2008 Mercedes Benz C300
cville3637
Member Posts: 7
I bought a 2008 Mercedes Benz C300 and I want to know if the dealer warranty covers paint chips on the car.
Any comments...?
Ive taken it in for this particular issue. They said they sanitized the ac...
Ive brought it into dealer and they replaced the driver side one and it started making noise again.
P.S.
If not a Merc can you make a suggestion on a diesel that would get the job done?
2008 C-300 Luxury ...from time to time, I get this 'red' message that one of my tires is losing air. I cancel the message (OK botton on the steering wheel) and check the tires visually and they all look good. Further check shows that front and back pressure is correct at 2.8 & 3.0 psi
Anyone has similar a problem?
Yea the mirrors make noice ...occasionally when they fold .... never when they unfold.
Our 2-year-old c300 has only 11,000 miles. We are due for another service (first oil change was a year ago at 5700 milies) .... what is service B1? I see in manual A1 and B2 but not B1.
i took it they did an ac flush. they tell me its normal because of the mold, mildew and bacteria in the air.
my fellow benz owners I know have not experienced this. i never had this problem in previous cars.
one friend say they had to replace something in the dashboard.
is this information true
is it possible the noise is being caused by feathering - it's like a "whirring" noise
can the same size tires be put on the vehicle so that the new tires can be rotated and extend the tire life
will a lesser tire i.e. not as soft have the same, shortened life due
what are our options; does anyone have some anecdotal advice, idea, suggestions
I'm a little more than frustrated and annoyed at the prospect of having to drop $1k a year in tires, but shame on us for not doing better research when purchasing the vehicle if that is, in fact, the case.
Thanks for any and all advice you can offer.
Every so often, it smells like BO and only when I turn the air on. It's not me and I haven't spilled or cause that smell.
A friend of mine had the same problem. She said after numerous attempts they were able to fix it. I will ask her again to help diagnose the problem correctly.
Sorry you have that wretched smell. It's not right. I agree with you. All the money for a stinky car....hmmmm
Try turning off the A/C for a few minutes before you get to your destination. (Keep the fan blowing though...) That should dry it out, and stop or slow down the smell. It's not a great solution, but maybe you won't have to smell it while MB figures something out.
Good luck!
The 2 years I've had it, and especially more recently, this chemical/exhaust/I have no idea smell has been coming out of my vents with the AC on. My hair, clothes, planner, coat, SKIN smells all the time. Last week it started to give me headahces.
The dealer has had it 3 times the past week or so - redid the entire ventilation system, etc. SAME smell.
DISCOVERY:
Yesterday the OWNER of the dealership checked it out with me. He agreed 'chemical' smell. I said 'maybe the glue?'
Once I said 'glue', his ears perked up and went RIGHT TO MY FLOOR MATS.
Fliped them over and OH MY GOSH THEY ARE TERRIBLE. It's the smell you are all smelling, but 100 times worse! I have no children, never spilled anything....all 4 mats are omiting a chemical.
The air conditioner pulls air from the 'floor' where your mats are, and puts this air with the good air - through your vents.
It's as if they cleaned the car before selling it, that cleaner got into the 'foam' bottom of the carpeted floor mats, and has been eating it away.
If you have the original floor mats that came with your Mercedes - flip them over and take a smell. You'll have a headache for a few hours.
My trunk - everything has this smell. Well there are vents in the trunk too.
I hope this helps and hopefully IS the issue!!!
-S
DISCOVERY:
Fliped them over and OH MY GOSH THEY ARE TERRIBLE. It's the smell you are all smelling, but 100 times worse! I have no children, never spilled anything....all 4 mats are omiting a chemical. The air conditioner pulls air from the 'floor' where your mats are, and puts thiis air with the good air - through your vents.
DISCOVERY:
Jeannine Fallon
Corporate Communications
Edmunds.com
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Is it easy to remove the multi-function light switch in C-300? Occasionally, the passanger side parking light somehow gets turn on when I move the knob form 'A' position to '0'. I think the switch is faulty. I want to take the switch out and disconnect the wire for the passenger side parking lights. Once those 2 lights stayed long enough to prevent me from starting. Other time I saw the lights on (in the evening) as i was coming to the car .... the know seemed to be in 0 position. I now keep the knob on 'A' or put in A position when I leave the car during the day. Any suggestion would be appreciated.
Best.
I'll ask my service advisor.
There are different levels of Mobil 1 Fully Synthetic Oil....ensure to read the label. There is a code on the back that specifies if it meets MB specs...call the parts department of your local MB dealer and ask...also....it is very difficult to find the recommended weight....normal 5w20w etc does not meet MB specs (for warranty purposes). Although I find it hard to believe that it will make a difference if you change it before the recommended MB mileage....I think they stretch it out too far...hope that helps....Disclaimer: Changing oil intervals is ONLY my opinion.... :=)
