Isuzu Trooper Oil Consumption
i have a 99 trooper with 120k and is using alot of oil between changes.what brand and weight should i use to try and help.what about oil addatives like lucas oil stabilizer,sea foam,myster marvel oil?or any other suggestions or recommendations?thanks.
I have a 2002 Trooper with about 85,000 miles which is burning quite a bit of oil, about one quart every 1,000 miles.
What causes this? Is this common for the Trooper? Is there anything to do other than to keep adding oil? An automotive parts shop recommended using an oil conditioner? Do these oil conditioners work? Is there anything else I'd want to consider that is not too cost prohibitive?
Also, does driving at higher speeds for an extended period (a road trip) burn oil faster than when driving at normal speeds over shorter distances? I just drove about 400 miles back and forth between two cities and seemed to burn oil faster than normal.
SUVs and Smart Shopper
Can u tell me little more in details on how the dealer determines that a new engine is require ?
I never go over 65/70 in any SUV or truck. The suspension is not meant to handle any emergency at those speeds. Try riding in the passenger side, lay the seat back and shut your eyes while someone else drives down a 10 mile straight of interstate at 70 or above and you will see what I mean. And I replaced the shocks with great shocks at 25,000 miles.
I asked mechanic if this affects him in any negative manner and it looks like the mechanic loses on labor. I don't understand how because it is not mechanic's fault but I did not go through more details as it is between Isuzu and dealership. At least it helped understand why they didn't want to give me the replacement.
I know there are very few people who can use this warranty because for most it is more that 10 years of ownership. I bought it late in the model year therefore I still have some time left.
Meanwhile, my dealer diagnosed my transmission a couple weeks ago (I was having trouble accelerating after a stop), found metal shavings in the fluid, called Isuzu (without any prompting on my part) to see if the powertrain warrantee was still in effect (it is), and arranged for a replacement, no charge. This is how a dealer should respond.
Having said this, I'm really disappointed in this iteration of Trooper (I've owned three). Replace the engine AND trans before 83000 miles? Now I know why there is a 10 / 120000 warrantee.
One more thing...dealer service adviser told me that it is going to be a factory rebuilt engine. I was surprised as I know no-one in Isuzu factory is re-building engines anymore. I called Isuzu and they clarified it for me (and also called the dealer and clarified it for them) that this is a brand new engine. New engine also comes with a 12 month 12K mile warranty. Apart from these issues I really never has any other major problems. EGR valve gets clogged but that is an easy cleaning job. I am wondering if there are any other typical problems I should get checked before warraty expires in a month or so.
