1999 Nissan Quest Problem Code P1105
supernissan
Member Posts: 1
Hey Guys
Well I have a Problem,I got a Check engine light about mouth ago, Check with a diagnostic, it was a P1105 which a MAP/BARO Sensor, We replaced it Reset the code and still Check engine light came back on, scan again it was still P1105 and since I live in NY failing an inspection is a big no no and I have inspection next mouth so do you guys know what could be the issue? any and answer Suggestion would be Great.
I have a Nissan Quest 94...Battery is just 2 yrs old , shows 12 volts..
I came home yesterday (outside temp was 65 )...I put van in Park and Suddenly all the lights gone.
When i open the door , door lights didnt turn ON...Usually the seat belt comes off by itself once i open door. It didnt
So i tried to start Van again ..No sound No clicking nothing...Wht might be wrong..??
All i know was brake fluid had gone below min level and brake light was ON...
I drove like that for 6 miles...during that once ABS sign also lit up; just for 2 seconds. Then its gone. To be specific, I happen to drive almost 4 miles after that ABS light disappeared...Thank god the van reached home But now its not starting at ll..Wht could be the proble....?? pls help
Appreciate your tips...
thank you and advance
