Worst case scenario he shold have been able to activate the e-brake although at those speeds it might have done very little and totally burnt the rear brakes.
What about just turning the key off?
And lastly he could have slowed down by gently scraping the middle divider until friction would cause him to stop?
On a somewhat related side note back in 1997 when I had my new 1997 Civic back then with a 5 speed manual an odd thing happened to me a few times.
I started the car in neutral, and suddenly my ABS and CEL lights came on and when I attempted to press the clutch it would not press, instead making a grinding noise. Transmission was in neutral, the clutch pedal would press in only about 1/2 inch before making the grinding noise (it was not like the gears were grinding, it was another weird noise), and nothing I could do to put the car in gear. I always thought the clutch was fully mechanical and independent of any components, mechanical or electronic so it was weird what caused it to be stuck. The dealer could never replicate the problem and it happened only twice or three times over the 4 years I had the car. After that incident in a way I believe that sometimes mechanical parts like brake pedals could "freeze up". :confuse:
Anyways after I turned the car off and restarted it, no lights came on and everything worked fine. :confuse:
According to the video clip, he tried that.
No dice.
Throttle wide open, can't shift into neutral, can't turn off the ignition, can't engage any brakes, but somehow the steering works just fine.
And the driver's cellphone works, too...
I was too, until finding out he flipped the car 5 times. Not even a teenager would be so dumb to risk their lives over a lousy couple hundred grand.
Also, why drive an hour? Better to dial 911, get a couple witnesses, then jam the car against the concrete divider and cry whiplash.
Yet, teens get out and risk their lives every day doing stupid stuff in cars for NO money.
I seriously doubt the driver had plans to crash his car, but then again, how many kids that crash racing other kids set out with the idea of crashing?
IMO, the crash at the end was simply the culmination of the odds of a crash finally adding up and outweighing the luck the driver had enjoyed for the previous hour or so.
Like this one:
kid is obviously brand new driver. At 16, is he even supposed to be out there alone? Anyway, speeds past cop, knows he is screwed, so let's try this trick! then it just gets out of hand. He can't figure out a way out of it and just keeps going, maybe figuring he'd run it out of gas as his way out. Unfortunately, his lack of skill catches up with him before that happens.
Even the most skilled drivers could slip up and out of instinct slam on the brakes when approaching a hazard or slow moving vehicles in which case the vehicle would slow to half the speed it's going before the driver would "remember" that they're pretending their brakes don't work.
What do you think about companies that don't clearly label their products, oil or otherwise? This one is clearly labeled correctly. Why are they the exception?
Bigger question, why survey my opinion about the potential risks before you as a consumer ask that question of the companies that are using confusing statements in their advertising?
With Smart Key the operator has to push and hold the start button, and the vehicle will shut down. If it had a normal key, turning the key would directly open the power circuits to the PCM, BCM, and the smart junction box.
The brake lights, which you never see come on during the video, are directly controlled by the pedal switch and a relay. I could look at the circuit a little more for cross references but with the smart key system the car would not start if there was a brake lamp circuit issue. Keep in mind, there is always room for something to change after the vehicle was started.
If the throttle was genuinely stuck open, there would be no manifold vacuum to assist in the brake application. It would take both feet, but the manual operation of the brakes would still over power the drive train and from 110 mph, you can stop the car in about double the normal distance as you would without the engine pulling. Car and Driver (and others) have done some tests on this and there are also some you-tube videos of techs demonstrating various scenarios. They always stop the car, even with the throttle wide open.
On some cars today, the shift lever is really just an input to a computer, but that is not the case with this Elantra. It uses a shift cable and has a manual valve and park pawl in the transmission just like we have used for decades.
Sorry for the kid, but I'm not buying any of it.
PS almost forgot.
A kiss off of the median, or even one of the cops positioning to let him rear end the squad car would both set off the airbag system, and that results in a complete system shutdown as well.
