Town Car window motor problem
99towncarexec
Member Posts: 160
Every so often my windows stop working,including the moon roof in the 94 SIG SERIES.Anybody have a clue what this could be??I just got the car a week ago.
When my 94 Sig had your problem, it was solved by installing a fresh and more powerful battery. If we don't drive it frequently, I put a charger on it every two weeks.
If you do your own battery installation, remember to use a terminal cleaner on the posts and cables & install an anti corrosive lube too.
Any ideas?
fuses are good.
When the drivers door control works but none of the other door switches do, check the remote safety cut-out switch on the driver's door that shuts off all the other door switches on the other doors. May be OFF or a bad connection where its plugged in.
Single windows inop? This issue has come up on my 99 Cartier. The left rear window only worked when it wanted to, I guess.
Took it in to the Dealer for a PM and asked the write-up guy about this ONE window (inop - but up at the time).
He went in the bump shop and came back with a rubber mallet. Struck the inner bottom frame of the door ONCE a good lick, while I held the button for down, and it started working again????????
Friend at Fords here in Dearborn told me if the window wasn't used very much (I called the previous owner and Aunt Barb actually said she never remembered using either rear window AT ALL since new) there can be a film build-up from humidity on the comutator (copper bars on the armature of these permanent magnet motors that the brushes contact) and will cause no contact. Once it was working again the Dealer guy told me to run the window up and down a few (25) times to wear off/clean off this corrosion.
He COULD have sold me a motor replacement.
It has been working ever since, but I do run them up and down twice a month anyway.
Terry
Wtg
The guy struck the door with the rubber mallet where -- on the metal below the panel?
--Tom in Ohio
