Nissan Armada Brake Problems
13567
  • ljg2ljg2 Posts: 1
    Hello, I have an 04 Armada, brakes went out 3 times (separate events) on my wife while she was driving on the highway, it's at the dealership right now, their telling me they can't duplicate the problem, 3 weeks ago when it happened, they said it was the Master Cylinder and they charged me an arm and leg to replace. Brakes went out again 2 days ago (6/2/09).
    Did you get any resolve, please share so I can follow suite, thanks. Anyone else with recommendations please join in (name of a good lawyer is also welcomed)!
  • shopinfulshopinful Posts: 47
    We have a 04 Armada too and had it in the shop for a while after our breaks went out a few times. We gave them one last chance and believe it or not they fixed them. It wasn't a break problem after all...it is an electrical problem. There is a fix out there and make them check out the fix in the electrical and computer area. It has been 3 years now and we haven't had any problems sense. Hopefully that continues. :P
  • drcurbelodrcurbelo Posts: 3
    Hey, did the upgrade work? I have had the same problem just started about 6 months ago but it happens rarely. If you didn't get any resolution and need a good lemon law attorney contact www.normantaylor.com they represented me against Dodge and I won all my money and then some.
    I used Norman Taylor & Assoc. against Dodge and won pretty easily.
  • Does anyone have the same brake issues with their '06?
  • mzswannmzswann Posts: 5
    :lemon: i have a 2004 ARMADA, when purchases in MARCH it only had 43k miles on it. i have taken it to CARMAX and to NISSAN on Several occassions to deal with the ABS system shutting down. At first they told me there was nothing wrong, I was mistaken,. If the ABS light didnt come on. then it wasnt the ABS.. Then They made me aware there is a ABS MEMO and the computer needs to be reset. I will tell you that my computer has been reset 2 times since APRIL. Just recently the system went out and I called NISSAN on the phone and asked them...while riding what to do. Because it was 5:45pm and i was 30mins away from them and they closed at 6. The service man told me to pull over.., I am like,, HELLO no brakes,.,. easier said than done.. So.. finally i get the car to slow down. I pull over and he instructs me to turn the car off.. I do so.. when this happens. The light goes off and the brakes start working again.. The computer reset itself.. this is the only solution that they give me.
    so i guess i need to find someone that has had the system replaced and how they went about doing it.. i love my truck.. but I LOVE MY LIFE MORE!
  • vhypevhype Posts: 1
    Yes I have an 06 also, took it to them today for the same problem. Charged me for diagnostic test and said I need a brake booster, but going by what I have read on here it's very common. Seems to me this should be a recall item that Nissan should be paying if not all at least 80% of.
  • paisanpaisan Posts: 21,181
    Sorry to hear all the issues guys. My 04 has been working flawlessly. Even had to tow my 11,500 lb boat trailer about 200 miles with no trailer brakes when they died on me and the Armada actually stopped all 16,500lbs!
    I did notice that when my pads went low that I started getting an ABS and Brake lights (forget which 3 they were on the dash but more than just the usual brake light that comes on when the pads go low) and once I swapped the pads to new Akebonos they have been fine since.
    -mike
  • I have read through alot of the problems that the Armada's are having with the brakes and I find it very hard to believe that some of the dealers and reps are okay with telling people to pull over and reset it by starting the engine again. How many people have to get hurt or worst yet die before Nissan bites the bullet and does a recall to repair all of these issues. I am sure most of you know that these vehicles were not cheap and we should be getting a quality vehicle for the price we paid. If anyone has had the reprogramming and has not had any issues, I'd love to hear from you.
    Mike
  • well yes it did happen. more than once.. however, since my post NISSAN had taken the responsibilty and replaced the ABS system.. and it only took from APRIL - SEPTEMBER to get it done!! CARMAZ also volunteered to fix the other issues. So my truck has been okay for the last month. PERSISTANCE is KEY.. ifyou value your life that the PRECIOUS CARGO you ride in your TRUCK., dont give up until its been taken care of. I dont know how many people it will take for them to take care of it.. BUT we shouldnt have to almost die or kill someone else to get help.. THANK GOD i didnt.
  • What procedures did you have to follow to get Nissan to take care of the problem? I have the same issues and would like to expediate the process as much as possible, Thanks for your help.
  • Hi. I took the Car to NISSAN and CARMAX several times. I called NISSANs corporate.. and I called CARMAX corporate. Within 1 day BOTH corporates called me back.. Both asked me for copies of my receipts. Both told me that someone would call me back within 24hours. NISSAN was first. they told me to call dealership and make an appt to get the ABS fixed. You have to call the corporate and let them know whats going on. You will have to prove how many times you have had the issue and they should help you out. I hope that this helps you.
