2002 Outback legacy power outlet problems
cireleahcim
Member Posts: 2
I have a 2002 Subaru Legacy Outback and the cigarette lighter/power outlet is not working. It just stopped. I checked fuses under the hood and below the steering wheel. I have no other electrical problems what so ever. I have no clue what is going on. Can anyone shed some light on this problem for me? Thanks!!!
I need to know what kind of parking brakes my 2002 Subaru Legacy Outback has. Are they a cable system that engage the rear brakes, or are they some sort of brake that is applied to the drive shaft or transmission?
I would have assumed the former, but was told I need to find out for sure and I have no idea how to determine which it is.
Thanks very much in advance.
The 2002 Outback (Legacy based) uses a combination brake in the rear - two completely separate systems built into one assembly. If you look thru the spokes of the rims, you will see that the rear service brake is a disk, as is the front. But if you look closer at the center hub section, you will see that the 'hat' is larger in the rear than in the front. That larger center piece is actually a cable operated miniature drum brake.
So the post above mine applies to 2009 and prior Outbacks.
I'm just trying to ensure that the system is a cable system rather than an "independent" braking system. At least I think that was the term he used.
I understand what your instructor is attempting, but let me say that it is a crude substitute at best.. The problem is that a rear parking brake is not very effective on a moving vehicle. Weight transfer forward means that the front brakes do 90% of the stopping in a normal situation. Even locking up the rears with the parking brake will mean an extremely long stopping distance if the service brake is not applied. If the gas is applied, it would completely overwhelm the rears brakes alone. Worse yet, skidding rear tires can result in a loss of control, with the back end even coming around (oversteer). Lastly, this is very hard on an AWD system. The center differential can take quite a beating if only one half of the brake system (rears only) are applied hard. "Handbrake turns" can be done in snow or ice in an emergency, but again, it is very hard on the drivetrain.
Net: this is a last recourse type of maneuver, and not something you should do on a routine basis.
But I don't want to damage the car in any way and if doing this has even a chance of messing with the AWD, I'm not going to do it.
Maybe I should go rent a car.... :^)
Kidding....probably.
I did the rear brakes on my 98 Forester (drums) and my dad's 02 Outback (disc), but I haven't worked on any of the e-brake models yet.
