2012 Hyundai Sonata
I'm debating to buy a GLS or SE. Somewhere I read that among the people who bought Sonata, more than 50% bought GLS, more than 30% bought limited, and only about less than 10% bought SE. Why is SE not as popular as GLS or Limited? Any commonds from anyone?
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
http://www.jdpower.com/autos/ratings/quality-ratings-by-category/midsize-car/
Sonata is a newer offering from as company working hard to establish a reputation for good quality cars at value prices. We felt comfortable with the resulting equation of good initial quality (per reviews), good looks , and value for the price, that is MPG,warranty, Assurance program, increasing resale values and a company eager to sell cars in the US and making the right moves to make that happen. Lots of good choices right now.
There was a rattle from the rear parcel shelf area somewhere. Wedged more foam between the right rear c-pillar and the rear window. That lessened the rattle significantly.
The doors don't latch closed in weather below 10 degrees...have to soak the latches in lithium grease when the weather gets cold. Once they have the grease on them they latch a little easier.
The driver's door now rattles when going over bumps. There is a rattle in one of the passenger doors, but only when going through curves or corners that sweep to the right.
There is a loud metallic clunk/clang from the underside on cold mornings when going over bumps. Noise goes away after 20 minutes of driving.
The car takes 30-35 minutes (approx. 15 miles of driving) to indicate normal operating temperature on the temperature gauge when the outside temp is below 30 degrees.
The center console is poorly assembled and requires liberal applications of silicone spray in all seams a few times a year. Otherwise it creaks constantly, especially when slowing down or accelerating (when there is a shift in momentum.)
The bolts holding the front seats to the floor have to be tightened at least twice a year as they tend to loosen up. Very odd considering I rarely ever carry passengers.
The door panels pop in cold weather, and vibrate with low bass notes despite the fact I have the bass set at -2.
The rheostat that controls the brightness of the dash lights when the headlights are set on auto is poorly designed. The dash lights dim, or get brighter, randomly while driving regardless if set on auto or if I have manually turned the headlights on.
Sometimes the windshield wipers do not park correctly after using the washer fluid. They will park 2-3 inches above the normal resting position. I have to turn the wipers on again and do a complete sweep, then turn them off and they will rest in the correct position.
The headlights no longer come on at night when I press the unlock button on the remote. If I want the headlights to come on while approaching the car at night, I now have to unlock all doors by pressing unlock twice, then lock the car right away, then hit unlock again. This wasn't the case when the car was new.
The car has been mechanically reliable, however the build quality is less than stellar. This is my first Hyundai. I would possibly consider another, but it would have to be a Genesis sedan or possibly the new 2013 Azera...something higher up in the Hyundai product line. If Hyundai released an AWD V6 Genesis sedan tomorrow I would seriously consider purchasing one sooner rather than later.
The paint quality is poor. It has a few areas where the paint has shading issues from being applied improperly.
There is way too much road noise. It appears that they skimped on insulation to save money and weight.
Yes, they are selling well but the quality control has fallen in favor of production.
Spend a few extra dollars and get something with a proven track record.
The key will be Hyundai's response to any potential problems. Quick, honest recalls and TSB's will fix customer complaints early and avoid the bad press of other brands with bad engines, designs problems, unannounced recalls and cheap TSB fixes to known problems.
We are willing to give them a chance to back up their great warranty and Hyundai Assurance trade in guarantee progams should their cars experience design or manufacturing clitchs down the road.
If anyone has a problem they complain about it however if you have no problems its unlikely that you would write about it.
Hyundai has sold over 250,000 of these cars so your going to have some problems and so do other cars such as Honda or Toyota. My Sonata has 21,000 mile and I have had no problems. People having problems are mostly caused by a poor dealer...........
My issue for which the dealership has found no solution is the strong odor of gasoline/exhaust in the cockpit and outside the car once parked and prior to restarting. First the dealership replaced the gas cap after testing found a loss of pressure in the fuel tank. After that didn't work, they replaced the high pressure fuel pump after finding it was cracked. (Note: the replacement fuel pump was also found to be cracked in the box, supposedly the result of damage during shipping due to poor packaging.) The air filtration filter was also replaced and it smelled of gas as well. Once, the service manager kept my car for two days and drove it home and claimed he could not duplicate the issue; yet the service writer could smell it inside my car during a recent oil change. The car stinks up my entire garage once parked after driving. I am embarrassed to have a passenger because of the smell and I am concerned for my own health from inhaling the fumes. The service department has thrown up their hands and Hyundai has been no help to them with an answer. I am considering invoking the lemon-law. The crazy thing is I would just want a replacement Sonata. For what it is worth, I have had Blue-Tooth issues as well, but that has been the least of my concerns. If anyone has a possible solution - please write. Thank you. :lemon:
All manufacturers turn out lemons on occasion but when it happens to you it can be an extremely stressful experience. Good luck.
