Toyota Echo Climate Control
I have a 2000 Echo and the heater knob Far right knob) that directs the heat to different areas of the car (windscreen, foot area etc) has stopped working. I have taken the cover from around the instruments, but I cannot really see the controls from there. Does anyone know how the knob moves the linkages which changes the direction flow of the heater.
Thanks Dave
Thanks Dave
Thanks for the information, I have only just got round to trying to fix the problem.
I took the cover from round the speedo and could see some of the six clips, I am not sure if I could just pull on the trim panel the same way I took the speedo cover off.
Thanks very much for the help.
The ECHO is one of the best built, best designed cars EVER made.
There ISNT anything better out there. You already own the BEST!
Go to some AC shops (NOT the dealer!) and get two or three estimates for the repair. That should give you a feel for what is needed. Get some recommendations as to where to go from friends/coworkers/family. Maybe it just needs a rechrage, ($$) maybe it needs a compressor.(More $$$)I would also look in the yellow pages under auto section and airconditioning to find a shop.
A full on new compressor repair maight be $1000. If so were it my car I wouldnt hesitate. But it could well be someting cheaper. If one shop says big bucks go someplace else. Go to several until you get sort of the same answer.
Good luck and tell us what happens!
That is the fate of all such cars I fear.
But maybe with the economy going real bad people will come to their senses....
Maybe...
Are you mechanically inclined?
My son has a 2000 ECHO and its nearing 200,000 miles. Bought at 117,000. His method of dealing with noises has evolved into running the car until whaever is making the noise either stops it from running. Or not.
But they might say it will be $1000 to fix it when not that much is wrong.
Do you know any AC shop you trust?
If it was mine I would just pay attention to the noise and see if it gets worse.
If not I would drive it until it does!
gOOD LUCK AND TELL US WHAT HAPPENS!
I got that "chirping" looked at. Turned out to be a loose belt. Got it replaced for $65 at a local mechanic shop. Great deal!
