Nissan Armada Brake Problems
124
  • I was also in need of front brakes as well..was told by someone with same problem that replacing their front brakes worked not replacing booster. I was going to just do that but with my consistant complaining to the dealer they replace the booster (me just having to buy part, no labor charge..$450 mind you!)Still feel un safe since I keep hearing this issue will re apear!!! Front brakes still should have been good for more miles as well.
    Attorney general is my only thought on this with a number of us all fileing complants
  • I had that problem and it is the brakebooster.
  • I had the same brake problem with my 2004 Armada except that my brake would lock up on me when warning lights would appear. It didn't matter how fast I was driving (5mph or 80mph) when warning lights came on (I usually wouldn't notice it) and I used my brakes, they would lock up on me. Initially they reset computer and that was only a temporary fix.They did replace my rotors though. There was a recall on those so pursue it. I eventually traded in my 2004 Armada for for a 2008 Armada and mentioned nothing about my continued issues to dealership. I was told that the only way that they could figure out my problem was to witness the activity while the problem was active (it happened periodically without any rhyme or reason). That was highly risky considering the consequences. My son was just born when I decided to trade it in. I didn't want to take any chances. The 2008 model is heaven on earth. Good luck
  • binzlbrew,
    I just bought an '06 Armada 40 days ago. While driving at speeds of about 35-40 also had the same symptoms that everyone else is talking about on here......question, did your breaks actually "lock up" and tires skid to a stop, or did it just have the crunchy noise that others share in this blogg?
    I took ours to the Nissan dealership today and spent $75 to have the tec look at the computer....he said the reprograming of the computer was already done (prob from previous owner). So I was told that it could continue with the same problem as all other Armada owners on here....My wife just wants to make sue they won't lock up on her and skid to a stop like you wrote.
    Thanks for your input.
  • Please go back and read my VERY FIRST post. I was driving on I-20. going over 70 miles with kids in the trucks. i had my digital camera in the car and taped my trucks brakes going out. Several times. I think i went to NISSAN 7 different times. But the cake was me CONTACTING NISSAN CORP and CARMAZ CORP. if your break light comes on and its early enough to take it to the DEALER take it.. do NOT turn the TRUCK OFF.. keep all the receipts of you going and contact the corporate office. make them aware that you belong to a group. a group of people that all have ARMADAS that all are getting a LAWYER and will be trying to get a CLASS ACTION LAW SUIT. i did.. They replaced my computer. I've had my truck for 3 years and I haven't had an issue. I even get calls from NISSAN and CARMAX checking on me to make sure that the car is doing okay. If you give up and don't keep pushing the fact that you fear for your safety.. Which is NOTHING BUT THE TRUTH. then they don't take you seriously. What we need to remember is that NISSAN can replace parts and their trucks.. but we can't be replaced. I wish you all the best!
  • I never did state the brakes locked up. The brake light went on and they grinded and pulsed to a stop. Not full braking. Like the power brakes went out and I had to really push the pedal down to stop. Mind you I was only in a parking lot when this happend thank goodness. Not sure how the vechicle would have responded at a higher speed!
  • i have armada 2006
    i have the same problem
    The brake light comes on while driving. I have to turn off truck and turn it back on to reset break light. If I use brakes when light is on the brake does not work good , It makes a springy crunching noise when brake is pressed
    I am doping my kids to school every day in my car , Anyone have a solution to my problem please post it ASAP
  • ritz23ritz23 Posts: 4
    My husband recently replaced the brake booster and we had the back rotors turned. The truck is running great. I hope this helps.
    More info can be found on the following thread
    http://www.youtube.com/watch?v=bmtpofDbJR8
    Hope this helps
  • I have Armada 2006
    i ma in Saudi arabia - Jeddah
    i Hve the same problem
    please nay one can help how to fix it
    regards,
  • It is fixed!!!!! 2 days ago my brake light came on suddenly and it made this noise everyone is talking about. I immediately called every dealership in town who all told me they never heard of this problem. The next morning it happened again while the car was parked. The light came on so I tried to reverse and sure enough. It then happened like every hour
    Anyway, called a friend of mine who told me that when the light comes on it is triggering the ABS, that's the noise you here. He was right!! Found one dealer who knew off the back what it was. He said it was the booster. They put it on the machine and the code for the booster was in there! A few hours later and a new brake booster and I am good to go.
    ******He said that this is not common in the 2008 Armadas but he sees it all the time in the 04-06 models!
  • I have an 08 Armada that did the same thing. Light went on, ABS kicks in and the brakes start grinding and shaking with almost no braking power. Needless to say when I turn the car off then on again it is fine until it happens again. None of the dealerships said they ever heard of this. But after a mechanic friend of mine told me it was the abs engaging, I called another dealer and told him this "the brake light is coming on and it is engaging the ABS". What do you know he said he knew right away what it was. They replaced the brake booster and it runs great! He did say that although this is not common in the 2008 model it is very common in the 04-06 models. Oh, and when they put it on the diag machine, the code for the booster was in there. It seems that on the older models the code does not store and so the dealers have no clue what it is.
