GMC Jimmy emissions
Jnavarrete
Member Posts: 4
I have a 2005 GMC Jimmy and a few month ago the "Check engine" light went on. As per manual recommendation I changed the fuel, I was using low grade Esso and changed for Medium and High for the next two tanks and the light went off. It went on briefly later on and I decide to change completely to Petro Canada and since then I haven't have any problem.
Now my questions, in your experience which have been the fuel additive that have better improve the car emissions or clean better your system.
I, and probable other, will appreciate your opinions.
Jorge
Edmonton, Canada
Jorge
Edmonton, Canada
I've heard that regular gasoline has the same amount of detergent as mid-grade and premium grades of gas too, but the marketers (Top Tier, etc.) claim that they add more detergent to their gas than what the EPA requires. Petro-Canada is a Top Tier retailer.
Is it possible that your CEL went off initially because the gas cap didn't quite seal completely?
I just had one where the CEL would come on only when it was very cold (<40) outside. Turned out the thermostat was partially sticking open and wouldn't let the engine warm up within the pre-programmed time parameter. This was on an 02.
At the present time, I am runnming a tank full of 93 octane so-called "premium" grade gasoline with a 5 - 1/4 oz. bottle of Lucas #10020 Fuel Injector Cleaner and lubricant. It may be my imigination but the engine seems to run better. The engine pinging under load is gone but that may be due to using the 93 octane fuel. My S-10 has 146,000 miles on the odometer and I am sure it has a substantial amount of carbon build up in the combustion chambers and valves, which will raise the static and dynamic compression ratio to the point the engine needs higher octane gasoline. Another reason a high milage engine requires higher octane gasoline is because oil contamination of the fuel-air mixture in the combustion chambers will raise the fuel octane requirement..
In my opinion, using a good fuel system cleaner and lubricant on a regular basis may help soften and eliminate carbon depostis and lubricate the fuel pump in the tank which will delay a fuel pump failure.
If the vehicle is running good, no CEL/SES light on, chances are that everything is okay and the inspection station needs to check out their equipment. There is a small chance that something ate some wires or such, damaging the data link to the diagnostic connector, but I would try getting the system read by another source before going down that road.
