Jeep Liberty Oil Pressure Sending Unit
Our 2004 Jeep Liberty has a problem where (usually when cold) the low oil pressure indicator will illuminate but when you shut off the engine and restart it will shut off. Is this a problem with the sending unit sending an incorrect code? Or maybe the oil pressure could be low? I'm seriously thinking of getting a gauge and testing the pressure. I know low oil pressure can mean BIG problems. I don't want to know about engine bearings being bad. But I know when I change the oil it takes a few seconds for the new oil in the pan to get to the crank because the engine ticks a bit for a few seconds. I've even tried putting oil in the new filter to "prime" it and it still seems to do the same thing. I don't like to hear those noises when I change the oil probably causing some unneeded wear. Any help would be greatly appreciated. -Rick
- either the ECU does not change the status of the "at pressure" bit (low probability) and sends an engine malfunction alarm,
- or you may have a leaking check valve (oil filter bypass) that lets the pressurized oil return into the sump via the pump after a few minutes when the engine is not running.
The absence of oil film normally explains the ticking sound of your engine but if you use mineral oil that is at the end of it's life, the engine will produce the same sound. This is a typical 4 stroke lawn mower engine issue: my wife doesn't know there is oil in there, she just pushes the thing
sump * pump * check valve-&-filter * engine
when the check valve cancels the filter you may get:
sump * pump * engine
I think the time and pressure needed for the oil to circulate backwards through the filter is long enough to give you a noise free start even after a few hours.
Just had mechanic replace oil pressure sensing unit and still have the problem.
Some of you have mentioned a "switch" - is there a switch that bypasses the oil filter on startup to get oil to the engine immediately?
Since the light goes off on an engine restart (every time) I don't worry that much about it - but it is a nuisance.
TIA!
Guys. I Have the answer to solve this issue
1 of 2 things is wrong. 1: the connector to the oil sending unit/switch is faulty. Or 2: need to flush or clean the sludge with kerosene/ engine flush. These videos will help you solve problem. If not these two issues then it’s oil pump or engine crankshaft is worn out. Best of luck!
https://youtu.be/q-B-MJXLi-A
https://youtu.be/n1nb1HYsZG8
https://youtu.be/lTmkK1Xjovw
