2013 Cadillac ATS
13»
  • robr2robr2 BostonPosts: 8,857
    the epa esitmate has to come from testing of the cars they rated correct?
    The EPA test is based on a very strictly controlled testing cycle that nobody in the real world can achieve. The majority of the test is done at under 50 mph and only goes over 60 for about 4 minutes. The highway test averages about 49 mph.
    Drive at those speeds and you'll hit the EPA estimates right away.
    I can forgive a few mpg but 20% below the rated figure?? That is false advertising.
    It's not false advertising. The manufacturer is required by law to post the EPA numbers on the sticker. The manufacturer doesn't come up with them - the EPA does.
  • Just short of 6 months my 2.0, 4 cylinder ATS has posted a VERY disappointing 18.5 mpg on almost all suburban driving.
    Estimated MPG on this car is WAY OVERSTATED !!!!!!!!!!!!!!
  • kd1007kd1007 Posts: 23
    I ORDERED THE ATS TURBO FOR THE PERFORMANCE AND THE MPG BOTH HAVE DISAPPOINTED
    THE CAR HAS A TURBO LAG AND ISNT THAT FAST AND THE MPG IS HARDLY BETTER THAN MY 2005 CTS WITH A 275 HP 6 CYL.
    THE ATS WAS SUPPOSED TO BE MUCH LIGHTER TO GET BETTER MPG AND A 4 CYL WAS ALSO SUPPOSED TO GIVE YOU GOOD MPG
    IM GETTING 20 MPG AND THATS WITH ALOT OF HWY MILES
    I LIKE THE LOOKS AND HANDLING BUT THEY NEED TO KEEP WORKING ON THE ENGINE AND TRANSMISSION
    THE CAR HAS A TURBO LAG AND ISNT THAT FAST AND THE MPG IS HARDLY BETTER THAN MY 2005 CTS WITH A 275 HP 6 CYL. THE ATS WAS SUPPOSED TO BE MUCH LIGHTER TO GET MPG AND A 4 CYL WAS ALSO SUPPOSED TO GIVE YOU GOOD MPG IM GETTING 20 AND THATS WITH ALOT OF HWY MILES
    AND PASS REAR THRU SEATS SINCE TRUNK IS SOO SMALL
  • jeffm5jeffm5 Posts: 123
    I'd be disappointed in those numbers too. I also bought my 2013 Volvo T5 for power, luxury and because of the EPA numbers, which have been right on from the beginning. In fact, I consistently do better on the hwy. I get 30+ going around 70MPH on regular gas.
    I love the looks of the ATS, but to buy one with the options I wanted just wasn't in the budget.
    DEAR CADILLAC
    IM WAITING FOR MY REFUND $ CHECK SINCE YOU WAY OVERSTATED THE MPG ON MY ATS TURBO
    TIME TO PAY UP LIKE FORD DID TODAY
    Ford will cut the C-Max hybrid's fuel economy rating to 43 miles per gallon in combined city and highway driving from 47 mpg. The company said it also will send refund checks for $550 to customers who bought a C-Max. Customers who leased the car will get refunds of $325.
  • The EPA does testing to determine the MPG figures, they don't just estimate basd on the car. True it's not real world driving. We can wonder if cars submitted are driven 5,000 miles first, but I bet they make sure that car is running perfectly.
    To see about what your car can do for MPG Highway, drive on a Flat road, at 60 mph, using cruise control, with proper tire inflation, then look at the Instant MPG number. Using any type of combined MPG is confusing.
    I still have a 2007 CTS 3.6 V6, that gets 25 MPG with that test, which is close to it's EPA. I don't remember having to break it in for 5,000 miles to do that.
    I am posting here because I have been looking at the ATS and this is my first forum reading about ATS. I remember that in the CTS forum, there were always a few posting about poor MPG, but that doesn't mean it's every ATS. If you are buying off the lot, do a test drive like I recommended and see if that car, or any of the cars you test drive, gets close to the EPA. Buy the car that is close enough to EPA for you.
  • Seats: As you move up from base to Lux, to Perf, more movements are added. The padding seems to be the same on each.
    Headlights: Need Perf or Prem for HID and the signature lights.
    CD Player: Need Perf or Prem or 10 speaker sound added to Base/Lux.
    Magnetic Ride, FE3 Suspension, Summer Tires: Premium And RWD.
    The Prem AWD does not have Mag Ride.
    Trunk: Most cars this size have larger trunks. Golf clubs (1 set) does now fit straight across from taillight to taillight.
  • ls8ls8 Posts: 16
    Took delivery on mine a little over a week ago. Opened it up on some mountain roads and it is scary fast and handles extemely well. Coming back home at normal highway speeds i got 32 mpg on the 50 mile trip. Around town got low 20's in first week. CUE took a couple of days to get used to but love it now and it makes the whole interior of my previous 528 look ancient. Absolute blast to drive.
  • newatsnewats Posts: 2
    edited October 2013
    Wondering what to put on my ATS for this winter. Live in The Northeast and will travel South for one or two months this winter.
    Turbo, AWD. Driven by a grandmother. Love the turbo!
    I am assuming the stock tires are a "no go".
  • jpfjpf Posts: 496
    I assume you have alloy wheels. I suggest 4 steel rims and 4 snow tires (e.g. Blizzak). Good luck.
    May I suggest some Nokian WRG2 or WRG3 on some dedicated rims.
    They are an all season snow tire and should be able to deal with the warmer weather for the time down south.
  • eliaselias Posts: 2,110
    Enjoy that caddy, KD. And expect 10% better mpg after the engine breaks-in.
    Some cars power the cig lighter when ignition is off.
