Honda Odyssey third row seat opening problem
Few months back my third row seat stopped opening when I pull the strap at the back of the seat. As a workaround I have to pull the strap which is located at the center of seat on the front side. The seat closes down perfectly. The smaller split seat closes and opens fine. How can I fix the problem with the big third row split seat not opening when the strap at the back of the seat is pulled.
Are you referring to the strap that goes from the seat to the van's roof?
If that is the one, I pulled that strap and nothing happened.
Can you please give any more tips?
I would appreciate it..
The strap I am referring to is the one which is on the side of the seat you sit on. It is probably on the vertical side where your back would rest. Just pull that strap and the seat should fold down.
If you know any cost effective solution to this issue, please let me know. I would really appreciate it. thanks
