A Mechanic's Life - Tales From Under the Hood
13132343637180
  • stickguystickguy Member Posts: 50,545
    you work on commision or something?
    That is not really a schedule, and not sure where it came from, but it is something. Though the 10K interval is not accurate, at least based on the MM.
    Afaik, all the Guide info comes from the manufacturer. You could try the Acura Owners site. There's stuff in the '12 TL manual about Maintenance A and Maintenance B (and sub items 1 - 6), and to change the oil every year if the "service due now" message doesn't show up. And there's stuff about other inspections independent of the Maintenance Minder (brake fluid every 3 years, inspect idle speed every 160k, adjust valves during any service if they are noisy).
  • thecardoc3thecardoc3 Member Posts: 5,747
    Makes one wonder who wrote that. Typical valve wear will have the valve faces and seats in the heads wearing the fastest and that means the valves get tighter and make less noise. When they get too tight they can hang open and that causes them to burn and fail. So a little valve noise is actually better than no noise.
    edited February 2013
    Guess whoever wrote the 2012 Acura TL owner's manual wrote that. It's on page 540 of pdf version I downloaded.
    that looks about like what my owners manual has in it.
    I always got a kick out of their "inspect the idle speed" at 160K. Seems very random. First, with a tach, kind of easy to do every day. and by that mileage, who cares?
    The mechanic specifically said that the line "wore out "-
    This is worth a little revisit. We can't see the line, so all we have to judge this is experience. As I said earlier here in western Pa, a corroded line would be quite plausible. I've got a feeling that the mechanic in this case didn't have an attorney and defended himself. There are many people who don't communicate well under pressure situations. As simple of an event as this was he may have been a lot more nervous on the inside that was displayed on the outside. Saying that the line wore out leaves a lot of room for interpretation. Had he of had his own lawyer, (assuming again that he didn't) his lawyer would have made him be specific about just what "worn out" meant.
    he acted as if it was almost a consumable part like a rotor or clutch disc.
    They fail and need replaced, heck it's one of the first on the street repairs that I did as a sixteen year old. That AMC Gremlin that I was running around in was only three years old and it lost one of the cooler lines and leaked transmission fluid all over the street. I remember my dad showing me how to use the flaring tool, and the tubing cutter. Then we bought some copper line and transmission fluid and he dropped me off where the car was sitting. The rest was up to me.
    Had he said "The line had corroded and was starting to leak at a thin spot in the tubing."
    He was a mechanic, and likely accepted the failure as common and expected everyone else to know as much about the way they fail as he did. In retrospect he probably should have worded it differently, but thats why he should have had a lawyer represent him. Although that probably would have cost more than replacing the line did.
    I'm going to give this a 75% chance that he got ripped off by the system.
  • roadburnerroadburner Member Posts: 17,358
    The manual for my Mazdaspeed 3 states:
    "Audible inspect[sic] every 120,000 km (75,000 miles), if noisy, adjust"
    Mine: 1995 318ti Club Sport; 2020 C43; 2021 Sahara 4xe 1996 Speed Triple Challenge Cup Replica Wife's: 2015 X1 xDrive28i Son's: 2009 328i; 2018 330i xDrive
    I'm with Doc on that one--I'd rather have the valves a bit noisy (presuming they aren't hydraulic") than have someone attempt to adjust them and make them too tight--which would be a fatal mistake.
    many of these newer cars use a shim method to adjust valves, and so on a V-6 that's going to be pricey, and to no good end whatsoever.
    If they are clattering, sure, but a little tippy-tap noise when cold---just ignore it.
    Nowhere in the manual is "noisy" defined.
    But I'm sure some ultrasupreme dexos46 will quieten things down nicely. :-)
    As is often the case, unscrupulous repair shops will use irrelevant or harmless noises (tippy-tap valves), or perfectly normal situations, (consuming a pint of oil every 10,000 miles, a "dirty" dipstick, etc) to alarm people into spending money. You can trick the most intelligent person if that person has no expertise in a certain area.
