Here's a current auction for that manual:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&cate- gory=34233&item=2452348776
I think I may be onto something. I was trying to change the way the door locks when the transmission is put into "D" -- it locks the doors. According to the manual, we have to press the power door lock one way or another for 5 seconds to change that mode. To change it to unlock when put into Park for example. I had tried this again (in vain) on Monday night, and immediately after starting the engine, the radio was froze. Power off and restart reset it.
I know that I've tried to change the way the locks work in conjunction a few times in the past and I'm beginning to think the two are linked.
How about you? Did you try to change the way your locks work around the same time as the radio froze? Seems like a bug in the computer program.
BTW, If anyone can explain exactly how the door lock automatic function can be changed, it would be appreciated. I followed earlier posts to a "T", but no luck. Tried with no key in ignition; with key in column, but not started; key turned to accessory node; and lastly with the engine running. All efforts fail. Either my computer system is hooped or I'm missing some simple step. Maybe it's time to visit another dealer.
Chris
I'm also looking for a dependable, experienced service center in the New York city area. Anyone have any experiences with good Toyota service centers? My original dealer is about 75miles away and I wanted to find another dealer closer to home if possible. Thanks.
-km
basic question: if i have an 04, is the 03 manual the one i need?
thanks again
It's tough to find them discounted much new, as the markup on them is apparently lower than most parts.
kscott, I think very little has changed in the vehicles between 2003 and 2004 model years, so the changes in repair manuals should be similarly slight. If they've wrapped the V6 info into the main set of manuals and done away with the supplement, that may make the total cost lower for V6 owners.
BTW, it seems that Toyota doesn't actually produce these manuals themselves. They contract with a 3rd party company for the writing and production of the manuals, and then everybody (including dealers) buy the manuals from/through this 3rd party. My guess it that it allows Toyota to shed the whole writing operation and employees, and shift the cost. Now the entire cost of writing repair manuals is broken out from the cost of designing the vehicles, and this is why these repair manuals are so expensive.
This has occurred a few times. I don't want to jam on the gas out of fear that the vehicle will just rapidly accelerate and I may hit something.
Any ideas?
See your dealer, that is a warranty item. I wouldn't attempt a fix yourself for such an important safety feature. Does the belt 'grip or tighten' when you start the car and 'release' you when you turn it off? That is part of the SRS system working.
Any ideas?"
My '02 did it and my '03 does it sometimes. It is really noticeable at between 10-30mph, like in a parking lot. If you drive up to a speed bump, slow down, roll over and then press the gas to accelerate, the engine races and the vehicle doesn't move to the speed in conjunction with the RPM's. Kinda like it is gear hunting. I've written it off as Toyota specific. Same scenario as in the morning the tranny will hold 1st gear longer than usual to warm up the emission equipment, irritating, but Toyota typical.
Also, the 4th generation has a 'learning' transmission. Meaning, the tranny will develop a pattern, or mean, of your driving habits and corresponding speed, RPM, etc. If you vary your driving habit, it takes the tranny some time to learn the new style of driving.
for 5 seconds (press on driver lock button, pressing towards rear of vehicle) and the radio did lock up again! I was in a bit of a hurry, but I don't think I had the ignition turned to ACC.
I've written to my dealer to see what they can do about this.
It will be interesting if others, who also had locked radio controls, would try this theory and report back.
Chris
Anyone know a good service center in St. Louis?
And for what it's worth, I had my first oil change done at 1000 miles, and then again at 5000 miles, etc. Finally, at every 3000 mile interval I'm adding a ~23 ounce bottle of Chevron Techron to a tank of fuel, in order to help keep the fuel system and injectors clean.
I went out to the garage, popped the hood and my V8, 5spd. build date, 02/03, 4Runner has a transmission dipstick about one half inch to the left and rear of the engine oil dipstick. Both dipsticks are coated yellow, the tranny dipstick has the typical locking mechanism on the handle.
Maybe you don't have a transmission? j/k
I read somewhere, about a year ago, about the new 4Runner not providing a way to check your 5spd. tranny oil. The new Ford f-150 has a new transmission that never needs the oil changed, so if Ford has that technology, anything is possible with Toyota leading the automotive manufacturing pack.
The tranny dipstick was so obvious that if you don't see one, I'd call your dealer to run a VIN check and verify you don't need to check it. You'd hate to inadvertantly burn up the tranny by lack of maintenance or observation of fluid quality.
(It is the JBL 10 Speaker system)
At -8, wouldn't you hiss too? Might be a startup power surge causing the semi-frozen speaker element to rattle and hiss? Battery is working hard at -8.
Mine was delivered like that! That grey moleskin fabric headliner is a moisture, stain magnet. My biggest complaint in the vehicle.
BTW..the dealers in NC are worse. They actually do malicious body damage to your car when you decline an estimate and the car is in their possession for the estimate.
Anyone in the newyork city are have any suggestions on a reliable Toyota service center? Thanks.
-ken
Any ideas of similar experiences? thanks doct
The only other thing I can think of is something to do with the brake master cylinder.
