Any help?? Besides that issue, I notice a foul egg smell from time to time coming out of the exhaust but I think it's specific to where I get gas. Or is it my Cat. Converter?
Thanks a bunch
Thanks for any info you can give me
I bought a cabin air filter, I removed the glove box and the cover ro show where the filter goes, but for the life of me I cannot find out how to remove the old filter, the directions in the filter box were for an older year, I really need help with this, thanks
I only have 50k on my endeavor however my check engine light came on out of nowhere so I took it to the local autoparts store, (autozone) and they give you the diagnostic tester which you just plug into the side part of the dashboard and it'll let you know the error code. In my case, it was just the matter of tightening the gas cap cover. I guess if not securely fastened, then it'll set off the check engine light.
had that done on mine (2004.5 LS AWD) but didn't make a diff. mine did run better after a flush & fill but it has 55,000
didn't set off ck eng light until almost 6,000 miles later but would not start after fillup and running bad as well as bad gas mileage
What should i try next?
Also, has anyone had their spark plugs replaced (105K miles according to Alldata). This is also around $500 since the intake manifold needs to be removed.
I have a 2008 Mitsubishi Endeavor LS awd with 28,000 miles.
Mistubishi dealer wanter $920.00