    Go figure
  • I have been dealing with this problem w/ my 05 Armada for over a year.
    I brought my car in the dealer 3 times, the first time w/ the grinding/bake light/ABS problem I spent over $1,200 for new rotors and brake pads. A few months later the same grinding problem occured, I towed my car in the dealer again, but they could not find any problems at all specially when they have records of the new brakes work done. The third time it happened on the freeway and it nearly cause an accident. I took my car back again, all inhouse mechanics there could not figure out what the grinding/noise/brake problem was with my car, except when I'm about to pick up my car, the guy at the frontdesk said the computer shows that I need to replace the brake boosters...! He laso said, if it happens again, pull over, turn off the engine, and restart after a few minutes to reset the boosters, but it is a temporary fix and that will not solve the problem until I replace the parts. He said it will cost about $850...!
    If you have replaced these boosters, please verify that $850 is for 4 boosters or just the 2 front wheels.
    I am planning to have a petition for all you Armada owners to sign. I believe this problem warrants a recall from Nissan.
  • I have a 06 Armada and this brake failure just happen to me. It's Sunday and the Service Department at Nissan in San Diego is closed. Thanks for your post. I'll have them check out the brake boosters. Do you know if there is a recall on this problem?
  • Yes, I have the same problem. I bought my 2006 Armada used from a local dealer in my hometown. Less than 3 weeks after I purchased the vehicle my Brake, Slip and VDC Off light came on in my vehicle. When I pulled up to a stop sign to stop, my brake pedal went to the floor and I had very little breaking ability. The noise was a grinding sound as well as the pulsating in the pedal and the steering wheel began to shake. I took it back to my dealer and they investigated and told me that the brake pads for the Armadas were made to small and that it was causing the problems. Needless to say, I am a single mother of two and I cringe everytime that light comes on for fear that one day I will not be able to stop and my babies will be in the vehicle with me. I have done alot of research today here on Edmunds on this issue and see that we are not the only people with this problem. I like yourself took my Armada to the local Nissan dealer and explained the problem and like you, they looked at me like I was insain. I was told that my vehicle would have to be acting up for them to be able to pull the codes and see what the problem is. I just had new brake pads put on my Armada less than a month ago and last Sunday it happened again. I would love for someone to enlighten me on what the actual problem is with these Armadas so I can get mine fixed. Any information would be greatly appreciated.
  • I want to be on that petition. My Armada scares me to drive it sometimes as I have 2 daughters that I would just die if something ever happened to them. Please let me know when this petition becomes available.
    Amber
  • jrustjrust Posts: 2
    I have had a 2 year struggle now with the dealer about my 2005 Nissan armada. The first time I had the brake issue wAs in 2010. Same exact description as yours. Except I was so frightened by the incident that I couldn't articulate the details you did. If you have further details please advise. My car was in the dealer in 2010 and then again this march 2011. Both times huge issues with brakes going out. They replaced booster this last time. I felt a similar feeling last Friday and because I'm traumatized I took it to the dealer. After 3days, they couldn't replicate the problem. Driving home today, the grinding funny feeling started. If anyone out there has been successful in repairs, Please contact me. Please. Mrs.rust@yahoo.com
    I feel validated by this website. The Nissan dealership made me feel like I was crazy. Even after my brakes locked/ slipped and I ended up in the middle of an intersection. I was towed to the dealer and they said my brakes seemed normal. My 2005 armada had huge brake repairs in 2010 and again. In 2011. I've replaced booster. I don't trust my car anymore. What should we do?
  • steverstever Viva Las CrucesPosts: 51,098
    Please don't ask for "personal" help via email. We all benefit when a problem is discussed on the open forum. Thanks.
    Moderator - Buying questions? Please include city or zip code and trim you are shopping, FWD or AWD, etc.
  • I am so sorry that you are having this same problem. I did have the brake booster reprogrammed back on 2007 for around $800 at my local dealership, and no it was not covered by the extended warranty I purchased from them when I purchased the car. I did not have the problem again for about 7 months and then it started up again. I had no luck with either Nissan dealership they both acted like I was a stupid uneducated soccer mom who is paranoid. I was frustrated with the the issues I was having so in 2008 I traded the vehicle in. It is unfortunate that a large company has no social conscious and is knowingly endangering the citizens of this country and does not take responsibility for a problem they are well aware of to save a dollar. I will never purchase a Nissan again and have wrote this off as a costly experience, but feel safer driving a different vehicle.