    Conversely, an intelligent car owner with no expertise in cars can drive an honest repair shop crazy with illogical demands.
    You would definitely need a mechanics stethoscope for my Mazdaspeed 3; you can't hear anything over the piezoelectric fuel injectors...
  • crkyolfrtcrkyolfrt Member Posts: 2,345
    I agree, plus..bucket and shim systems go way longer between checks. They may be a pain to do when the check indicates it's necessary, but at least they rarely need doing. On bikes (and probably most DOHC car engines too) you can check with cam in place, but many you have to remove the cam in order to actually make an adjustment change.
  • jipsterjipster Member Posts: 6,244
    How.many of.you guys change the oil viscosity to the season? As mentioned earlier my Mazda MPV had a 3.0 duratec engine, rated 200 hp.
    5w-20 suppose to cover all
    Temp ranges. But owners manual says can use 5w-30 in summer, which should offer better engine protection in high heat fora bigger engine correct? Always dealer maintained
    but dealer usually did not write viscosity used. I know lower viscosity helps with mpg. But, as noted earlier, MPV burning oils bit early. Any thoughts?
    2020 Honda Accord EX-L, 2011 Hyundai Veracruz, 2010 Mercury Milan Premiere, 2007 Kia Optima
    You'll notice that the 5W20 is likely approved for all the temperature ranges the car can encounter, and the 5W30 likely starts at a much warmer climate and overlaps the 5W20.
    Ambient temperature is an important consideration when it comes to choosing an oil for cold starts, but it isn't as important for when the engine has reached its operating temperature. That's why both oils are acceptable for year round use, and they are both tested for harsh conditions as well as engine load. Engine load is the more important concern, the harder you work your engine, the hotter the oil gets. That's why the manufacturers specific tests have requirements for 301f (150C) and not just 100C like you usually see published. That 5W20, that meets Mazda's specs (Ford's) will protect your engine just fine.
    Kevin M taught us to realize that a car running around Yuma Arizona when its 130 out during normal use doesn't make an oil as hot as it could get in a truck towing a trailer up an Alaskan mountain in the winter. The correct 5W20 can protect both of them just fine if that's what they call for.
    The manufactuers have been going to thinner oils and while fuel mileage is a consideration, there are a lot more reasons than just that.
    Thicker oil flows slower, and when it gets into some of the very hot places in an engine, it sometimes can be too slow to flow back out of there quick enough. That causes the oil to get overheated. One of the jobs for engine oil is cooling. If an oil hits a hot surface and it flows off very quickly it will pick up heat, but not so much that it gets damaged. Thinner oils do that very well . A thicker oil because its flowing slower can get so hot that it leaves deposits behind from it breaking down. This is what gums up the piston rings and leads to cylinder scoring and finally increased oil consumption.
    For everytime that you have seen someone try to use the defense that the manufacturer would have to prove that the wrong oil was used in an engine to deny a warranty, realize that I just told you one of the things that they will look for and they can analyze the deposits that were left behind that gummed up the rings and prove exactly what happened.
    I'm glad you included that. It can get really bad with unrealistic demands such as when one guy with a Cadillac wanted to run 38psi in his tires. This was early on in the phase in of TPMS and a local shop had done what he requested. The TPMS light came on and besides using the magnet and following the book, they had no idea what to do with the car. They thought that it must have a bad sensor, but couldn't figure it out so they sent it to me. I'm not a tire shop, but I added TPMS tools to my collection right away, and have had to upgrade those tools through the years. (That's about ten grand to date just for TPMS)
    When I started checking the car I quickly found the tires over inflated, and I reset the pressures to specs (30PSI). The light went out. That's when I called the other shop and they told me the guy screamed all over them because he insisted that he was running 38psi in his tires before they were replaced and the light wasn't on, so he's sure they did something wrong to the car. It was easy to find documentation that the light would come on if a tire was under inflated by 25%, but no where was there documentation that explained that the light would come on if a tire was over inflated. There also was no way to change the tire pressure spec in the vehicle system back then either so at that point I was done. The car was later picked up by the still screaming customer, (with the light out, tires correctly inflated) and he still wouldn't believe that there was nothing wrong with the car.
