Regards:
Oldbearcat
Regards:
Oldbearcat
The following quotes from you beg the question whether they are directly comparable!
I filled her up with premium outside of Atlantic City, NJ, and got 34.5 MPG running her 70 - 73 MPH on cruise - headed for home in WV.
When I use 87 octane gas on my Pittsburgh runs, the CRV typically gets 24.5 MPG.
AndySD
Regards:
Oldbearcat
First, the reason I asked about comparability is it's almost unbelievable that your mpg jumped so much just from a gasoline change, using higher octane than mfr-required (not like your engine required premium and you used regular). Whether or not ethanol is involved, do you believe your CR-V's mpg went up so much - was it 24.5 to 34.5? Just seems over the top.
Re a different car's mpg for the same trip, in this case, the Jag, I'm not surprised. I think gearing has a lot to do with it. In my '99 Camaro Z28 I've driven three times round trip to The Formula One race in Indianapolis, and gotten just over 30 mpg door-to-door with regular gas. I attribute that to the fact that in sixth gear the engine turns 1,500 rpm at 65 mph, just idling along. Not that I didn't exceed 65. And I went via the Colorado mountains.
AndySD
I couldn't believe it either. The car's computer kept telling me I was getting this fantastic gas mileage on this trip. Then when I filled it up again in Flatwoods, WV, I checked it with a manual calculation, and, it agreed with the car's computer. A few months ago, my CRV was recalled, and, the dealer reflashed the computer. Today, Wife and I took a run up I 79 to Morgantown and back - about a 350 mile trip. The CRV, running 93 octane for the trip, got 25.1 MPG. That's basically a neglible difference over running 87, and, not worth the extra expense - other than the car feels a bit more athletic.
Re: The Jaguar - its more than just the gearing (6 speed). The Jag's VVT setup and induction system are more sophisticated than Honda's. Because of this the torque curve for their V8s and V6s is very flat - peak torque is available over a very wide RPM range starting at about 1500 RPM.
Regards:
Oldbearcat
Well, talk about dashing cold water! I know you give dependable data, so with your last CR-V trip you have singlehandedly sunk this big ship.
AndySD
(by the way, this is a paying gig Andy. So no tipping, even if it is the holiday season. )
I have got to get my act together and write C&D. Oldbearcat's last contribution negates the mpg improvement part of the fun, but horsepower increase was actually the starting premise. Also, I'm just about convinced that smoother engine performance is a side benefit.
In addition to trying higher octane, I plan something else with my Fit. Since I thrash it at the red line in the mountains, I figured out a way to effectively gain about 5 horsepower - and improve cornering: am going to remove the rear seats, which I've read weigh over 100 pounds. That will improve the power to weight ratio by about 2,550 / 2,450 = 1.04, as if the horsepower were increased by 1.04 x 117 = 121.8.
That said, I lost 30 pounds in the last year and my mpg nor performance haven't improved (hasn't helped my car's mpg or hp either :P ).
Regards:
Oldbearcat
But what do I know; another 70 pounds and I'll be a 90 pound weakling. :shades:
AndySD
Regards & Merry Christmas
Oldbearcat
Dear Editors:
In the light of European Car magazine's July 2010 positive result, this is to suggest you repeat your November 2001 test to determine whether using premium gasoline increases horsepower for engines that are not required to use it. The European Car test can be read on http://www.europeancarweb.com/tech/proven/epcp_1007_2010_volkwagen_jetta_proven/- viewall.htmlxx. In their test, using premium gas in a 2010 VW Jetta 2.5 L, dynamometer tests showed an increase of 8 horsepower!
I started what became a lively forum thread on this subject on Edmunds.com, Gasoline - 87 vs Premium. There seemed to be unanimity that such engines felt peppier but did not conclusively increase miles per gallon. My 2011 Honda Fit Sport 5MT definitely feels stronger with premium, and I wonder whether engines with higher compression ratio, like my Fit at 10.4:1, benefit more. Considering your success with the Fit in the 25 hour Thunderhill race, I hope you might use the Fit in your test.
As an aside, I love driving my Fit on the San Diego East County two-lane mountain roads, and it flies through the curves, more than holding its own compared to friends' expensive sports cars. I installed 17" Kosei Racing wheels with 215-.45 Kumho SPT tires left over from an '04 Civic, and removed the rear seats reducing weight by 70 pounds.
Sincerely,
Andy...
Maybe they'll edit that part out and get back to you.
All to no avail, and I'm signing off. I don't know the answer definitively, and probably never will . C&D never reacted.
RIP
