Need Fog Lights on Hyundai Santa Fe 08 GLS
Hi! Any one have installed the fog lights on the Hyundai Santa Fe GLS? I recently purchased an 08 Santa Fe. When I called the dealer ship that I want fog lights they said GLS does not come with the Fog Light Assembly so now I can not install fog lights, I have have to get it when I buy the vehicle.
I did check out some fog lights they were in the range of $40 to $60 + Tax. Do I need any special wiring kit or I can use a common one for the Fog Lights. Also will need any specific tools to do this job? I think I'll need more help from you, I'll mail you the details once I get the fog lights. I am thinking of getting Keystone fog lights.
Read your earlier reply. I ran into a similar problem and it is still with me. I found a set of OE fog lights online at partstrain. Problem is getting the harness and switch to set it all up.
Tried Pep Boys, 2 locations didn't know what I was talking about. Hyundai says it can't be done.
Would you happen to have a part # for the Pep Boys harness and the Hyundai switch?
Thanx
I'm nervous about taking the fuse box appart to due a OEM style hook up, not knowing what I will find and what trouble I could cause.
A little help would be nice befor I go any further. Thanks!
I just bought a 2009 GLS and I also want to install fog lights and was told by the Dealer that it was not wired for it. My question is where can I find the Harness and lights?
I got my switch at Hyundai and my OEM lights on line. Some have talked about getting wiring harnesses and the wiring lugs at PEP Boys but they didn't seem to be much help at the store I went to. Finally got the small lugs at a different PEP Boys store. I Got small spools of wire at local auto stores.
Some folks say you can go into the fuse box and set the lights up just like OEM
but I'm not willing to risk the warranty. So I'm doing it what some call the quick and dirty way.
Others in this forum are helping me and I'm sure they will do the same for you, again look at the posting and if you have a specific question, I will try to help.
Joma1
I had started this post originally I wanted to install fog lights on my 2008 Santa Fe GLS by a Hyundai dealer only. BUT FINALLY I DROPPED THE IDEA.
U see the things is when u go to the dealer he takes ur VIN and then looks for the part numbers which if u have GLS will not come but if he knows what part numbers to order and if they are willing to do it then u can get it.
For me it was very costly it was costing me about $800/- which was not really worth, considering where I live (New Orleans) we hardly have foggy conditions over here, and I did not want to do it at PEP boys or any other shop cause after learning the amount of work involved I did not want to spoil my warranty (which is one of the reason I bought Hyundai), so I decided to play safe.
With Regards
Parag M.
Where did you connect the wire from No3 hot when on? Sorry but it didn't seem clear to me. I do appreciate the help you have given.
Thanks in advance.
http://www.hyundai-forums.com/index.php?s=&showtopic=32845&view=findpost&p=26636- 0
For do it yourself 2007+ Santa Fe fog light install. I have the part # for the foglight switch to match a gray interior. Just call your local Hyundai dealer and ask for foglight switch to match your interior color.
I removed the front bumper to install OEM fog lights.The lights install with two screws, There is a Right hand and Left hand light. I found ground screws on either side of the radiator frame and tied each light to its own ground useing #14 wire. I ran a number # 12 feed wire from passenger side fog light and tied it to the wire feeding the driver side fog light and continued the wire run through a protective cover that I slid down behind the driver side head light to the engine compartment.
Make sure you have spots available in your fuse box also get the wiring kit from the dealer and F/L Pigtail. I do not know part numbers for 2007
I just got a 2010 santa fe and am looking for the cheap way to score OEM fog lights. I was'nt sure if you said yours were OEM for 49 a piece. Could you set me up with all the info. to purchase the lights, wiring kit w/ plugs (if needed) and switch. Cos Thanks
