2009 Town and Country - dashboard lights
We bought a 2009 Town and Country Touring Edition on Saturday (five days ago). It was in the showroom at the dealer. We were told that the battery in the van was dead because the doors and lights had been left on. They replaced the battery and off we went! The next morning, we had problems with tire pressure and had to put extra air in each of the tires.
On Monday, I drove the van to work and everything seemed fine. At the end of the day, I went to leave work and the power doors and electric windows wouldn't work, the windshield wipers were on and wouldn't shut off, every warning light on the dash was on and the radio wasn't working. We called roadside assistance and then drove it to the nearest dealer.
The service department told us the next morning that the battery hadn't been installed properly and that everything was fixed. We went to pick the van up that afternoon and the same problem happened. We left the van and have been calling back twice a day and the service manager just tells us that they don't know what the problem is and that they are trying to fix it.
Has anyone had a similar experience? We have owned this van for five and a half days and three and a half have been spent in service. I am very frustrated and my confidence in both the van and the service department are decreasing rapidly. Advice is very welcome.
Was your problem ever resolved. If so, what did they determine the problem was. I too am loosing confidence in the van and the dealer.
Our van is still not fixed. Late last week they identified a broken part of the 'computer' that needs replacing. The parts have been ordered but will take a week to arrive. We are hoping that the part will arrive, that it will actually fix the problem and that we will have the van back by the end of this week (almost three weeks from when it went into the shop). By Saturday, we will have owned the van for three weeks and been in possession of it for about two days. I am quite frustrated at the delay to diagnosis the problem and to get the parts to fix it. I am not feeling especially confident that the problem will be fixed by this repair (although I don't really have anything to base that on other than the mixed stories we have received for the last two weeks and the frustration of not being able to drive our new van). Good luck getting your van fixed!
Deb
http://townhall-talk.edmunds.com/direct/view/.f1ddee4
did you ever get your problem fixed?
I hope you have better luck getting your van fixed.
Today it did it three times in a row. Makes me nervous to drive. I'm going to bring it in tomorrow to get looked at.
Our dashboard problems were fixed when they replaced the entire dashboard. But the van is in the repair shop at every three weeks -- it goes in for one thing to be fixed and comes back with four or five more things broken. We phone and complain and then have to wait for parts (which are always on backorder). Then we take it in only to find that the computer diagnostics show that other things need to be replaced, the parts are on backorder and so it goes. For example, they installed a command start (the only way that the automatic windshield wipers would work) and broke the cruise control when they installed it. When they replaced the defective heating element in one of the seats, they broke one of the side pieces of the seat. The list goes on and on.
We looked at a Sienna before we bought our van and I really wish that we had bought the Sienna. I can't say one good thing about the van or the service we are getting and to be honest, I'm embarrassed that we bought it (and that we spent so much money on it). Good luck - I'm sure your new van will be much better!
Thanks in advance.
Jose
I believe you can purchase just the seal for the sun roof on your 2009 Chrysler Town & Country. You may want to double check with the Parts Department at the dealership you are working with.
Lisa
Customer Care
Chrysler Group LLC
Thanks again
Regards
I went today to the dealership and they double check and the (PC) catalog doesnt show the rubber seal along, only shows the glass and even doesnt show the rubber seal, could be possible that you search in your catalog, for the part number of the seal along?
That would be nice.
Thanks in advance.
Lisa,
The part number he gave me for the glass and rubber was: 68028578AA.
Please help me if you know or can get the #part for the rubber alone.
Thanks in advance.
sorry to insist, but could you help me please?
Thanks in advance
There should be one at or very near each of the 4 corners. They are usually a bit difficult to see, but you can locate them.
The 2 near the front of the opening have hoses connected to them that go down through the A pillars of the roof on both sides of the windshield & drain out through the front fender area and onto the ground.
The rear 2 have hoses connected to them that run inside the channel between the roof and the side body toward the back of the van and then down the side wall and back out of the van in the area between the sliding door & the tail gate.
A length of flexible wire run through them, followed by water then compressed air should unclog them and you should see the water draining out onto the groud from all 4 hoses. If the hoses come disconnected where they attach to the sunroof drain tray it sould appear as a water leack inside the van onto the carpet some where in the area near the disconnected hose. Be very careful when forcing air through the lines because if they are packed solid with debris it could force the hose ends off where they connect & cause interior flooding.
Hope this helps you out.
Again thanks a lot.
Regards.
Does any one have a pic of the underside drain of the back hoses? If I locate them, I will compressed air through them and maybe that unclog that BACK holes.
Thanks to all.
Thanks for posting your comments and info, and I hope that the problem is solved, time will say.
BTW the only thing about 2 vs 4 drain holes, could be that the van was sold in Mexico and maybe they are different ????. IDK.
With an scanner you can find some codes about tranny?
Are there any other thing to do?
Thanks in advance
JA.
Regarding your original question: "Does this mini vans has transmission dipstick?"
All four–speed transaxles are equipped with a conventional filler tube and dipstick.
Lisa
Customer Care
Chrysler Group LLC
Thanks Im going to look for the filler tube and check the oil level first. Thanks a lot.
Chrysler Town & Country/Dodge Grand Caravan Discussion List
KCRam - Pickups/Wagons/Vans+Minivans Host
"Click here to start a new thread if your message is not a reply".
So I dont know what to do: the fact its that the van sometimes works as normal and sometimes the tranny seems to slip, so IDK; thats the reason Im asking here the possibilities that are producing the issue.
Thanks again.
The correct discussion to add your questions is this one: Chrysler Minivan Transmission Problems
Go to the last page of that discussion, and add your post at the bottom. The members who are following that discussion will be far more likely to see your posts and give you a hand.