There was one product on the shelf, I'll leave the name out for now that was clearly overdosed on ZDP, and it didn't even have the ILSAC donut on the bottle. That product used in a car experiencing above average consumption issues would easily contaminate the O2 sensors and catalysts. A similar product just down the shelf (Royal Purple) correctly identified itself as not for use in any vehicles after 2004, yet the first one did not.
There is more to it than just "engine damage". Now answer my questions.
How do you feel about companies that use misleading statements in their advertising, whether it's an oil company or not?
Now another question.
Are you in favor of helping consumers understand the oil manufacturers labels and oil specifications, or would you like to keep consumers uninformed?
From there, who does it serve to try and cast any doubts as to a consumers need to learn about and understand engine oil specifications?
I recall reading somewhere that the new "smart keys" will soon respond to multiple jabs of the button. Might have just been one automaker or maybe it's under consideration by the NHTSA.
Back to 99
bottles of beervarieties of oil on the wall. :shades:(More like 999 - just counted 36 different kinds/weights of oil at Pennzoil, and that was just for the US market).
True. But 911 nor the cops would risk the liability. The kid spins out and crashes, is injured, now he's suing the city, the cops, and the car manufacturer.
I came to the same conclusion.
Actually, THEY aren't much in favor of learning it and I'm not keen on trying to shove it down their throats. I know when to quit. :P
Just curious... Why not use the correct spec oil 100% of the time?
Chances are, it isn't significantly more expensive that an alternative oil that doesn't meet the manufacturer's specs.
Assuming the lubrication specifications aren't encrypted in some form of impossible to understand code, or that the correct oil can't be located in the tri-state area... Why would you knowingly use a below-par lubricant?
Even the cheapest cars aren't that cheap. So, if one puts 100K miles on a car, and changes the oil every 5K miles, we're talking about 20 oil change intervals. If the correct oil costs $2 more/qt, and the crankcase holds 5 quarts, that's a whopping $200 extra over the 100K mile life.... Or $400 over a 200K mile lifespan. Not that much coin at all...
IMO, if money is that tight for the owner, I can only imagine the condition of the tires on the car after 50 K miles.
Makes no sense to me...
That's been my point all along. You simply can't make the average car owner get interested in the minutia of what it takes to keep his car running at peak efficiency, unless the interest is already there.
There's always a significant number of people that will spend $50+ large on a luxury vehicle that calls for hi-test gas and yet only run 89 octane in it.
The same goes for service. Penny wise and pound foolish...
In some cases, the products that actually meet the manufacturers specs are less expensive than ones that do not.
I can't expect those to seem important to everyone, nor can I bother myself with minutiae about oils. If my engine blows up it's probably not going to be an oil-related issue, it's going to be a detonation issue, since I'm running higher than normal boost.
Your also assuming that they know how to choose the correct oil. Plus your assuming that the competition to try and have a low price isn't resulting in poor choices being made.
I called back after seeing They said it was a computer error. Difficult to believe
The computer didn't put the oil in the car, and it only generated the repair order based on what someone entered into it.
So, if I'm doing my own oil changes,I'd go ahead and get the correct spec, now that I know what to look for.
Have you noticed any pressure to try and make that confusing for you here?
But, for the average Joe blow car, doesn't seem likeitwould matter much ...to the extent of asking every oil change if they are using correct spec oil.
It does matter, a lot! There are groups who have an interest in allowing the consumers to not understand the need to learn how the specs have changed.
Did you then wonder, why does one company have that many different products? Words like "equivelant" get to take on a whole new meaning when you can grab four bottles of 5W30 off of one shelf and find out they aren't equivelants. Then when you know what to look for, you find out that that store, with four different 5W30's still might not have the one your car calls for. That doesn't mean that a given company doesn't make it, it means there isn't enough correct information out there yet.
I didn't even mention during our trip I found one store only had type F transmission fluid on the shelf, and several others only had bottles of "Dex/Merc" which quoted the expired dexron III spec.
