92 Towncar - turn signal inop need help
I have a 92 Lincoln Towncar - Exec series. I am having a problem with the right rear turn signal not working.I replaced the multifunction switch on the column - ( wiper, hi beam, hazard, turn signal switch )since the hi beams wasnt working. The switch fixed this problem. The front turn signals work & so does the left rear signal, the brake lights work, the hazard lights work but no right rear turn signal. Here is what I have done to check things out,I checked the bulbs & replaced them, I checked for ground at the bulb socket, it has ground. I have replaced the turn signal & hazard flashers, checked the fuses.I do know that the right rear turnsignal wire is orange & blue but its not getting power from the switch for some reason. ( to double check to make sure the switch is working I bought another one, that did not fix the turn signal issue ).
I am not an electrical genius by no means but I need some help here. Any suggestions.
