New car, Purchase the added security or no?
I just bought a 2011 subaru legacy. The dealer is recommending the added security plan. Normal cost is 564 for the 3 years on top of the manufacturer's 3 years.
He says that if i order before i take delivery, he should be able to get the price to 400 dollars.
Do you think its a good deal? oh if your wondering where i am. the dealers in ramsey new jersey
Also. has anyone had experiance with the added security plan with older subaru's? i just don't want one of those useless plans that doesn't cover anything, or has a zillion loopholes that you only find out when something happens.
It includes roadside assistant, too.
Now as far as buying into a 5, 6 or 7 year policy, it really depends on your luck. Feeling lucky kid? may not need it. Like me? buy as much supplemental coverage as you can afford!!
but the covered parts list is the enginer, brakes, transmission, cooling system, awd, stteering, front suspension, electrical, fuel and air condition
Is it worth it for 400 dollars? or no. piece of mind?
We need to know the exact terms: length (and they all begin at day 1), mileage & deductible.
http://www.subaru.com/finance-center/added-security-plans.html
The one that i am looking at is the Classic Plan
Classic Plan
•Classic plans cover nearly 1000 parts in all major component areas, including engine, transmission, drivetrains, front suspension, steering, brakes, electrical, cooling and fuel systems and air conditioning. Also provides towing and rental car reimbursement for covered repairs.
I am paying 400 dollars to get it. It is activate when the manufacture warranty expires in 3 years. the plan will then cover the next 3 years. ( years 3-6)
100 dollar deductible per visit.
I found this ad from a dealership in Penn on line:
Plan Terms (YR/MILES) with $100 Deductible
.............. Classic......Gold
3/45,000 $246 $360
4/60,000 $328 $544
5/60,000 $442 $718
6/60,000 $564 $872
6/80,000 $840 $1,230
7/70,000 $840 $1,230
All Subaru plans are referenced (year/mileage figures) to begin on the day you buy the car, and from ODO=zero.
So if they are telling you $400 for a 3 year plan, it is either an overpriced offer to cover the difference between 36k and 45k miles (but same first 3 years), or a real sweetheart of a deal that is getting you to 6 years and much higher mileage (either 60k or 80k). It could be, but please ask!! I'm trying to help you here....
98 legacy GT -130K, replaced a/c evap/condensor and compressor, power radio antenna twice, engine oil leak fixed, dealer even got SOA to pay for the timing belt at the time of the oil leak as it was "damaged" by the oil, also dealer replaced several dash bulbs (which are not actually covered), got way more than my money back on this one
02 WRX - 60K - lost money on this one, though they did replace leaking fuel lines, but that issue eventually became a recall item, also replaced rear view dimming mirror/compass
06 Tribeca- 60K , still have another year of ext warranty to go, have had bushings, and control rods replaced so far under the ext warranty- I was just out the 5yr/60K powertrain warranty on that , replaced 2 dc power outlets, probably break even at the least if not ahead even if nothing else needs fixing
I will say if you have it they (dealer and SOA) seem to treat you much better on issues, eg the fuel line leak, dealer initially said it wasn't covered as it was a "hose" which is a "wear" item. When I called SOA and said I had an ext warranty, they immediately had dealer fix it under the ext warranty. though it would have been covered under the recall which came out a year or two later so I probably could have got my money back on that repair
you can usually find a dealer on line to sell it for 2/3 list price. you also don't need to buy it till just before the 3 yr/36K bumper to bumper warranty is up
if you put a lot of miles on (but not above the covergae limits!) its probably worth it, if not probably not
