2009 Honda Civic Problems
Lonewolf77
Member Posts: 8
in Honda
Issue 1: I have a 2009 Civic LX-S Automatic with an annoying starting problem. If the car has been sitting in "cold weather" (55 degrees Fahrenheit or less) for several hours, the car will not start the first time I crank it, OR the car will start, and then putter to life, or just die out.
In a brand new car, this issue is quite embarrassing and disconcerting at the same time. Based on the discussions in the 2008 Civic problems thread, it seems as though Honda has supplied oem batteries with insufficient cold-cranking amp ratings. When a battery gets cold, it loses efficiency and tends to degrade in performance. For a new battery to have problems starting in 45-55 degree weather is pathetic. Any thoughts?
Issue 2: From day one the car has "wandered" on the freeway. Not pulling to one side, but wobbling side to side over certain freeway surfaces. I haven't ruled out that it could just be the tires, but I doubt it. Now, the car is beginning to produce excessive tire noise over most types of pavement. I have not noticed excess tire wear yet, but I'm only at 5,600 miles.
I'm wondering if the alignment/control arm issue from earlier 8th generation Civics has still not been remedied. I'm taking the car in for an alignment and tire rotation this week, and I'll see if that takes care of the wandering and excess road noise. Once again, any thoughts?
Issue 2 I am not experiencing
2009 civic ex auto
Issue #2 Honda seems not to be able to correct "production and supplier issues" from model year to model year even though the problem is known and a service bulletin has been issued for a quick fix. So, it wouldn't surprise me that the rear control arm problem still exists in 2009
I have an '06 Civic and the alignment issue was a problem then. There were several complaints on this forum. My tires wore out at 15,000 miles; my dealer said that it was out of alignment. Later after I paid $1000 for a set of Michelins, I read about the problem here. Surely by 2009, they have fixed this problem. We are talking about the third year of this design. I just finished looking at the thread on the 2008 Accord with vibration problems. I also have an '05 Accord and it has been the best car that I have had. Maybe, Honda is not making the car they did.
Here is the latest update:
Issue 1: The starting problem still persists. I had the dealer check the battery, and it checked out "ok," and within spec. No surprise there, I just wanted to create a paper trail regarding the issue and bring the issue to Honda's attention. I don't have the luxury of leaving the car at the dealership overnight or for a few days while they try and replicate and diagnose the problem.
I have found that when I turn the key to the "Acc." or "On" position for a few seconds before I start the car, the car starts on the first try, and the hesitation or stumbling is greatly reduced. Perhaps this is a problem with the tune being too rich, or an issue with the coil pack then???
Issue 2: I had the tires rotated but Honda was hesitant to perform an alignment on their dime since the car "felt normal." The car still exhibits wandering tendencies, and now with 7,600 miles, the tires seem to be more worn than they should be. I have Continental ContiProContacts for the record. The road noise isn't as bad after the rotation, but I have a feeling by 10,000 miles it will be. The next time I take the car in for service, I am going to demand an alignment; I have a feeling that will put this issue to rest.
Now I'm frustrated! I thought this was only a "cold" weather starting issue??? I'm now considering it could be the starter, coil pack, or tune...Any input?
By the way, the two biggest problems people are having with the 2008 Civic are the exact two issues that I started this thread with; see the NHTSA complaints database and select "2008 Honda Civic."
See link here: http://www-odi.nhtsa.dot.gov/
http://www.teirney.net/civic/KnownProblems.htm
Time to see what happens when I go to the dealership...
The car does not have difficulty starting as long as I turn to the accessory position for a few seconds before trying to fire her up. But, if I try to start her up in the morning without doing the aforementioned procedure, the car has a really hard time starting. I'm sure that the main fuel control relay is the problem (per the link); and I will request that it be replaced once I have more evidence, or I have more time to argue with my dealership.
I am having the same problem with my 2009 Civic. At first it was in he cold weather so I wasn't too concerned, but when it got nicer out, I knew it wasn't the cold weather doing it. It's at the shop today and they called and said nothing is wrong. I told them to keep the car overnight because sometimes it does it after sitting for a while. Have you heard any other new info about what this could be?
alz79
Even with the weather getting better, it seems that this problem will not go away on its own for me either.
From the link in another post, the problem may lie with the main fuel relay. Apparently, this problem has affected older Civics as well.
As long as I turn the key to the "accessory" position on the ignition switch for a couple of seconds before I start the car in the morning, the car starts just fine. I just think that a modern, new car, should not have to have this annoying procedure done to start in the morning.
Honda won't do anything about this issue unless we make a fuss about it; I suggest taking a few minutes and filling out an online complaint form at the nhtsa website here: http://www-odi.nhtsa.dot.gov/
I got my new 09 civic coupe,MT about 3 weeks back. I'm a first time buyer, I some how have this feeling that the engine is making very loud noise. I have noticed this sound even after it is completely warm. I dunno if this is common issue in Civic.If would appreciate if anyone can throw some light on this issue
Sweety
My A/C is not really cold either. Not feeling comfortable at all, with the weather in chicago in the last 2 days. This is Not the ICE Cold A/C I would expect from a brand new car. I also have a 2009 LX-S. Love the car, but the A/C is not great! Please let me know if you take the car to the dealers or somethign and what they say.
-mark
You know what ... that kinda sucks! with this no improvement in 3 years. because it really would push me into a different automobile....
its going to be a long summer in chicago... =(
Last week went on a 2 hour shopping trip. When I went to start the car - it was dead - just a click - had to call roadside assistance.