    For my troubles that idiot still bad mouths me and my shop, all because I did a favor N/C and checked his car out for the tire shop.
    My Bro-in-law qualifies remarks like that with, "If you cant dazzle-em with brilliance, baffle-em with BS." :P
    I had the head off of a Sentra late last year. When I got it back from the machine shop, I figured it would be far easier to do the valve adjustment before the head went back on. After getting all of the sizes that I needed I called the dealer and his parts guy replied that they not only didn't have any of the shims, they had never used any. He used his locator and he claimed that there wasn't a single dealer that had a whole set of the shims. The best that he found was a few that each had one or two.
    I called up my machine shop and talked to them about the situation after I had talked to the shop that the dealer uses. Let's just say the machine shop had to be very creative to get the existing shims to work correctly.
    I was glad I chose to address this before I put the head back on.
    Amazing, in that if a customer did have a car that needed adjustments (like your guy's Sentra) that they don't stock the ability to do the job. This speaks to them just throwing it back together with what may had they been the chosen shop to do the job..and probably charge the guy as insult on injury.
    In future, try a few bike shops...they tend to carry pretty good shim stock, and work with each other trading sizes..
    I'm not sure, but I suspect shim overall dimension sizes are probably not much different between car and bike engines? Putting that out as a question, but I think might be the case with similar sized displacement engines and valve trains....or at least bikes that are not tuned super hot with steeper cams and such. Possibly the thinner sizes might be harder to come by for auto use and milder cams?
    The proper weight oil is also important for hydraulic variable valve timing systems.
    Many years ago, I bouught John Muir's book " How to keep your Volkswagen Alive"
    He REALLY stressed the need for me to lie on my back every 3000 miles and do a COLD valve adjustment on my beetle and I did!
    Funny thing, they never needed to be adjusted but I still did it.
    That was a classic, spiral bound to lie flat and everything. Mine seemed to benefit from the valve adjustments.
    That was a great book and fun to read. I passed it along when I sold my VW.
    I think I may have adjusted one valve one time but otherwise they never needed it.
    And as I mentioned earlier, I know of at least one BMW dealer that never bought the special BMW tool needed to do valve adjustments on the S14 and S38 M motors, even though the SI system called for a valve inspection at @15,000 mile intervals.
    Amazing is right...
    The odd part about that is one would think that would have been an essential tool, and in North America, the franchise agreements were worded in such a way that the dealers don't have a choice in the tool purchases. They get boxes shipped in and the moneys come right out of the dealers bank account. There are lots of dealers with boxes of essential tools that have never been opened.
    That being said, before I went on my own, I was buying lots of tools that the shops that I was working in should have been buying. I had my own jack, and jack stands from my dealership days. I had my own scan tool, and oscilloscope. Heck I even had my own press and shop crane among many other items.
    I've had several new customers from check engine lights that were the direct result of the wrong oil in the engine.
    Meanwhile on my blog here is an example of "You can't tell if oil is due to be changed by just looking at it".
    My Mustang, which gets stored each winter had it's last oil change Nov 9th. 2011 since I am teaching in Tennessee this week, we decided to sneak it out of Pa. But I knew I needed to change the oil first. So with almost
    sixteen months and just over 4800 miles on it, here is what it looked like on the dipstick.
    http://johng673.blogspot.com/
    Yep, you cannot tell by just looking at it.
    After reading this story in the NY Times tonight, I wonder if your estimate is too low (GM "brake lines are so susceptible to rust they may burst").
    The oil myth quote goes "If the oil turns dark or black quickly, it's no good. You can tell the condition of oil by the look, smell or color of it. Dirty (black) motor oil means the oil is breaking down".
    (Big tool sale tonight only at Sears btw).
    From your quote.
