2008 T&C stalling without reason
sararines29
Member Posts: 1
in Chrysler
I have brought the van to the dealership 3 times, and each time they have been unable to find 'anything' wrong with it. Each time it stalls the ESP light comes on on the dash and the RPM drops to 0. I can't hear the engine die though. My steering wheel will become stiff and difficult to maneuver to the side of the road. It happens if I'm going 15mph or 60. I don't care if if costs a grand to fix, I just want to know what to do!
THANKS!!!!!!!!!!
My 2002 T&C LX 3.3L always idled smoothly and idled at a lower RPM when starting than does the 3.3L on my 2006 Sienna.
I think both of these charges are unresonable.
Any comments...
I have replace the fuel pump and filter that lessened problem, but not a complete fix. When it happens, if I shut off the car and wait 5 minutes it will work ok for a while. Also I can pound on the bottom of the fuel tank that that fixes it for a while. I have switch the relay modules for the fuel jump and auto shut down with others and that did not seem to help.
The mechanic who replaced the fuel pump suggests a problem in the wiring connector. I can wiggle it and that does not seem to help as much as just pounding on the bottom of the fuel tank???
I am going to look at the wiring somemore, any other ideas. It has a mileage computer, I do not know if may the the fuel flow meter in that could be at fault.
The 4th time it happened someone replaced the alternator. For the last 6 or 7 months the car has been running without incident until yesterday. It stranded me again. I had it towed to a shop. I am hoping someone might know what the problem might be before I spend more money fixing the wrong thing.
thanks for your reply Russ
I had the Chrysler dealer examine my car last week. It checks out fine. But the problem has already reoccurred.
Knocking on the guage pod allowed me to get it started just the other day when i had it do the same mess again. The technician said that starting the car more than 4 times unsuccessfully will cause the computer to lock you out, and the car will not start for 24 hours. My son has been talking to technicians and people with this problem on other forums. He says its something to do with the guage pod and alarm system. Even t&c/caravans without alarms or keyless entry have some sort of built in alarm and immobilizer. Its not the BCM or PCM its something that is talking to the BCM and PCM.
I tried hard stops and quick acceleration. It did not stall. The change of the sensor seemed to help with my problem. I thought I would share what I found.
this van runs fine most of the time. it has about 70,000 miles on it at this time. the problem is that out of the blue it will not start. wait a little while and it starts right up but the check engine light is on. i pulled the codes one time and got 2 codes for ignition circuit 1 and 2 failure. reset the light and it was fine for a few days and themn it did it again only this time it had 3 codes. ignition coil 3 failure was also listed. i replaced the coil pack and it was fine for 3 days and then bam. wont start the first 2 codes are back. does anyone have any idea what this might be. i am hoping it is not the ecm but that is a possibility. any help would be appreciated
Got your posting and Im have forwarded you an email with
folks with similiar issues who have communicated their results to me. Ive yet to replace my board, but plan to sometime within the next 6 months. My wife has a new used car to drive, so I dont have a real necessity to do so right now. But a good friend/associate of mine, who does all of my vehicle maintance, works for my local chrysler dealer, he's one of their top mechanics and has also confirmed my issue with one of thier vans as well. Changed the circuit board and fixed the problem.
But if you plan on spending the money, for the BCM,PCM,Battery,starter....etc, do the board first, it's about 420 for the board, plus the labor, or if you can do it yourself, even better. Please, advise how you make out.
Miz
acted up' again for my wife. This time I told her that "it sounds odd, but try hitting the dash".. She said she had the key in the on, but not crankng position. When she hit the dash some of the lights blinked, then she hit it again and different ones blinked, on the third hit she said they all blinked and she then tried to start the van. Tah-Dah, the van fired right up. I am now convinced that it is a dash problem. I was just about the sink 1000 plus dollars into a set of computers for it. I have been checking around for an instrument panel, and might get lucky, possibly a $100.00 part. Just have to find out what years, models fit/match. Or I have a little electronics background, may be able to repair the board myself. I will post what I find wrong with the circuit board when I take it apart. This forum has been a lifesaver. Thanks to all...
Good luck,
Bosch plugs and wires are cheaper from Autozone. has anyone had any experience of these, or other brands. My van is now on 82000 miles and I feel its time for a tune up.
Any info is well appreciated.
On one of my many tows to the dealer, I had my dealer do the same,Clean out all the connections, apply the spray to keep the connections clean. Yet, I still have the same problem. I have not yet to change the circuit board.
mizafer@yahoo.com
It has started all week every time- and then last night it left us stuck again. SAME problem- turn the key, all the dash lights come on but the van doesn't crank or start. It just sits there. After wiggling the gear shifter, opening the hood and hitting the relays (tried replacing the starter relay the FIRST time this happened) and then I remembered the advice on this forum- hit the dash. I did and it started right away.
SO... What does this mean? Has anyone truly FIXED this problem? What did you do? Help!!!
I have a 2000 T&C that will run rough (sproatic rpm), stall at idle when I touch the excellerator and "shutter" when cruising at highway speeds. We have spent waaaayyy too much getting spark plugs, wires, the fuel filter all replaced. Ours has an after market remote starter, the mechanic thought is was that. We had that worked on and again, it worked fine for a couple days and then on a trip to Wilmington, it started acting up again. The earlier threads are interesting about using the valey key to unlock the doors may be linked. My wife has the key fob. I do not. I use the valey key. It only seems to happen to me. Either way, I have over $1000 into this van and it still does the exact same thing. And now, the passanger side window is only working sporatically. I am calling it quicks and getting a different vehicle and this will be my first and last chrysler product!