So then you support the misleading statements used in advertising that can result in a consumer, shop, or technician using the wrong product in somone's car?
That's not what I see him saying at all.
There are multiple factors in play, one of which is a gross lack of understanding/ignorance by the general population regarding lubricant quality needs and requirements, and another is the confusing way lubricants are labeled, if for no other reason of having multiple standards, both industry-wide and those set by individual manufacturer.
If an engine seized immediately after having the incorrect oil installed, owners would stand up and take notice. Since that rarely, if ever, happens, owners don't see the correlations between incorrect oil and the use of said oil in their car, especially when it can take 50, 75, 100K miles or more before any direct correlation can be identified. Even then, when a correlation CAN be identified, the damage is usually blamed on something else, so the consumer still doesn't get the "education" he needs.
Simply put, some folks care, but most don't.
I'm not sure how to change that perception, or even IF it can be changed.
Then why doesn't he answer the question, yes or no?
I have no intention of becoming the Billy Graham of motor oils--I'd rather just sit like the Buddha and let everyone figure it out for themselves.
My only responsibility is to try, to the best of my ability, to convey manufacturer's specs to consumers. If GM can't get it right, then it's out of my hands.
How does the suggestion that you could get away with using the wrong product no matter what the cause was support this?
Why does this have to specify GM, when the issue is also a concern with BMW, Mercedes, VW, Ford, Chrysler, some Nissans, new Hyundai's, etc.etc?
As for me dumping any old oil in my car, that's my business. I have no intention of inflicting my habits on the consumer.
I'm not a missionary--I don't have to always practice what I preach :P
One might say, with I hope some modesty, that I have the knowledge to know when to push limits and when to obey them---and I don't think every consumer has that knowledge---so I am very careful to be as "right" as I can with them.
On the other hand, I don't want the consumer to waste money heedlessly.
If I can save them money by pushing them to have codes read rather than guess, by steering them away from "scams", and by conveying accurate information from trusted databases, then I feel okay about what I'm doing.
But I'm not going to advise them on how to re-wire their car via my Internet instructions. I'm not crazy. :shades:
a) either MAKE manufacturers authorize whatever form of nationally recognized min spec you want (pick one) to be used in all their engines past and future, (future ones governed by a new year spec of course) SN, SP, SQ, SR or whatever..like I said, designation chosen as nationally recognized,
.........................OR............................
b) owners damn well buy their oil from their home brand if they do their own oil changes, keep their receipts or forfeit future claims..as simple as that... or have their home brand service shop DO ALL their oil changes!
Pick one..
This confusion stems from NON licensed oil brands, wanting a piece of the pie, WITHOUT manufacturer's ble$$ing$. Why are we catering to them, if the consequences of using the wrong oil (regardless of who is to blame for labeling/interpretation/there's-that-can-o-worms again omitted/solved) are that serious, then why are we bowing down to allow such free-enterprise WHEN IF SOMETHING GOES WRONG, EVERYONE WANTS THE OTHER TO TAKE THE HIT!?
So...a or b....pick one, no negotiation..."is that a 'but' I hear back there from the cheap seats?!" But NOTHING!
Pick one.....
:shades:
Part of the confusion stems from old habits that didn't immeadiately result in an obvious failure, and now people still want to carry on with those old habits when the cars are different. The worst part of all of this is the people who try to pooh-pooh someone when they do try and alert the consumers. When I first attended the oil class I was just as amazed as everyone else at how things had changed and at the same time felt betrayed that the suppliers that I was trusting to give me the products that I needed to take care of my customers didn't do their part and make sure that I knew about the changes. I followed that up with hours and hours of additional study and confirmed everything that Kevin M was explaining to us.
Since adapting to the changes, I have had to deal with all kinds if suggestions that the reasons we were doing this different from everyone else were everything and anything except for the simple fact that we learned that we used to be doing it wrong, and now we are up to speed for our customers and their vehicles. When you read all the way back through this, you will see that same kind of pressure that continually suggested that following the manufacturers specs isn't necessary and that goes all the way back to some specific lines in Ron's article.
