2010 EX-L side door often doesn't fully auto-close
hondaownerinva
Member Posts: 4
I've got a two week old 2010 EX-L Honda Odyssey in which the passenger side sliding door doesn't fully close all the way.
What happens is that it will attempt to close, get 99% of the way closed, and then re-open. It does it on and off and there doesn't seem to be any rhyme or reason (ie...car on or off).
It closes every time if I push it in at the end (right before it would normally re-open).
Any one seen this or got any ideas?
Just took the van in and the service tech says he didn't do anything and it stopped happening. Although he said he didn't do anything, technically he did push in the rubber seal where the sensors are which might have reset or at least pushed the rubber seal back.
Not sure but it was happening 50% of the time on the dot and then they do "nothing" and it doesn't happen anymore.
http://db.theautochannel.com/db/HondaReviews/safety.php
Bulletin Number: SB-08-055
HONDA: SLIDING DOOR DOES NOT OPEN ALL THE WAY EVEN THOUGH WINDOW IS CLOSED. THE WINDOW REGULATOR IS NOT CONTACTING THE LEVER ARMY PROPERLY, MAKING THE SLIDING DOOR CONTROL UNIT THINK THE WINDOW IS OPEN. *PE
