BMW X3 Fuel Needs
dlcole76054
Member Posts: 21
My 2011 Lexus RX runs fine on regular unleaded fuel, even though Lexus says it needs premium, the salesman said to run regular. It runs fine and has a 10.4/1 compression ratio.
An X3 iDrive35 has a 10.2/1 compression ratio (lower), yet premium fuel is still recommended... Have any of the readers run regular unleaded fuel in your X3? Did you get engine knocking? or other bad things (poor MPG, etc).???
THanks.
THanks.
PREMIUM FUEL IS REQUIRED,NOT RECOMMENDED
I tried using mid grade 89 octane I felt that the vehicle did not run properly
and also the gas mileage suffered a bit.The same thing happened with sunoco
PREMIUM 91 octane.
You need to use PREMIUM WITH 93 OCTANE to achieve maximum performance
Since Sunoco is a California fuel (or western US), I'll take it that the 91 Sunoco problems were related to the California fuel formulation and not 91 octane fuels in general.
The BMW requires premium, whatever octane level that might be where you are... While a naturally aspirated engine might tolerate a lower fuel grade, it's an especially bad idea with a turbocharged engine....
regards,
kyfdx
They say it is a widespread problem. Anyone else getting this advice?
If the local dealer can't help you, you might try contacting the Performance Center at the factory in Greenville, SC.