  • ladywtrkladywtrk Posts: 1
    Hello all, I hate to sound like a broken record, but I truly need some help with my issue. About a week ago, my 4 year old daughter and I were backing out of a parking space and all of a sudden, i heard this exteremly loud noise, and the brake light came on. I also heard this grinding noise and it scared me sensely. I stopped in the middle of traffic and after panicking, I just turned the truck off and sat there. When I started the truck back up, the brake light went off and I finished backing up. When I put it into drive the noise came back and the brake light came back on. I went through the same procedure and after sitting for about a minute or two, I started the vehicle back up and it ran fine. it hasn't happened anymore since then, but after reading some post on this forum, I have a feeling it will be back. What can we do to fix this problem. I just paid my vehicle off and I have no desire to trade it in and start over with car payments. Is there a solution? :(
  • amber78amber78 Posts: 4
    I can assure youbthe problem will continue. For no rhyme or reason it just happens. I have been around and around with Nissan about this problem. They refused to pay for the break booster to fix my Armada. Their defense is my vehicle is out of warrant so they have no obligation. All I can tell you is good luck. Nissan is aware.of this problem with EVER 2004 to 2007 Armada and Titan but the refuse to make it right. I will be selling my Armada very soon. It's a death trap. I'm afraid to put my children in this vehicle for fear I may not be so fortunate the next time around.
  • We have had this issue with our 2006 Armadaon and off for about a year. Last week the same car started stalling randomly so we searched these foums and decided to ask the mechanic about the brake booster while it was getting looked at for the stalling. Interestingly, in these forums we also found info about the stalling and specifically asked the mechanic to look at the IPDM (Integrated Power Distribution Module). In no time they had it hooked up and replaced the engine control module relay. We then asked them about the braking and they said the two are related and that this would fix it as well. ?? Something about the vdc thinking the car is going downhill because of the engine...not something I can explain but I'll keep my eyes open for the brake issue. OH YEAH, it was a recall so Nissan picked up the tab. :) Recall PC068.
  • nisrjznisrjz Posts: 5
    I read all these posts about the Armada's ABs and Brake malfunctions, which are similar to the postings on the Nissan Armada.com Website.
    The bare facts are:
    1. Nissan knows about this problem from many, many owners.
    2. Nissan is not interested in fixing this problem or they would have by now.
    3. Nissan obviously doesn't give a hoot about your safety, your wife's safety or the safety of
    your children.
    4. The dealers can't or won't fixt the problem. They continue to do things which they know don't work. I have a 2004 Armada, one of the original. It has had this ABS and brake problem on and off for 9 years. I have written to Nissan USA, brought it to various dealers and complained to the National Highway Traffic Safety Administration (They have a web site where you can e mail your complaint).
    In my opinion, not enough Armada owners file their complaint in appropriate places. If all armada owners would file a complaint with NHTSA, as above, maybe they would order a recall and then Nissan would HAVE to fix the problem.
    My other suggestion, which I have made, to no avail, to other Armada owners is to join me in bringing a Class Action Lawsuit, on behalf of all Nissan Owners similarly afflicted, against Nissan USA and the manufacturer. I happen to be a Long Island Attorney. I would be willing to commence the prosecute the suit, if the fellow owners would pitch in the share the Court costs and disbursements with me. My fee would be paid by Nissan if we win the law suit.
    When I make this suggestion, it would appear that most Armada owners would rather rave about the problem on line, then go back to the football game on TV. Nobody appears sufficiently serious in bringing this matter to a head by making Nissan either fix this problem to pay damages to the owners of the defective vehicles it sold to Armada owners, with knowledge that the vehiclesl have this very dangerous defect.
    So, unless you guys all get serious about this, stop putting these posts on line which are more than copious by now and become redundent. In all fairness, I have been reading these posts since I bought the Armada in 2004 and not one posting owner has thought the problem serious enough to do something about it.
    Thanks for listening. Nissan must love the "sheep" who purchase their defective Armadas and do nothing.
    NISRJZ
    Sir, you are so right about everyone taking action, but nobody does - they just like to rail on line and go back to the football game.
    You may think your problem is fixed by rotors and brake pads, but that is not the problem. The real problem is in the ABS system, which actuates when it is not supposed to. Nissan knows this. They supposedly reprogrammed by ABs controler, replaced a sensor for the ABS and performed a recall on a switch/relay in the engine compartment, but the problem persists--worse than ever. Then the dealer took it back and tell me it needs a new brake booster. I asked the service writer " What does a brake booster have to do with the ABs coming on randomly" - His answer
    was " I don't know...that's what the tech says". Perhaps he should had the "tech explain this to me", but no such effort was made. My usual local mechanic says it sounds like hogwash to him too.