    A common misconception is that high quality motor oil should come out of an engine looking clean at the time of an oil change. Nothing could be further from the truth. If the oil is doing its job of cleaning the engine, then it should be dirty when it is drained
    People read that, and would look at the oil that was still in my Mustang and with no other information think that it was OK to keep running it. The mileage that we put on the car last year was 80% highway miles with one way trips of fifty or more miles. We rode 500 yesterday, and are in Bowling Green Ky. this morning. After touring the Corvette factory and museum today, we will be headed on to Memphis.
    First this isn't a problem with just GM vehicles. Honda, Ford, Chrysler and others all also have brake line corrosion concerns. The lines are fine and probably last the lifetime of the car if you aren't in the rust belt like we are. I have some cars that before we went to the copper-nickle alloy have had some pieces of line replaced more han once. Even the coated lines you can find at the parts stores don 't last. I have one truck that the owner asked me to not only use coated lines, we rust proofed every inch of the lines that I installed. That worked, so far...
    In Pa. we still have state inspections. At one time techs could fail a car if the lines looked bad enough, today we can only fail them if they are leaking, and what happens later that day isn't our problem. On one hand that may seem like it doesn't make any sense, but if we are to fail the lines by what they look like (judgment call) then we can get it wrong both ways and can be held responsible. Think about it, we could condemn a line, only to have it last another year or more, (we would be rip-offs selling unneccesary work) and we could not condemn that same line only to have it fail later that day (now we are incompetent, or must have done something to the line to make it fail). The facts are, you just cannot tell by looking at them. The best we can do is show the customer, and tell them they need to plan on dealing with them, but we are not allowed to fail them. As watered down as the state inspection program has gotten to be, I wouldn't be surprised if it eventually goes away completely in the near future.
    Some of the notable experiences are lines that have failed while we had a customers vehicle in for another repair. One was a Ford truck with a powerstroke diesel driveability problem. I was doing my baseline tests, which included an automated test that requires me to hold the vehicle with the brakes and a line burst in the shop. I was moments from going out on the road with the truck. That's one of those "I got good news, and I got bad news phone calls" for that customer. The bad news is of course that the line failed, the good news is that they didn't experience the loss of the brakes themselves. With me behind the wheel, its my insurance if an accident had actually occurred, but its also my driving skills and attention to detail that are tested to try and prevent an accident. No one has ever questioned needing the lines replaced and usually feel bad that their car put me in that position. To me its just part of the job, and I feel better knowing that my customer didn't have that frightening experience.
    BTW. GM and Chrysler both had so many tranny line problems, they sell factory bent replacements cheaper than I can make new lines from bulk.
    Don't forget fuel lines in this too. You should see what it might take to do a simple fuel filter replacement, you could get into doing every brake and fuel line on a car as they fail the moment they are disturbed.
    Well, you know what they say, "Just because an oil isn't light, it doesn't mean that it is safe to continue to run in your engine." :shades:
    I've never lived in the rust belt until we moved to the UP three winters ago. The amount of road salt they use up here is just amazing, compared to my AK experience at least. It took ~15 years before I had to start rattle-canning the lower door areas of my Tercel up there. My Idaho rides were old but pretty pristine after the decade in Boise but they are rusting now.
    Pennsylvania likes to tout their auto inspections and toss out stats about how much safer the cars are there. I have my doubts, but I'm not surprised to hear that the program may go away. People tend to hate those inspection programs.
    Did you know that Craftsman tools that were bought with the full lifetime warranty aren't guaranteed anymore if I go to the store with my work shirt on? Of course I don't have and use many of them anymore,since my box has mostly Snap-On and Matco tools in it. The majority of the craftsman stuff that I do have has been taken home to use on the garden tractor and around the house. I still break one on occasion when I do use them. It doesn't seem right that they can discriminate against professional mechanics when it comes to the warranty.
    Guess they don't want their tools to be "used" but yeah, I have seen a lot of products disclaim the warranty for professional or commercial use. Most recently the in-laws' electric blanket (not for motel use).
    Sears should rename the sets to Wannabe Mechanic's Tool Kits.
