Infiniti G37 Vibrating rearview mirror
Recently I purchased a 2009 G37x. I see blurry vision in rearview mirror that i believe from vibration, even on smooth roads. It happens from about 78 - 85 mph speed. At below and beyond speeds are doing okay. I went to the dealer's service center, but they said they can't do anything about this. They made me angry when they couldn't solve the problem and asked me to slow down. Has anyone seen this problem at that speed? What might causing this?
If it's just the mirror, try wiggling it by hand and see if there's any play in it, where it attaches to the mount. Usually there's a set screw that attaches it. However, I would be surprised that a loose mirror would have escaped the eagle eyes of your dealer's service center techs .
I have EXACT same issue with my 2010 G37x Sedan. The vibration happens at the same speeds you mentioned (78-85 mph) . Makes checking behind you all blurry.
I can tell you is is NOT the wheels and tires since I have replaced them all with aftermarket wheels and Michelin tires. The same size as original (17").
A 2009 G37x Sedan courtesy car did not have this same issue. We have been told a higher RPM balance system might minimize the affect. The cost was $100+ for all four wheels. Have not done that yet.. have you?
What do we do now?? Any suggestions or progress you have made may be helpful.
Dealer is good, attentive, concerned and free use of a loaner. No complaints with them at all.
This is my 6th Infiniti. Immediate prior one was a G35x; never had this sort of issue.
I've read the vibrating mirror comments but haven't seen one quite as similar as this.
