Anyway, the noise happens whether the car is moving or not. I took off the serpentine belt and the fan belt and started the engine. Same noise at 2500 rpm. If I speed up or slow down the engine then the noise goes away.
Any ideas? Thanks in advance.
Winter problem. I had a door handle snap off this year. Stupid me for yanking on a frozen door.
I can sympathize with you about the broken door handle. I live in northern Maine, and during a period of -40 temps this winter my grille shrank and the chrome began to blister; and the driver's side scuff plate split when a friend stepped on it trying to give me a boost. Plastic isn't made for sub-zero weather!
The black plastic lumbar (if that is what its even called) that holds my softtop in place broke off. Tracker parts are hard enough to find as it is, so it may be needless to say that I have had no luck in finding a replacement.
To give you a better idea of which part I'm talking about exactly, it's the black plastic bar where the top of it holds the softtop so it is firmly stretched snug against the metal (closest to the moon roof)
Anyone know where I can find one of these?? I checked all over the web with no luck.
My glovebox handle also broke off, if anyone knows where I can buy a replacement, please let me know
Thanks all!!
I agree with the others - you should have the transmission serviced or at least the fluids dropped and refilled. I recommend a complete flush and new filter and modulator valve if it hasn't been done. Fluids should be changed at probably 75K miles.
You can easily check to see if you're frozen in the power mode by turning it off and seeing at what rpm on the tach it shifts from first to second under full acceleration. Ten turn it on and check again.
My 2000 Tracker 4dr with the 2.0L 4 now at 117K miles is one of the very best vehicles I've ever owned and I've owned a few good ones.
I do wish they had never used those stupid plastic "Christmas Tree" posts to anchor on all the exterior plastic. I've been chasing around replacing the missing ones on almost a weekly basis lately!
Tony
LONG STORY SHORT: all you have to do is pull the fuse from under your hood that controls all the lights from your car (that fuse was also in charge of the radio, so I'm not sure if that would pose a problem for you or not) but my AC was working fine.
Otherwise I would say take it to a mechanic if you would really want to have the automatic headlights feature.
Can some give the actual part name for this "pig tail valve"? Tracking it down with this type of name does not make it easy.
Thanks, Bill Colwell
Yes, the 2001 Chevy Tracker does have a cabin filters on the passenger side of the vehicle. The filters are located behind the glove box (aka glove compartment). I'll do my best to explain the procedure for filter replacement. Even the illustrations that came on the instructions with the cabin filters were of little help.
Open the glove box to reveal the compartment. Empty the contents of the compartment to a convenient area. At this point, I consider this initial opening of the glove box to be the "normal" level of openness for the compartment.
To open the glove box to the next level, you need to slightly squeeze the compartment inward (on both sides at the same time) to release the glove box to the next level. At this next level the glove box has swung open to the floor.
Now, look at the area you just revealed from behind the glove box compartment, you will see a metal bar. Just behind that metal bar you will see a narrow plastic cover. This cover is like an upside down "L". It has two protruding "rectangular" type knobs that extent from the long leg side of the "L" cover.
Above the upper knob, (this would be the short leg of the "L" cover) you should be able to get your fingers into the space and pull up on that portion of the cover to release it.
The long side of the "L" cover should be a bit easier to release once the upper side has been released.
Once this "L" cover is removed it should reveal the cabin filters (there are two). The filters seem to be stacked one on top of the other. Replace the two filters with the tab on each filter facing you (the tab on each filter when stacked correctly will slide into the back of the "rectangular" type knobs of the "L" cover).
Replace the "L" cover and make sure it's locked into it's upper and lower positions.
Begin closing the glove box. Remember, you will have to squeeze both sides of the glove box compartment to push it back into the opening and it's "normal" open position.
What engine do you have? I thought all '03 inlines were 2.0L DOHCs. If so, the oil capacity at change with filter is 5.5 US quarts, and 4 liters is only 4.2 quarts. Of course that would be low by a good lick on that dipsick.
Each change with my 2.0L I put it 5 quarts of something-or-other with another can of an oil additive like STP for the other pint. Brings it right up.
The 2.5L V-6 I believe holds 5.8 quarts with filter, or 5.5 L. That, again, would leave you pretty low on the stick with only 4L.
That tiny little oil filter can may hold .5 L but I'm betting it's more like 2 oz!
This little 4-banger uses about a quart of oil in 3000 miles now, but used up half a quart every 3000 when new. Just the nature of the engine I guess.
Thanks in advance!! :confuse:
I don't know anything about cars but what I have experienced, but hope this info. helps. Ronda
It's quiet over there too but lots of people subscribe to that discussion and watch it.