    Safer cars, safer roads
    There is only a little pressure to kill the program right now, however there is some activity to try and amend the emissions testing that we do. The emissions program is tied into the safety inspections in that, you cannot get a safety sticker until you satisfy the requirments of the emissions program. Sen Elder Vogel wants up to a ten year exemption on the emissions testing because in hs opinion there just aren't enough broken cars that it gets credit for being repaired. IMO all someone would have to do is add an amendment to that bill to kill the safety program and it will all fall in a hurry.
    There is both good and bad in that, the bad side is that there are quite a number of shops who's existence relies on the inspection program. A lot of those won't be able to change direction fast enough to stay viable without it. They do a lot of good, and necessary repairs, but the loss of the program would have some customers putting some of these repairs off for a long period of time. That is until fate finally catches up with those vehicle owners. The shops would need to drastically cut expenses and IMO the shops don't have the cash reserves to wait out the lul in vehicle traffic. Then by the time the consumer does get forced by the car itself to have something done, we will have the classic situation where the repairs cost more than the value of the car and that will hurt them more at that point in time then all of the repairs strung out over a larger time period would have.
    So Sears is admitting that the wrenches and sockets that the sell aren't professional quality?
    When I worked for Sears, they didn't do that.
    Still, if people saw the abuse some tools take they wouldn't believe it.
    The pros didn't want to hear the word "abuse" but so often it applied.
    Sears is just admitting what every mechanic already knows. :)
    You want to break every knuckle on your right hand? Just put a lot of torque on an open-end Craftsman wrench.
  • busirisbusiris Member Posts: 3,490
    Well, that's exactly what SC did several years ago. Annual car safety inspection was required, but the price was state-regulated, yet the state kept adding on inspection requirements. Finally, it became impossible to find any shop willing to spend the time to do an inspection, since they lost money on every single one.
    That forced the state to do away with the inspections.
    In December I broke a 1/2" to 3/8" Craftsman adapter trying to loosen the lug bolts on my wife's car when I was installing the winter tires/wheels. It dated back to the '80s, so it can't be blamed on being made in China...
    No, it can be blamed on using the wrong tool for the job.
    Very common tool to break and for good reason!
  • xwesxxwesx Member Posts: 16,794
    How do you know it needed to be replaced?
    Yeah, I'm always a little nervous about using a 1/2" to 3/8" adapter, and just for that reason. You can put a whole pile of torque on that little 3/8" socket (& adapter) that it couldn't possibly see through use of a 3/8" ratchet (without the use of a breaker bar).
    I have such an adapter and do use it on occasion, but do so with care. Heck, I've broken lug nut wrenches trying to loosen their namesakes. I wouldn't dream of using a 3/8" socket! :surprise:
    I'm not real picky about the brand, but I do make a point to buy my tools US-made. I don't know for certain whether they're better, but I'll support industry in my own country where I can.
    Tools are one type of purchase where I expect that it should be a once-in-a-lifetime event. For me, that's turned out to be twice-in-a-lifetime, as apparently someone else needed my tools more than me about fifteen years ago. C'est la vie.
    Well, I've used it since the '80s, primarily for wheel changes- and I typically applied 65-95 lb-ft of torque. I ended up buying a 1/2 inch drive 17 mm impact socket and a longer breaker bar- but my next garage purchase will be an 18V cordless impact wrench- it should save my back and be more convenient in the pits.
    I hate hearing stories of people getting their tools ripped off.
    In the "old days" they used to hang horse thieves because they were basically stealing a person's liveihood. No difference between that and stealing a man's tools.
    Sorry to interrupt for a moment, but when you have a chance, please stop by our new "Forums Future" discussion and tell us what you like, and do not like, about our current forums, and how we might improve them when we implement new software! Mr. S thanks you, and please continue.
    FORUMS FUTURE DISCUSSION
    Darn straight. It took me a couple weeks before I wasn't walking around livid all the time. My wife (fiancee at the time) still married me though, so I must have toned it down within a reasonable time frame. :blush:
    Many of those tools I had purchased with summer jobs in middle and high school, though, so I had a lot of investment in them, even if the total dollars lost was "only" about $1,500 or so.