As Kevin say's, and I quote him here. Everyone goes through Denial (This can't be true) to Anger (Why didn't those SOB's tell us) Negotiation (Can't we just get a list of what oils to use in what cars) to finally Acceptance that its different today, and we will just have to work a little harder to ensure that we are taking care of our customers cars correctly.
There are times that I like to refer back to the title of this thread, "A Mechanics Life". This little war that went on here on this one "simple" (not) subject is a real reflection of just what it has been like trying to keep up with the changes in the cars for our customers, and getting them and the IMO self pro-claimed experts to realize what doing the job correctly really looks like today.
When the toy tools get someone's blessing it suggests to the consumer that they are seeing how we do our jobs, and that can't be further from the truth. They will try to prove their perception by touting only the lowest denominator but that isn't even close to our world. Our world today is easier seen with the purchase of a tool like Chrysler's WiTech, at some $7000. Someone who buys a parts store code puller can at best do about 20% of what the car is really capable of which can only be truly seen with the WiTech. The problem is, at $7000 we don't own the tool. We only own the license to use it for a year, and then if we don't pay another $1700 by it's "birthday" it turns off. Now repeat that for every manufacturer that a shop tries to support today and you have made a big step towards understanding a little more about what it takes to be a full mechanic today.
I first came to this site because of Mr. Reeds involvement in that sting with NBC. The second part that they aired of course praised a shop who didn't charge for the time spent diagnosing the car. That sends as incorrect of a message to the consumers as much as anything else did in regards to that "story". The perspective that they wanted to push on the TV, as well as the ones you saw here that did everything they could to discredit the need to really follow the manufactures specs are based entirely on a lack of up to date training and current experience. Fortunately that can be addressed, but not until people realize that they need to get up to speed with what it really takes to fix cars today.
I hear what you're saying. And I have followed this oil debate, I think, from the beginning. More as a lurker in the beginning though. And there is a pattern with the content in your posts. And to address just this part of your quote above..
To me, your points are made, they seem consistent for the most part and much is repeated, and I appreciate what you are saying, but there is a but. I still maintain that there are only two viable options (if a true solution is the goal)..and really..when you get right down to it, it is the manufacturers that should be left holding the bag. They CHOOSE to build an engine requiring a certain spec of oil. It is not the other way around. If a mfrgr wants to be different and veer off from a set standard, that is on them! So basically if you, as a consumer, decide to buy brand A, then you damn well use ONLY the oil that brand A SELLS. Not what they say meets there ever-changing specs..LET THEM BE ON THE HOOK FOR MISLABELING OF THE OILS, OWNER'S MANUALS ETC. RIGHT? Isn't that obvious? And in doing this, IT IS ON THEM, who they trust to supply them with the right oil, 100% of time. And if someone screws up, the mfgr PAYS. 100% of the time.
Once you are out of wty, that is when the consumer will determine by voting with their $ which non-licensed oil brand gets to sell product.
Since there is so much confusion in the industry and since mfrgs can NOW TELL if you have used the wrong oil, it is just so obvious that a smart consumer will continue to buy their oil from their brand mfrgr and that way, if you do have a failure just outside of wty or if it becomes known that a certain build date on a certain engine was found to have faulty components that failed almost always outside of wty, but it was easily determined to be a fault due to the numbers involved, that brand is more likely to go to bat and cover the repair.
Again, why cater to ANY brand of oil that doesn't measure up? Let the mfrgr decide which oil brand gets to sell oil, not the consumer. Put it ON the mfrgr.
Neysayers will say that sounds too idealistic. I say it is doable...unless there is something right under my nose that I can't see that says it isn't.
edit: perhaps monopolization abuse..that one occurs to me.