  • titan8titan8 Posts: 41
    I have a titan truck 2004 and let me tell you I had my share of warp rotors, front and rear, mainly fronts, Nissan covered me up to 75,000 miles and now on my own, so I did alot of research on brakes and bought the slotted/ dimpled rotors for the front and rear, and semi metallic pads, I only have 200 miles right now on these rotors so time will tell. I had a very hard time removing the rear rotors and found out why-- The emergency brakes shoes ( both sides) came unglued---bonded pads-- and made a deep grove in the rotor/ drum making the rotor very hard to come off. So if anyone has a hard time removing the rear rotors, your emergency brakes shoes are wiped out. also make sure you replace all parts for the emergency brakes,adjusters, clips etc.
    I tow an 11,500lb Cigarette Boat trailer with my 04 Armada. I have 65k miles and replaced the rotors once around 30k with OEM Rotors and Akebono Pro Act Ceramic Pads. So far at 65k miles the pads and rotors are fine. I did upgrade the pads and rotors and braking system on the boat trailer to discs from drums which helped a bit. Otherwise though I've had good luck.
    I never suggest doing drilled or dimpled rotors due to it creating weak points in the rotors.
    -mike
  • I have an '05' Armada and had the ABS brake issue, I took it to the Nissan Dealer. The first time they re-set the computer. The second time they tried to do the same thing and I said I was in already for that. They called technical support and had to order a new brake "booster"/box. We were leaving for vacation the next day and she told me that it was "unsafe" to drive the truck, apparently the first time they didn't care?
    They said the part was about $1200. I have the extended warranty, not sure if it helped or not with only having to deal with it twice. Good Luck
  • jdmmfjdmmf Posts: 1
    I love my “Night in Shining Armor” silver Nisson Armada 2004 SE 4 wheel drive w/ off road pkg. It looks great and drives comfortably and safely here in the hills of Hanover, NH, if you invest in good tires like Dueler Revo P265/70R18. You must rotate tires and change oil every 3,000 miles religiously. Inside seats v. comfortable. Carries 8 people including driver with small storage in rear. I have versatile middle row that flatten or half flatten and a 3rd row that flattens for large flat bed carry all. 6 DVD changer is great. Cloth seats clean up better that optional leather. Great cup storage.
    I had the same problem with the computer which was fixed and charged for with the 60,000 mile maintenance service $443. I hope the problem is fixed as my warrenty expires after another 4,000 miles.
    Now for the really bad con’s: brake rear and front pads/rotors replaced v. often.
    Wears out tires too soon, v. expensive for both.
    City mileage advertised as 14 mph/ highway 18 mph. I averaged 11 city/13 highway. Very disappointing!!
    After use of 4 wheel drive or low 4 WD seem to have problem with lights on for repair. Brake rotors recalled but still v. frequent pad and rotor replacement. Power steering leak and transmition leak at 58,000. Make sure to get everything on the warranty checked before the warranty Expires. I was lucky the that a replacement of the manifold ???? , stated by the service manager as a $2000 repair was caught and repaired before warranty expired.
    I would buy a 2012 Armada again if the gas mileage was lower, and the brake/tire replacement needed less often. The dealership could give
    discount coupons for replacement of brake pads and rotor all around
    if they could not correct the extreme wear in the 2011+ Armadas.
    If the manufacturer could not lesson the tire wear, the dealership could
    include discount for owners that agreed to buy the best tire (like the Dueler
    Revo) with 3,000 mile rotation mandatory. If the price for the tires were
    comparable to the cheapest available price this would be a great incentive to buy Nisson Armada.
    I would buy a used 2004 Armada and take the preventions needed to lower the tire and break replacement expense. This would not be such a great expense if you lived in a flatter area.
    I would recommend the Armada especially if the manufacturer was upfront
    about the flaws and offered discounts for the dealership to use as incentives to the buyers.
  • sandyb3sandyb3 Posts: 3
    In September 2007 I experienced the same brake problem at 33,000 miles with the VDC locking the brakes. Victory Nissan of Macomb County Michigan diagnosed the problem and reprogramed the VDC. Now at 66,000 miles the problem is re-occuring again. Nissan of McKinney Texas upon examination of the vehicle state they can not duplicate the problem and deny any service bulletins on the subject. I will pursue the issue as this is a major driving hazard. Shades of Toyota.
    I believe the last model year for the Armada will be the current 2010 model.
  • We are having the same problems The VDC\Slip\Brake lights all come on and the front brakes feel like they are about to fall off the car. I just had the brake booster replaced at my local mechanic shop and as my wife was drving around on Saturday the lights came back on. I just spent over 700.00 and the problem is not fixed it has to be something electrical now. I am going to bring it to Nissan tommorrow to see if they can check the computer system any suggestions? We love the car but hate the problems that we are having.
    We had our Armada fixed a few years ago. They did find it was a computer problem in the electrical area. They reprogramed and haven't had a problem since! :)
