Toyota RAV 4 Sport Run-flat Tires
I see that the RAV 4 now comes with a model without the tire on the back. Which off hand I like better. However, I wonder about having only 4 tires and them "run flat tires". Questioning how those "run flat tires" ride as compared the regular tires.
It seems that you can go 50 miles on them after picking up a nail et al which is fine with me since I won't be driving anywhere that I cannot get it repaired more than 50 miles away.
Any thought?
Any thought?
Not recommended:
1) The ride on RunFlats is considerably harsher.
2) In addition to the tire needing redesign to be capable of running flat, the rim has to be stronger (meaning thicker and heavier)
3) The rim has to have what is known as an EH2 or EH2+ safety hump so the bead of the tire stays on the rim. Otherwise, the tire will debead itself and the rim will be ruined.
4) The TPMS system is required so you know the tire has lost air. RunFlats don't feel much different when running flat.
5) Repairing RunFlat tires is hotly debated. If you look past all the verbage, The problem is that when a normal tire is run flat, the sidewall gets damaged. This damage occurs with RunFlats, too, but much slower - which is why they say 50 miles is the limit for running flat.
When repairing a normal tire, you can see this damage - sometimes on the outside, sometimes on the inside. On RunFlats, the damage is under the stiff rubber insert and you can NOT see the damage even if it is there! Clearly after 50 miles, there will be damage. If a RunFlat tire is damaged in the sidewall and then repaired, it could fail - just like a normal tire - and if that failure occurs at high speed, the vehicle could go out of control - and that's always bad. The failure will be sudden - just like a normal tire - and the RunFlat capablility will not be there.
Overall, not a good reason to make the attempt.
I'm quite certain that you can install a conventional tire on the rims when it comes time to replace tires.
Many new cars are doing away with spare tires and come with a can of sealant.
A guy I work with that has a BMW, says many a BMW owner changes to conventional tires and has roadside assistance coverage in case they have a flat.
I personally think Toyota could design to do away witht the exterior mounting and have a space-saver spare inside. Maybe for 2012? They don't need to continue with the exterior-mounted spare "because that's the way it has always been".
In any case, I generally like a stiffer ride and better handling, but a little softer would be nicer. Does anyone know any adjustments that can be made (without compromising safety, of course). For example, can a slightly lower air pressure in the tires be used? Will that damage the tires over time? Affect gas mileage a lot? Can any adjustments be made to the struts?
Thanks for any experience and advice!
Either or both are quite doable. If you opt for non-r/f tires - get a can of tire sealant and a 12v compressor in case of a flat.
If you ever do sustain a blow-out or sidewall damage, just call for roadside assistance to get the damaged tire/wheel or whole car to a tire shop.
Very doable if you cary your cell phone and AAA card.
Do not drive with tire pressure lower on run flat tires. This will not improve the ride at all as the sidewalls have no flex, hence no cushion.
So far I've changed the run flats for normal tires which helped some. Whats next, changing out the shocks? I'm guessing there is a somewhat more forgiving shock that offers a slightly less harsh ride, hopefully something in between the ride a limited offers and the harsh untuned sport ride. Suggestions?
Thanks in advance.
I kept the best run-flat tire from the OEM set and will get a rim to serve as a spare for long trips. I have not been able to find a spare 18 inch rim thus far.
I also have a can of Slime quick flat fix in the vehicle and have road hazard coverage through my auto insurance plan.
Hope this helps.
Any issue with the tps? I've had the OEM run-flats repaired twice when the tps went off - dealer found screws each time - and I wouldn't have known that except for the tps light.
Anyone else had this problem and were you able to find a set of conventional tires that handled like th RFT. Thanks
It's also possible that the dealer is commenting on the fact that there is no spare, so a flat tire would disable the vehicle - or that driving on a flat tire will damage the wheel and those are expensive.
Thanks in advance!
