got talked into replacing two sensors by a Mineke mechanic with a price tag of just over $500.00 after parts and labor. Close to my next oil change and before I knew about the oil consumption issue my check engine light came on again. This time I took it to express oil change and they actually tried to work the problem instead of throw parts at it. The tech reset my computer after the oil change (after noticing I only had 2 quarts of oil left in my pan) and told my about the hydraulic sensors. He said if I kept the oil level as close to normal as possible, it should not happen again. To this date, I have not had a repeat of this problem.
I hope this helps someone out there. Let me know if you all come up with something else. Thanks.
It’s worth noting that the engine oil hydraulically operates several engine sensors. This makes the engine performance dependent on the oil level then. In this regard it is therefore absolutely necessary to have proper engine oil level before you operate the vehicle.
Meanwhile we don’t exactly know what’s causing excessive oil consumption on Pathfinder it’s just logical to do something like the safest route possible you’re taking to avert low engine oil level occurrence that could result to other engine problems on the vehicle.
I presume the "mystery" oil that is being consumed is also fouling and clogging the CCs. I have no idea how long the fix will last.
I will be trading in this piece of garbage as soon as my job situation is more stable.
I was a loyal Nissan guy until now, my first was a 1972 240Z, my last will be this P.O.S. 2002 Pathfinder
I will to try installing a 'water-trap' unit, designed for air compressors, into the PCV hose. I will just empty the container, which seems cheaper and easier than replacing the valve cover.
I also wonder, if the valve cover was 'dipped' in a degreasing tank at an engine rebuilders, if it could be pressure cleaned and reused ?
My tailpipe is black with soot, and initially I thought this was an excessively rich fuel problem, but my mileage is between 18 and 20mpg consistently. The engine has lots of power and torque. I worry this oil consumption will clog the catalytic converter.
Did I mention my diff was leaking? dealer said its "over full". Sure a diff that's never been touched "over full".Well of course it started leaking again after a 150 service. Just too much. I work too hard to keep paying on a pain in the [non-permissible content removed]. Bye bye Path.
Thanks Dawn
i had a brand new passenger side valve cover (which also includes a new PVC valve by default) installed at the dealer a few months ago for $1000. My 2002 pathfinder had 65000 miles at that point. this $1000 did not help my oil consumption in any significant way. i still mystery burn about 1 quart per 1000 miles. i keep oil on hand and just refill, i check it every other gas fill. just live with it or trade it in, dont waste money trying to fix it. the truck runs fine, so at least things are tolerable as long as the oil deal doesnt get to the point where i have to refill every other day, right now i refill 0.5 to 1 quart about 1 time per month.
this problem may be due to bad piston rings, block or valves, probably a design or manufacturing tolerance issue, i am 98% sure it is one of those issues, and any of those cost at least several thousand $$$$ to fix
again, live with it or trade it in.
for what its worth i am a mechanical engineer (without time to work on my cars), i understand engines, there is a unspoken or not understood design or tolerance issue with that engine that can only be fixed with a lot of money
what u describe has been reported before under bad "power valve" screw falling out of these engines into the internals. look up on google to find more info on that issue. it is a definite problem
HOWEVER
ONLY AUTO TRANSMISSION 3.5 HAVE POWER VALVE ASSY FOR EXTRA TOWING POWER.
WHEN I WENT THRU THIS BS WITH THE DEALER THE FIRST TIME THE FIRST THING THEY SAID THEY WOULD CHECK WAS THE POWER VALVE SCREWS. WHEN I TOLD THEM IT WAS STICK, I ASKED THEM TO CONFIRM THAT MANUAL TRANNY DOESNT HAVE THAT POWER VALVE. THEY CONFIRMED THE MANUAL DOESNT. THEY STILL HAD NO EXPLAINATION FOR MY OIL CONSUMPTION.
SO THE MYSTERY CONTINUES. I HAVE NO LEAK, NO SMOKE, NORMAL MILEAGE AND IT RUNS FINE. BUT EATS OIL LIKE A SOB
I've run Mobil-1 5/30 and filter since birth, every 7500 except 3000 when towing.
An analysis on my '99 Quest would be interesting (I'm at 158k miles), but it's running okay and isn't worth much anyway, so I have a hard time justifying the $25, when I can do an oil change for that and have $10 left over. I use SuperTech or whatever is on sale at NAPA and change at 7,500 mile intervals too. Don't tow. Never have to add oil between changes.
Got any blue smoke? How are the plugs? Do you have to pass emissions tests where you live? Thought about switching to a 10W-30 oil? Replaced the PCV valve lately?
I really can't complain. It's been a fantastic car. I've put shocks/struts in it once, 3 or 4 sets of tires, and a complete brake system overhaul at 120K. Everything else by the book. In fact, it never even had to have an alignment until I had the suspension done at 130K.
I have owned a 2003 Pathfinder Chilkoot from new. I now have 152,000 K on it and am on the third engine from the dealer. It sounds like I have been treated better than others but I am not happy about it. The "third engine" was only a top end rebuild and a new cconverter. The dealership says they will not do any more repairs when this engine is finished. I believe I have about 20K left on it. The symptoms seem the same as reported by others, increased oil usage until a quart with every fill up. Dealer told me to change my oil often and do not use back pressure for breaking. The parts guy says this problem does not come up with automatics. One explanation from Nissan parts guy was that the catalytic converter gets sucked back into the cylinder and chew things up. This is my 3d Nissan. Happy with the other 2. Will never buy another. It seems like short term thinking on their part not to do a recall.
No smoke simply means oil isn't getting into the cylinders, but if a lot is disappearing and you see no apparent leaks, it has to be going somewhere.
How much oil is it using?