My Sonota is 1 year old and has about 20,000 trouble free miles and get GREAT gas mileage. I don't think you can find a better value with a fantastic warranty.......... Even Consumer Report check rates this car
Most of our maintenance & repair discussions have quite a few dissatisfied owners posting in them. The higher the volume of sales, the more active the M&R discussions are, in general (there ARE exceptions, of course). So, if Hyundai complaints have picked up, my first thought is that it's because there are more owners than there were previously.
Each vehicle seems to have its own issues - for example, you'll see a lot of complaints about the transmission for one of the BMW sedans. There's one that's experiencing "pull to the right" issues too. Accord/Civic owners have complained about premature brake wear. I could go on & on. The smart shopper will just do a LOT of reading using different resources about different makes/models, and decide what seems the best overall risk for themselves.
The collection of parts on a car are manufactured for minimum cost not maximum life. The parts are then assembled by semi-skilled labor in the US or Mexico or another exchange rate friendly country. It is truly amazing that we receive such high quality dependable vehicles - but we generally do. We bought a 2010 Buick Lacrosse that cost 11% more than our 1998 Pontiac Bonneville. we bought a 2012 Sonata GLS that cost 19% more than our 1990 Honda Accord EX. About 1% per year more for much more in features, safety, fuel economy, driveability, and overall value for each example.
Of course, there are companies I refuse to do business with, but that has to do with the way they treat me and/or their policies more than their products.
Another model (GM) had a problem with the return (overflow) line actually deteriorating and allowing the smell of gas to enter the car thru the trunk. the car was older and the failure was attributed to age not design. The connection to the gas cap receiver to the receiver tube tot he tank and the overfill bypass can also contribute. Hard to diagnose and easy to fix.
good luck. Crankee
On the 2.4L Sonatas, there is a known issue related to a hose in the engine compartment that goes bad and results in a very strong fuel smell in the cabin. Not sure if the 2.0T uses the same/similar setup.
I'm VERY close to buying the 2012 Sonata Limited but there are so may posts that contain "problems" that I'm hesitant. However, I recently purchased 4 brand new LG appliances for my kitchen in spite of some of the negative reviews and, to my surprise, we haven't experienced any of them. we absolutely love them and i'm hoping the same will be true with the Sonata. Would you mind giving me your honest feedback on your Ltd. and let me know how many miles are on it & how long you've owned it?/ Would appreciate it. Thnx
I bought a new Sonata 2.4L 2012, four months back with navigation package. I paid 32000$s just for Car. About a month back some how some water went into the engine thru air filter. No body knows how (not even the technicians). Anyways, Engine engine ceased. Hyundai dealer ask me to claim it with my insurance. I did, they replaced the engine with new engine. Now my Car is fine and working.
Now I want to know three things:
>> How can I check that the engine they fit, was surely new?
>> And what will be the cost of this car, for resale and trade in.
>> I don't want to keep this car, what are my options and which one is the best.
Any help will be great
Also, as an aside, I seem to be occasionally having a a slightly rough idle while at stop lights...fluctuations between 500 - 750 and it sounds as if something else is running in the background of the engine...MOST times at stop lights however, the engine is super smooth and the RPM gauge sits quietly at 750...
Lastly, I have noticed that the driver side fabric seems to "puckering" after sitting in the seat...I had fabric problems with my 2009 and this appears to be similar, although not as bad...it's almost like the fabric wasn't stretched enough? Is anyone else experiencing this type of fabric issue?
Other than these minor issues, the car is a pleasure to drive. I am getting about 36 miles to the gallon (I drive highway almost exclusively) with an engine that isn't fully broken in yet (only at 1600 miles)...I am very impressed with that.
Thank you in advance for any advice anyone has. I have been a faithful reader (albeit, not poster that much) for MANY years and have learned so much from the numerous discussions.
Hyundai really has a winner here.
Reminds me of many years ago when my dad tossed a butt out the window. It got sucked back into the car through the open rear window, landed on my sister's lap, and started burning her. Needless to say, it was the LAST time my dad ever tossed a butt out the window!
When I was a kid the same thing happened to my dad's car. The butt burned a hole in the back seat.
Thanks for replying.
I traded it in January 2012 for a 12 Limited (no navi, no turbo) because I had already blown out two wheels on potholes. In a mild winter no less. I knew it was going to be a constant issue for me in New England. Got 90% of what I paid new on the trade and got the new Limited at a very competitive $24,500.
12 Limited has been great. Though for some reason my MPG has been lower (about 26 on average vs. about 28 on SE) Doesn't make sense, but it is similar driving.
I also notice the drop in HP. Mostly around town, probably about 15-20% highway and I drive conservatively. The SE was real nice and have a better tuned engine and better MPG. If I didn't live in a bad pothole area I would have kept the SE.
No real problems on either car with a combined 16,000 miles in 11 months.
Please watch the LCD radio screen in the center of the dashboard. It is not visible in normal bright daytime.