    Owners afflicted should join in a Class Action Law Suit in Federal Court.
    The lawyer's fee will be paid by the defendant if we succeed.
    Filing fee disbursements would have to be advanced by a few of us, however.
    If anyone is TRULY interested in solving this problem once and for all, instead of leaving your family's at the mercy of Nissan's inaction and probablly endangering their very lives, I would suggest you get in touch with me and we can get the ball rolling.
    NISRJZ
    edited October 2012
    And two or three years later, if you win, you get a $500 coupon off on a new Nissan.
    If you really want action, just go to small claims court. But no one (much) ever does that either.
    Meanwhile if the recall didn't fix the problem and there's still a safety issue, owners should contact the NHTSA.
  • I have filed a complaint with the BBB several time. Took it to the shop and the so called specialist that came in for my specific case said it needed wheel sensors. Even though I have done all the research and told them that is not the problem they insisted to replace them. As they did free of charge. Less than 3 elweeks later the problem happened again. I contact Nissan again and the BBB as well as Nissan Consumer Affairs. I have exhausted ever effort imaginable with this vehicle and I have gotten nowhere. The last time I took it to the shop I drove it to them will nearly no breaks so they could get the code. The code is pulling I need a break booster. Well duh that what I have told them all along. So when they wet back to Nissan Consumer Affairs with it. Big shocker they denied Fixing it ad said my vehicle is no longer under warranty. Well no sh** Sherlock. My vehicle is an 06. Like it would still have a manufacturers warranty on it being 6 years old. I have been fighting this battle for 3 years now and still nothing. I am however on a class action suit with an attorneys office in California. I just want it fixed period. There is no guarantee that the break booster will fix it an i for one do NOT have 800 dollars for the part and the labor with no guarantee.
  • My saga started nearly 90,000 miles ago, and has finally resulted in them conducting a "Technical Bulletin" to reprogram my PCM--only $90 out of my pocket--in addition, of course, to the $110 "Minimum Diagnostic Fee"...My service advisor is also talking about either the brake booster or the master cylinder as well, but I have news for him there...Has anyone else had the PCM reprogrammed, and did it work for you?
  • Sir: Good for you. Let me know what court the class action is in, if indeed you have filed it.
    Meanwhile, the brake booster is a routine they go through to get you to spend money. I refused to do it, and my mechanic agreed. There is nothing wrong with your brake booster...trust me. Get it checked out with another mechanic.
    When I refused to do that, I took the car back and went to my gas station mechanic....he put the car on the lift and found that it wasn't even the ABs acting up this time....the brake pad had come off its mounting plate which was clashing with the front rotor. Also he found a broken spring on the same right rear side. I got new brake pads, new rotors and two new front springs. Cost me $1200. but at least the right this was fixed. This was after Smithtown Nissan on Long Island gave me a checklist stating they performed a "safety check". They put my life in danger by writing up a phoney "safety check". Nissan owners out there, learn from my experience.
    NISRjz
  • Dear Datsun man. They reprogrammed my ABS controler. I have not had a problem in the six months since, but that doesn't mean anything because this problem, of which Nissan is definitely aware, is sporadic...I have been dealing with this since 2004. Write the National Highway Transportation Safety Administration....they are online. The more complaints the better.
    Put it in the public records so some smart attorney can pull it up when someone is badly injured because of this. In fact, even better, send a letter about it to Nissan USA in California, certified mail, return receipt request and keep the letter and the return receipt so you can give it to an attorney if you hear about an accident because of this problem. Keep them in a place where you can put your hands on it in the future.
    All of you Armada owners should do this. Form a database of letters sent. Someone should organize this and have it ready so anyone hurt can sue Nissan USA and succeed.
    Do yourself a favor. They use this problem to suggest you pay for
    ridiculously repairs which have nothing to do with the abs problem, and they know it.
    Get as far away as you can from any Nissan dealer. They are not honorable..all the way to the top management of Nissan USA.
    Get rid of the Armada when you are able and never buy a Nissan product again. Vote with your dollars and your feet.
    The Japanese just are no honorable people. we knew it in WWII and it is still the same way. Don't do business with them.. Their cars aren't so great anymore and US cars are better...wake up, all you jerks like me who bought a Nissan.
    Nisrjz
  • This is a scam with the brake booster. Get the booster checked out by a reliable mechanic NOT connected with Nissan. I'm betting there is nothing wrong with your brake booster..Please look elsewhere...Nissan dealers are useles and they make ineffectual and unneeded repairs...I didn't fall for it, but wised up. Read my other postsl NISRJz
Nissan Armada Brake Problems - Page 4 — Car Forums at Edmunds.com