"On". It sure beats the 6 speaker POS that was in the EX Honda Odyssey I traded in on the 4Runner. It beats the old 1MC system. too.
pat84 - shellback 1974.
Jeannine Fallon
PR Director
Edmunds.com
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
I've experimented with the bass to set to five, tryied different fade settings, turned surround on and off, but my results are mediocre at best.
I've complained to my dealer about this, I get the usual "it's normal" reply.
If you can find "Low Rider" by Eric Burden and the group "War" play it and crank up the volume. It is a good system test. Actually, the Black Watch Pipes and Drum Marches are good system tests, too. High volume is appropriate for the Black Watch, too.
My system passes both tests.
It is what it is...why would the dealer be responsible to do something about a radio that is not broke?
By the way, I wrote a very detailled letter to Toyota Head office regarding the NUMEROUS problems I have had with this vehicle (still under 14000km on it) and they told me that they were not prepared to do anything about it. I advised them they would lose a high end Toyota customer forever and they did not seem to care one bit. Nice. Just today I sent a similar letter to the dealership hoping to get a more suitable response (not holding my breath.....).
Remember, Toyota drove the new 4Runner to Mt. Everest....and back.
Thanks again.
Before I made the final decision to buy a new 4Runner, I visited Toyota's web site on many occasions, and I paid close attention to the section that provided a list of the local dealerships, which in my case can be found here: http://www.toyota.com/toyota/LoadDealerSearchResults?expand_butto- n=collate&forwardToTemplate=/html/shop/dealers/results/dealer- _results.jsp When I then clicked on each of those dealerships, I saw that Toyota Direct has won Toyota's President's Award for the 4th time, and along with their strong "word-of-mouth" reputation, this honor really caught my attention.
It seems that many of you have perhaps bought your vehicles from a dealership that offered you the lowest price, and if that dealership subsequently proves to have lousy service, you may then begin taking your vehicle to other local dealerships in the hope of finding better service. While this might be a good strategy in some cases, keep in mind that your vehicle's service and complaint history (as well as a given dealership service center's invoiced comments, etc.) are recorded and documented in a database that will follow and track the vehicle's history, regardless of which dealership service center you next choose to do business with.
I've learned from prior experience with Ford dealerships that regardless of the validity of one's complaints about a vehicle, the act of repeatedly bouncing from one dealership service center to the next (in search of satisfaction and good service) may lead to the creation of a service and complaint history in which certain "red flags" might be subtly implied about the OWNER of the vehicle, rather than about the vehicle itself. In other words, the more we hire-and-fire various dealership service centers in our search for satisfaction, the more the service database might covertly or overtly paint us as being unreasonable, insufferable, and undesirable customers who seem impossible to satisfy.
As I said in message #9071, I'm fortunate to have a dealership that has thus far offered outstanding service and customer CARE and ATTENTION, but I also agreed to pay this dealership a higher price for my '03 4Runner Limited. Among those of you who've had to endure Toyota dealerships that don't seem to give a damn about you or your vehicle, I hope you can find a better dealership to do business with.
I'm saddened to hear that many of you are receiving shoddy service and care from your local dealerships, such as receiving your vehicle back from service in a filthy and/or damaged condition; or being told that an obvious problem is "normal" and nothing can be done; or feeling as though you must write a letter of complaint directly to Toyota Customer Service, rather than being able to rely on your chosen dealer's service manager to be an advocate for you when it comes to appealing directly to Toyota for help.
When a tsb is issued for a problem, they issue it by the vin#, if your vehicle falls into that range, and you experiencing that problem , then they will try to correct it. Toyota does not perform tsb's after the warranty for free. It is not a recall, that is a totally different animal. It states very clearly on Toyota's tsb's they will only reimburse the dealer if it is still under the manufactures warranty. I have access to toyota's official tsb's if anybody needs info.
I then stopped by the service center, described the problem, and the first thing the service advisor did was to check the 4Runner's TSB files. He said he's not yet received any TSBs on this issue, nor had he yet heard of this problem until I mentioned it. He offered to take my vehicle in for service and to put me in a loaner vehicle right then and there, but I said I'd rather wait and see if the problem reoccurs before proceeding further.
I've otherwise been quite pleased with my vehicle's audio system, which I believe is one of the better stock systems currently available. I listen to a lot of public radio and AM, and I find the radio to sound quite good. I'm also very pleased with the sound of the CD/DVD player, tape deck, amplifier, and speakers. My truck's sound system has thus far been very quiet (i.e., no obvious hiss, amplifier hum, speaker buzzing/rattling, etc.) and it sounds very musical and non-fatiguing, with great dynamic range, transient response, stereo separation, and clarity. The DVD/CD player is quite musical as well, without the annoying hardness, obvious digital "clock-jitter", digital clipping, and edginess ("digititis") heard with lesser CD/DVD players.
The premium sound system's speakers and subwoofer seem to do a very good job of resolving and reproducing the low, middle, and high frequencies; and the critically important midrange frequencies seem especially well reproduced considering that this is, after all, a car/SUV audio system.
Chris
Anyone else notice this? I know many people have complained about the lack of ground clearance and the raked stance. Maybe I am seeing things...
