2010 Fusion 2.5L starting issue
68jcode_stang
Member Posts: 5
in Ford
I have a 2010 Fusion SE with the 2.5L engine. On a few occasions, I have turned the key to start the car and the starter will turn the engine but will not disengage even after releasing the key. I have to turn the key to the off position to stop the starter from turning. The engine doesn't start either. I have heard there is a technical service bulletin, but when I mentioned it to the dealer, they were unaware of any such problem. I have met a few other new Fusion owners who have had the same experience. Has anyone else had this happen and have you had it fixed?
Just to be clear - the continued starting is normal. On the new cars the computer controls the starter after you turn the key. The problem is simply that it won't start.
Are you saying if you release the key the starter should not stop? I have never experience that in any car
BTW, dealers have something they call an "in-flight recorder" that is put on your car and after you've driven it and had the problem, they can dump the data into their computer and it will tell them the state of everything at the time.
They hate using it because there is only one per several dealers. But that is there problem, not yours.
Paul
As to the in flight recorder...never heard of it but I will certainly ask them. That would certainly solve the problem or at the very least prove to them there is a problem. They actually do not believe me !
Thanks for the info. Much obliged, Lorrie