I have Sirius Satellite in my car - they said it causes serious battery drainage - I contacted Sirius (I had the radio professionally installed) and they said they never heard of such a problem. My boss never unplugs his and he has had it for 3 yrs.- frustrating to say the least. Not impressed with the service at my Honda Dealer might go to another dealer. Seriously thinking of trading it.
Any thoughts on my problems would be appreciated
Wasn't complaining too loud. Just reporting on my experience. Heck, my Chevy's AC worked crappy for a long time, until the garage (Jennings) finally figured out there was a Tech Bulletin on a defective (from the factory) part in the AC system.
I bought this Civic for the daughter, but I've been driving it to work at night. I really like it. .
There are four Civics in our parking lot on the graveyard shift. We've been comparing notes. One SI, one LX, one EX and mine (LX-S).
Have a great day!
Hopefully this will help y'all...great a/c in my '06 LX.
The Sandman :shades:
2023 Hyundai Kona Limited AWD (wife) / 2015 Golf TSI (me) / 2019 Chevrolet Cruze Premier RS (daughter #1) / 2020 Hyundai Accent SE (daughter #2) / 2023 Subaru Impreza Base (son)
I bought my son's 2007 Accord SE at AntrimWay, and now my daugher's 2009 Civic LX-S there. Their service department has always treated us fair and well. One of their service managers was GREAT with us when the wife and I surprised our son with a wing spoiler on his Accord for a graduation present. He gave us fantastic attention, and helped keep it a surprise for our son. I think he was as excited about surprising our son as much as we were.
I also have another beef with Honda (this is my FIRST Honda purchase). The way the windshield and rear window are placed makes it IMPOSSIBLE to clean the inside of the window all the way down! I'm a female with medium sized hands and can't get my hands past the hump on the driver's side! Same thing with the rear window and the brake light.
Is Honda behind the marketing of the "Windshield Wonder"???
The Sandman :sick: :shades:
A few months ago (between February and April) I was having trouble with starting the car. I never really gave an update... sorry! So, I was told that it was normal for the car to take up to 15 seconds to start. I think that is ridiculous, but the repair guy read it out of a book. It had trouble starting when I dropped it off. I was standing right there, and they said, "oh - is that what you're talking about?" so we all knew it happened. Then after three days, they said there wasn't a problem, so I took it home. It had trouble starting one more time in April, and then never again. I have it documented, so if something else happens, at least they'll know that it wasn't the first time.
Credit to Rt.23 Honda in NJ and American Honda.
BTW, the dealer also replaced a defective trunk release--yes, it is a new 2009 Civic and was made/assembled in Canada.
I know once or twice I forgot I hadn't started it yet and put it into drive with it off...hopefully making that mistake two times wouldn't hurt anything?
Any idea why a brand new car would already be having issues starting in the middle of summer? Could it be a certain type of gas (I don't always go to the same station). I haven't taken it to the dealer because I was waiting for my first oil change/service appt.
I bought an 09' Civic LX in July. It is an automatic. The car has ~450 miles on it thus far, and I have begun to notice something-the transmission often seems a bit 'jerky', especially when switching from first to second gear. This is also very noticeable when the car isn't warmed up; the first gear change of the day is the worst. Yet I feel like there may be something wrong with it. I used to drive my parents' 04 Toyota Corolla and I seemingly noticed that that car's gear changes are much smoother. Is this just the way the Honda transmission is designed?
I read somewhere that Hondas are meant to be driven with a 'little bit more medal to the pedal" than other cars if you know what I mean. Likewise, when I drive more so like this the gear change seems to be smoother. I am curious as to whether or not anyone else notices that the transmission is a slight bit jerky or has trouble making up its mind? Maybe I'm just being overly sensitive and worried that something is wrong with my brand new car! Just for anyone that wants to know- I drive my cars very easily. I rarely gun it (only if I have to!) and I always make complete stops when changing gears.
Please help me put my fears to rest!
Yes, my car also does the downshifting when I break. It's kind of annoying because you can feel it very well. I also agree about accelerating quickly after a stop- it's almost like the car is straining itself. Could this have anything to do with the i-VTEC engine? Mind you, I really am not smart about cars. Well, if yours does pretty much the same things as mine I'm assuming that's just how the civic transmission is. Do you have an automatic or a manual?
Just a couple of hours ago I parked my car and I was messing with the window for 10 mins before it went up right. I had to pull the window up too.
i was reading that previous civic have the same problem too. its the regulator that causes the window to go off track.
Does anyone else have a wobble in the car at high speeds? I bought my Civic in July, it has 2200 miles on it, and I've been pretty easy on it. Sometimes when it gets up to 70-75 mph, it wobbles, almost like there's gusts of wind outside. I'm baffled by this! it's brand new!
also, when accelerating, does anyone else sometimes feel a clunk in first gear? Not every acceleration but randomly?
What is wrong with my brand new car?! I bought it with 9 miles on it!!
Once I pulled up on the window and thought that was the secret, but no such luck trying it after that.
I'm over 41,000 miles now, so slim pickins on warranty work unless something big under the hood goes out!
The window doesn't come back down on it's own anymore , or it was half way to be more accurate. It has started to make a slight squeek or squawk on the way dow, but not all the time. A bit worrisome, I just hope it keeps working as I don't want to spent any money for something that is exactly the reason I bought this car instead of a European car.
I am happy with the Civic, as the 41,000 miles show!
