Nuf said.
Nuf said.
How would you know you never owned one or drove it long enough to make a fair appraisal!
Don't you own a Maxima?
" lack of computer-controlled rev-matching makes for abrupt downshifts. The system also won't downshift until engine revs are at a ridiculously low rpm, a frustrating experience if you're trying to have some fun with all that power on a twisty road." Not a good.
"Beyond the noticeable body roll, the Sonata's electric-assist power steering feels artificial and offers minimal feedback from the front tires." Not good.
"Heat soak was fairly significant." Not good.
"The steering has less than favorable feedback, with an artificial-feeling boost. Understeer on the limit gets progressively worse if you try to over-drive it. ESP breathed off throttle to bring the car back in line. Slalom: With ESP off, the slalom was an exercise in front-wheel-drive oversteer. Slow in, fast out kept the rear in line, and steering smoothness was key. It's easy to get behind in your turns due to a slight yaw delay, compounded by the loose tail. ESP was fairly intrusive when pushing the Sonata hard -- but we found out why!" That is a bad chassis.
Again, I would look elsewhere if you want a sporty type sedan.
http://www.insideline.com/hyundai/sonata/2011/2011-hyundai-sonata-se-2-0t-full-t- est-and-video.html
If you are looking for a true SPORT SEDAN ala BMW, etc... the Sonata is not your ticket. However.... if you are looking for a SPORTY and Economical alternative to a Camry, Altima Accord, etc.. then the Sonata is good to look at. If you want firmer handling check out the SE.
I came from an Infiniti G35, and traded it on a 2011 Sonata Limited. Of course the Sonata won't out run or out corner the G, but it has very respectable road manners.
I'd put the handling in the middle of some of my previous cars. Better than my 2009 300M, and a notch under my 2001 Infiniti I30t. I'd say equal to or better than the 2001 I30 without the touring package. (Drove those as loaners several times)
Bottom line.... a very good car, but of course it's not a sports car. Some people hear TURBO, and assume that.
Also.... interesting to note.
2011 Sonata
Edmunds rating = 7.8
User rating = 9.3
2010 Maxima
User rating = 9.1
Sometimes people who are fans of a certain make, like to make negative posts regarding other cars that compete with their favorites.
I find it interesting that the editors of Edmunds find both praise and criticism of both cars.. and amazingly the ratings of both are pretty similar.
The engine is smooth and it mates well to the transmission that's obviously geared towards fuel economy. Nevertheless it kicks down to a lower gear quickly when I stepped on it a little harder. The engines is darn quiet when driving around town, nearly silent, but it might be masked by the road noise caused by the terrible road conditions where I test drove the car.
The acceleration impressed when I had to pass a minivan at about 30-35mph, I got up to 60mph with the pedal only down half way. I didn't really punch it hard since I was only driving around local streets. This isn't a sports car but it will definitely help me merge on the freeway with ease.
I've only test driven two turbocharged cars before, the Volkswagen CC and Saab 9-3 Aero with the 2.8L V6. The turbo Sonata isn't as explosive as the CC, probably because of gearing but I think I can get more out of this setup on a day to day bases. The Saab had nothing on the Hyundai and VW, all lag no fun
2011. Hope this helps!
Nuf said.
So ... don't buy one.
Thanks so much for playing.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Only you can decide if you really need the turbo, but here is a little perspective.
Here are the performance specs for my last few cars, and the new Turbo:
1999 Chrysler 300M 0-60 mph: 7.9 seconds (253 HP)
2001 Infiniti I30t 0-60 time: 8.5 sec. (227 HP)
2003 Infiniti G35 0-60 time: 6.5 sec. (260 HP)
2011 Hyundai Sonata 2.4GDI 0-60 time 7.7 seconds (198 HP)
2011 Hyundai Sonata Turbo 0-60 time 6.5 seconds (274 HP)
So... While I miss the G35 a little from time to time, (and amazingly, the new Sonata turbo is similar in acceleration specs).... the performance is more than adequate when merging onto freeways and other similar situations.
Also the Sonata 2.4 is faster than the other cars I have recently owned , and the more I drive the 2.4 GDI, the more impressed I am with the performance.
The fuel economy is a nice bonus too!
What could explain the lower freeway mileage on the turbo motor
Thanks..
The point is displacement plays a much larger part of fuel economy with concern to city mileage than highway mileage especially in percentage terms.
I would like to hear what the rpm level is at 70mph for each engine though. Also anyone who has driven both, any comment on engine noise under heavy acceleration or at highway speeds?
The only negative is that the bass can cause the door panels to rattle if turned up too high. I initially had the bass set at "+2" when I first got my Sonata, but have since turned it down to "+1" as it was causing the door panels to rattle too frequently.
For a standard stereo, I would rate it above average.
Intuitivly, tire noise seems more likely.
2011 Sonata Limited with Navigation package. It has currently around 6400 miles on it. TMV price for that trim is around $26600. Dealer's quote for the demo vehicle is $25500. Firstly, Is it worth going for a demo vehicle that kind of mileage?
Also, I was thinking it'd be a good deal if priced around $23500. Please advise.
did not take my rental car to work the next morning I took the new car. Well late as it always is I went to depart work and bingo no start! Called Hyundai 800 number (is this a new car?) and had car towed. Dealer Service Manager called and was great said it was most likely the brake interlock start switch and would have it ready next day. I had to depart on another trip said no problem, no hurry see you after the weekend on Monday when I get back. Monday I picked the vehicle up and Dealer Service Manager said thank goodness I didn't pick up the car that next day because it wasn't the brake switch. They had to trouble shoot the system and it took the day. They checked battery, OK at 14.4 Vs, brake switch light switch, OK, and checked ground wires and found them OK. The issue for the no start problem was they found the 40AMP fuse for the ECM lose causing the failure. They removed the 40AMP fuse assembly for the ECM & adjusted the male pins on fuse and the car started right up. All systems checked fine and problem solved. I have only drove the car twice since the problem was solved. It was to the airport and back. The other night returning from my trip I walked to the car looking good it did but was wary it would not start. It started! So far so good but only three weeks into the new ride.
Love the car but until I get a few more starts.... completed ...... I push that button with my eyes closed and fingers crossed. A month plus into it and so far so good..