    I know a few techs who have lived through the nightmare of having their tools get stolen or lost in a shop fire and it isn't a pretty picture. Its rare for a shop to insure its employees tools. There are a few that do, but they are the exception. The average senior technician will easily have over $50,000 in his tools. Some might think that the techs home owners insurance will cover the tools and in fact with a rider to do so and an accurate inventory list on file with the agent, they do, provided the tools are at the techs home.
    Insurance companies play games too. If I suffered a complete loss, they will cover about $160,000 for my tools but only if I am replacing them. My actual loss would be over $300K retail today.
    The most ignorant of all of the stories would be about a technician who's tools were stolen while he worked at a dealership. The dealership of course required the techs to have their own tools, and they didn't provide any insurance for the techs tools. He didn't have the money to replace his tools and subsequently lost his job over it! A bunch of us got together and each chipped in with anything that we had duplicates of and we got him reasonably set up, and even helped him find another job but nothing was really going to ever erase the hurt he experienced.
    There was an attempted break in at my shop last fall. The alarm system scared off who-ever was trying to break in, and since I work on all of the local policeman's personal cars, they responded to the call in a big hurry. Still, its always a concern. :(
    So we are on our way back home from the work that I did in Memphis. We stopped into a truck stop and took a short break from the road. While I was waiting for my wife I took a minute to check out some of the products on the shelf. The Kendall Liquid Titanium 5W30 bottle caught my eye, so I looked to see what it said on the back.
    API SN, ILSAC GF5. OK, that's the current standards. Then it had Chrysler MS6395 (T). Now that's excellent, they specified the exact rating that they met and it is the newest Chrysler specification. They had the Ford WSS M2930-B. Then they showed "GM 4718M (obsolete)". I put the GM spec in quotations here because they are open about the fact that the specification is no longer in effect by listing it as obsolete. However, the fact that it meets the Chrysler MS6395 "T" actually means it really does exceed that obsolete GM spec. But at the same time, it did not say dexos1 anywhere on the bottle. There was nothing on that stores shelf that had the dexos1 label on the front of the bottle. There were other products that met the API 5W30 and they weren't even all SN.
    If a GM vehicle owner that requires dexos1 had to add oil, that Kendall was the best choice, especially since it meets the newest Chrysler spec. But they made it very clear that it isn't approved for the dexos1 specification. So this morning I checked and guess what, there is a brand new list for dexos licensed products. (Feb 20th 2013) Kendall does not have one. Now the next time you are out at the store, compare what you see on the back of their bottle, to what you find on other products.
    http://www.gmdexos.com/licensed brands/dexos1licensedbrands.html
    When consumers, shops, and techs understand how to choose the correct products for given cars, they will find the correct products on the store shelves.
    BTW, there were no products suitable for any of the European vehicles on that store's shelf.
    Doc,
    This short video of a runaway acceleration event was on the CNN website yesterday. Being a mechanic that has a better understanding of the interaction between the many components on modern cars, I would like to get your opinion on what you think happened.
    Personally, I find it difficult to believe so many sub-systems could fail simultaneously....
    The family has secured the services of an attorney...
    http://www.cnn.com/video/standard.html#/video/us/2013/02/27/dnt-teen-out-of-cont- - rol-car.wfaa
    Doc,
    Do you REALLY think using an "incorrect" otherwaise quality oil would affect the life of a car's engine one twit over 200,000 miles?
    Assuming it's changed on time of course.
    I'd certainly take a 2-1 bet that it wouldn't matter at all. I'd ask for odds just to sting the purists a little harder when I win :P
    Of course, the problem with such a scenario is that there are a lot of other things that can affect an engine over 200,000 miles.
    I would take a bet, though, that I could put a premium oil, without regard to specification, in my car, and drive it for 30,000 miles without incident and without ever changing it--topping it off of course, and swapping out the filter.
    I totally agree with you but I couldn't bear to leave oil in a car for 30,000 miles!
    I still remember the "Pennzoil" engines from the old days. After beating the valve covers off with a rubber mallet you couldn't even see the rocker arms!
