Mazda Protege5 Hatch Problems and Questions
Are the rear hatches on the 2003 and 2002 P5's interchageable?
Cheers,
Duncan
Cheers,
Duncan
Really? Where on the hatch is the rust occurring?
I've heard some owners mention rust around the Protege5 and Mazda logos. This seems odd as the logos appear to be glued to the body.
Also, when I go over bumps, I can hear a rattling sound coming from either where the spare tire is or somewhere else under the car. Also pretty annoying.
Have loved my car for years otherwise, but these really disrupt the peace of driving.
PLEASE HELP!!
To help narrow the possible sources of the problem: have you tried removing everything from the trunk, including the spare, and then driving around to see if the rattle disappears?
You may also want to check the crevices in the P5's trunk. For example, the rear lamps can be accessed via three circular plastic cutouts on each side of the trunk interior. The first time I replaced one of my rear bulbs I dropped one of the retaining screws into the crevice. I was fortunate to be able to fish it out, otherwise, it would have rattled around forever.
Good luck!
Rattle in the rear:
If there's nothing loose in trunk/hatch or spare tire area, could be rear sway bar links.
Mine rattled driving slower over bumps. Sounded like an empty plastic bottle.
By the time I found someone to diagnose the problem correctly, the fronts also started making noise & needed replacement. Under $300 per pair/axle installed.
Parts store supplied GM manufactued replacements, 1st try. They lasted 2 months. Redid job w/ alternate brand. Still holding after 6 months.
Replace w/ Mazda or brand other than GM.
Good Luck
O15
