Acura TSX Electrical Problems
Went to start my 04 TSX yesterday and noticed a couple of strange problems.
1.) The outside temp. guage shows "--" instead of the tempeature outside.
2.) Power door locks don't work on driver side.
3.) Wiper blades don't work on lowest setting.
4.) Nav screen doesn't dim when headlights are on
I restarted the cars a couple of times for a few minutes and got the same result. The one time where everything did work propery, the outside temp. gauge showed a degree. Shut off engine and restarted engine again and the outside temp guage showed "--" and the problems above happen again.
Checked all the "mini fuses" with a fuse tester and they are good. Havn't checked the big ones since it's dark now but any suggestions? Don't think it's the battery because the car cranks up fine and the terminals are free of any corrosion and rust.
Suggestions?
Suggestions?
Irene
_____________________
Car ECU
My car simply looks/acts dead. This happens when I unlock it as well as when it's already unlocked. At first all the lights will come on. Then suddenly the car is dead. No lights. No ability to start it, of course. The remote seems to be operating since I see the red light. After I fiddle with the remote, by pressing the lock or unlock button, all's well. Tonight however, it took a lot of tries including getting out of the car and pressing the buttons, as well as pressing them in the car. This problem has been intermittent, but happened twice today. So I will have to get it to the dealers ASAP. Needless to say, I can't afford to be stranded.