Oil doesn't really "wear out" does it? The additive packs do. Just start doing like transmissions and seal the system up. Use an access port to refresh the additives every 15 or 30k or to top up the level. Change the filter at similar intervals.
What happens to the waste oil now? It either gets burned in the shop or sold to a recycler. And some of those recyclers take the waste oil and turn it back into base stock (link). May as well figure out how to take that step out of the process.
Yes, it does. The idea that it doesn't is a myth. Engine oil gets damaged by crankcase acids, the moment it's acid fighting properties are depleted. Plus as I explained in one response GM and Ford can both prove that with the reduced bearing clearances, too thick of an oil will have the molecules of the oil torn apart by the shearing forces in the bearings. You'll remember that' some wanted to make fun of that statement, without checking into the facts first.
We can do this two ways. I can repeat this whole exercise with transmission fluid, and even engine coolants exactly as I have with the engine oil, or you can choose to accept the fact that a lot of the ideas that you hold dear are no longer valid. :surprise:
If they get approved for use by the auto manufacturers, then what a great way to save resources. If not then they might just as well be used for heating the shop.
I think we're going about it the wrong way
I don't agree, the other way left everyone thinking that they knew all that they needed to, and that includes Ron's article. The thing you have to realize is there is still way more to this subject than just what you see here, and its still changing and will continue to in the future.
In a perfect world that might be true. In this one any shop who has failed to keep pace with the changes will easily be the ones holding the bag if a customer experiences a failure that isn't covered by the manufacturers warranty. We are in a position of superior knowledge, we are supposed to know what car takes what oil, regardless of how many people try and say differently.
If you really want a one size fit's all, then why doesn't everybody drive a Mustang GT in the summer, and an Escape in the winter exactly like we do and the problem would be solved as well. The simple reality is everyone doesn't want to drive the same cars, and to meet the power and fuel economy, and emissions demands of the governement, as well as the consumers the technology in the cars is driving the changes in lubrication demands.
BTW SAE is mandating a change and another catagory of oils, SAE16 A and SAE16 B to try and accomplish some of what you want. But they are about five years behind with that right now, or said another way they should have done that five years ago, and upgraded it from there to meet today's needs.
This is where the FTC and people who spout the Magnuson-Moss act contribute to the confusion. The manufactuers are not allowed to force you to buy their oil, even when it is in their, and your best interest. All they can do is require to use a product that meets their specs. from there you need to know how to recognize what does (and is truly equivelant) and what does not. You do not have to use VW's oil in a VW, but you do have to choose an oil that meets VW's specifications.
Does GM's move to have licensed approval for dexos make sense now? It isn't and was never about the money. It was all about making it absolutely clear for a customer how to choose the correct product for their car. Anything else you have ever seen about this has been a total misdirection at play.
So you remain objective, how?
YMMV.
:P
Most want to open their owner's manual (presuming they still have it) and turn to page 84, and point to that and tell the repair shop that this is what they want---or they presume that the shop is on page 84 without them asking.
Get rid of annual oil changes, switch to electromagnetic brakes (no pads) and let me go in once every four years. I'll upgrade the oil while I get the tires recapped. :shades:
What does a roller bearing extreme pressure lubricant test have to do with engine oils?
http://www.falex.com/pdf/FalexFourBallEP.pdf
Speaking of re-caps, during our trip to Memphis this week I saw two different cars lose a tread and watched them roll down the road seperate from the car. At first I thought it was a wheel-off, but these were just bad tires. We never see recaps around here anymore, at least not on cars.
We have to confront a 40' long shelf of various oils with various claims and a bunch of different "approved" specifications and labels and competing standards or trust that our mechanic is putting oil in the car that won't somehow void the drivetrain warranty.
I think the legal liabilities put the Ke-bash on passenger car retreads for the most part, but it still seems to be a viable alternative in 18-wheeler setups. I just watched a show last week on "How It's Made" where they "remanufactured" big truck tires.
I can't remember the last time I've seen a passenger cars sized recap.
