99 Subaru Outback front end issues
My 99 subaru outback began grinding type noises in the front end, esp. on turns. The mechanic replaced my front right axle and cvr joint. The car now made a new whirring sound that I assumed was associated with the new parts. I continued to have some slightly different noise issues after about a month or so. so they took it apart again and discovered my bearing was shot so they replaced it and the spindle that goes with it. Following that surgery, my cars wheel made little soft rubber squeaks which I tried very hard to ignore because I am a picky type. But now I've noticed that sometimes when I turn my car sharply, the wheel grabs; sometimes just once, sometimes a few little grabs (small jerks/ like the wheel wants to stick in that direction). The mechanics I am using are not Subaru mechanics, but they're good guys. I'm beginning to wonder if I should've taken it to a Subaru dealer (and hour away) because maybe Subies are compicated under there? I just want it fixed and safe.
For this last one, the "grabbing," I think you may have a differential issue. Does it matter what direction you turn? And, by "sharply," I am supposing you to mean you have the wheels at or near lock in either direction (low speed turns) as opposed to taking curves at a high rate of speed. The sensation of grabbing while taking corners is often caused by worn ball joints. I would expect your mechanics to have caught worn ball joints, though.
For what it is worth, I had 220,000 on my '96 Outback and the ball joints were still in good shape. I did have to replace both front half-shafts (due to CV boot/joint failure); one was at about 125,000 and the other at 144,000.
Look at the fender liners themselves to see if there is any wear.
I had that on my 93 Miata, but the car had been hit twice, so my guess it the body shop didn't put the fender liner is precisely the correct location.
As for the grabbing, I only notice it when I turn right, and mostly after the car has been sitting idle, like when I pull out of my parking place.
New noise; I am now getting the little twirpy sqeak noises like brakes give off. The noise stops when I push on the brake peddle. However, my brakes are relatively new and should not need replacing. Could the work on my wheel and axle have affected my brake on that side?
