2012 Mazda 5 Vibrating seats
At 60-65 mph, the middle row starts shaking severely. It will 'relax' outside of that general range. The mechanic drove four cars from the lot. He could not find a cause. Has anyone had that experience?? Know of the cause?
If so, then, yes, it could be a wheel out of balance. The reason that it happens at a certain speed is because that is the resonance sweet spot.
Obviously, if the dealer can't fix it, it is a lemon and they will need to make it right by buying it back. If they resist, then contact a lawyer.
Before all that, though, if they can't readily identify the problem, I would suggest to them that they replace all the wheels with a set from a car on the lot that doesn't vibrate. It is a quick and easy test that will either work or point them in another direction (next would be seeing if any rotors are warped or out of balance).
I really wanted to buy it so I was looking to see if this was something consistent or random.
At this point I should rule out this car. Don't you think???
Tire belts are known to slip during manufacture, balance is fine by the tire "wants" to go sideways.
I walked away completely from the deal and salesman said he would have too.
I really wanted to buy the car and was astonished that this has gone on unnoticed.
Was hoping there was a simple fix but now I am thinking it's a major thing from the factory. I want people to learn about this. I told the salesman I would do some research but am finding nothing about this issue. How can that be???
Do you own a Mazda 5?
If this was a defect in all 2012 models, I would think the published reviews would comment on it. I wonder if that dealer's shipper didn't do something wrong. I have read about tires/wheels being damaged when tied down too tight in shipping. Just a wild guess on my part.
The car talk forum talks about seats shaking in a Mazda 5's and that can be caused by rotors also. Vibrating seats in other comments in this forum in 2012 cars, the same as mine, can be caused by rotors.
There are cheaper parts in cars and I understand that. But, those outliers on the edge of specs deserve consideration. I think good customer relations would take reputation into account and have the rotors replaced in the few cars that exhibit these symptoms.
Is it just a few? The reason for the balk may be to not open a flood.
Personally, I consider it a good car and had three of them with no other problems. I think keeping the customer happy should be job one.
I appreciate the input.
