mazda5 RPM bounce between 500 and 1000 from a cold start(idle)
I want to get a mazda5(2010) through hertz rent2buy program. I tried out two cars. Both have issues with RPM sometimes bouncing between 500 and 1000 from a cold start(put in idle). Initially, I thought that there could be a leak somewhere which usually causes this bouncing RPM. But, after test driving two cars, two cars have the same symptom. I start wandering if this is a "feature" to this 2010 Mazda5. Thank you.
1. Disconnect battery (once again)
2. Connect battery
3. Get in car and close doors wait for dome lights to go out
4. Turn ignition to ON (but do not start car) to where all dash lights come on
5. Leave it like that for 1- minute (time it)
6. Start car and let it iddle for 5 minutes
Voila!
You could also clean out the throttle body with some throttle body cleaner sprayed on a rag and wiping the inner bore and the butterfly. Then do a iddle learn procedure.
Just suggesting...
PS -- the Mazda OEM positive battery cable end was shockingly weak, I completely ruined it overtightening trying to get a solid connection to the new battery. But a new connector, labeled "marine", costing less than $5 from O'Reilly's was an easy fit after some filing to enlarge the bolt-hole, and adding some washers.
