2005 Subaru Outback Sudden Problem
Hi, this is my first post. I'm feeling frantic! I just tried to drive my car to the store and got just down the drive way when I felt the car shaking and studdering. It has never done this. The "Check Engine" light came on for the first time. I turned the car back up the hill to my house and the studdering got worse. It felt like the car didn't want to go and I parked it in my driveway. Now, I'm not sure what to do-what is wrong? And, do I need a dealer to fix it (an hour away) or someone local? Can I drive it at all? Please help!
I competent local shop should be able to inspect and diagnose the problem.
The check engine light goes off and on, and the shuddering is periodic. Today, I noticed that the shuddering happens when the defogger is on.
I would love to know what this is about, too.
Are you referring to the air conditioner or to the rear window heating element?
A check engine light with increased electrical load suggests a bad ground or corroded battery connections. Have you cleaned the battery terminals?
I have had a similar problem a few times! I have noticed that the check engine light doesn't go on for me, though. It also never happens when I'm driving with a tank that is fuller than half full. Did you ever get it figured out? Would love any help or advice if you got some info from your mechanic. Thanks!