    Others not. (Oh, the humanity.)
    ps - A good way to save the planet and conserve power is to avoid the caps-lock key and all those capital letters since they use way more power than lower-case due to all the extra pixels.
  • blackatsblackats Posts: 2
    edited December 2013
    Just bought a 2013 ATS 2.0T AWD about a month ago! What a phenomenal car!!!! The engine and chassis are a blast, very willing, smooth and energetic. The car begs to be pressed hard, it's difficult to drive slowly :).
    I have the 18" rims with 40 series tires, handles fine in the snow (don't forget to change it to the snow setting).
    I don't understand the complaints on CUE, works very easily, all you have to know is that the metal "guide bar" is a guide bar and not the actual button, you need to press the black area above the guide bar with the PAD of your finger, not the tip. Works 100% every time when used properly. The voice activated controls work very easily as well & pairing to my iPhone was simple (vs. the multistep process in my wife's new Jeep Grand Cherokee).
    As others have noted the back seat and trunk are small, but it's a small car, so it's to be expected.
    Gas mileage falls short of the 20/30, but I've read in several places that after the first oil change things should improve.
    Radio reception is fine in my car, not sure what the complaints are about on this forum, of course it could just be that guy that keeps whining via threatening class action lawsuits and writing in caps....
    This is NOT the old, cushy Cadillac of 20 years ago. It is a drivers car, so if you are looking for a soft, cushy ride you need to look elsewhere.
    Awesome car all around, I look forward to any chance to drive it!!!!!
    And nice touch GM with the 110 years of Cadillac history book, it was unexpected!!!!!
  • knackllknackll Posts: 15
    edited January 2014
    I couldn't agree more with Blackats, I just got my ATS Premium 3.6 AWD Black Raven and what a car it is! This vehicle is quick! I too don't see the issues with the CUE. I get in the vehicle and my phone pairs & functions flawlessly. This is a very exciting car to drive. The ride is awesome! The AWD works perfectly. If I had any complaints (which I don't) it would be about the lack of an option for cooled seats. Other than that, I struggle to find a better car out there for me. I also was surprised to receive my history book. Very Nice!
    Proud to be a Cadillac owner!
  • amiicamiic Posts: 1
    Greetings,
    I currently have the 2013 ATS 2.0T. I have been dealing with the dealers and GM for the past year with an issue that I should not be experiencing with a new car and have some more information that I would like to share and if possible get some feed back.
    When the car is at a stop and no matter what the transmission is in, it be park, Drive, manual, it has a ruff idle. I could only explain this as being on some sort of a roller coaster or feeling like your in a truck which I would expect. It bucks and sways as if it feels its going to die and before the first update it did while I was driving and second time at a light.
    I have been to 2 dealers with this issue and have had 2 updates, mounts replaced and who knows what else they have done with no luck. they also were kind enough to give me a fuel cleaner additive but really, need this on a new car? I only buy gas from know names such as Shell, Chevron and mobile to no avail thinking it might be because of that.
    It appears that they want to do a sensor test or some kind of diagnostic on the car where I have to press a button every time it happens but have explained that the issue is always happening at idle.
    I have had multiple people sit in the car as well and they have noticed it as well.
    Now after all the loaners, it is an issue only with the 2.0T. The 3 and any other Cadillac does not have this issue. I also received a 2014 2.0T that had it but it was very faint. guess because it only had 300 or so miles on it.
    This is besides all the rest of the minor issues experiencing suck as double vision displays, power steering going out, Radio turns off and back on by itself and just the other day almost did not start.
    Chase from Edmunds has been a big help in contacting Jason K. who did the extended road test and noticed it as well.
    At this point I think GM thinks I just want out of the car. This could be further from the truth. I made a decision to get an American car. I was planning on buying the car for my mother to enjoy and picking up another Cadillac for myself.
    To add to that they have made me feel like I am at fault. This has definitely made me reconsider my next purchase. I know to many people that ask me recommendations for cars and wish I had better news for them.
    So for those that have the 2.0T, let me know if you have an idle issue.
    M
  • jvfjvf Posts: 1
    Is anyone having engine problems? I got a 2013 ats less than a week ago the check engine light came on and it started smoking I called on star they said to get it to a dealership ASAP i only have 600 miles on this car..this incident is going to appear on my car fax which is not good..I don't want this car..does anyone know if there is something I can do to get a new car? I've read other blogs ppl saying the same problem with engine resulting engine being rebuilt :/ this is my 3rd Cadillac only one has been a great vehicle I'm starting to rethink my next purchase not happy :(
  • Over 3,000 trouble free miles on my 2.0T, smooth idle, no smoking, just a pleasure to own. Sorry to hear you are having issue jvf and amiic. It's such a great car, give Cadillac a chance to fix them. All cars have issues, I know many people BMW's with cracked engine blocks, Toyota's needing complete engine rebuilds due to sludge buildups that Toyota refuses to acknowledge, etc.
  • trellsworthtrellsworth Posts: 24
    edited April 2014
    I just bought the 2013 Cadillac ats, when the door is open the mileage reads 14,112 and when the door is closed the mileage reads 28,221 Anyone else having same thing happen? Wondering if that means anything.
  • cdnpinheadcdnpinhead Forest Lakes, AZPosts: 3,674
    edited April 2014
    It means that two months have passed since the last post on this board, and that your electronics are, well, messed up.
    If you think dozens of people with ATSs are carefully monitoring this board every day, you may want to reconsider.
  • gmcustsvcgmcustsvc Posts: 4,246
    Hi trellsworth,
    It sounds like quite a dilemma! Have you consulted with your dealership service advisor? Please let me know if you need assistance. Thanks.
    Kenneth M.
    GM Customer Care
  • Have 7000 miles on mine. Rear seals went somewhere during 8 hours of driving around 5000 miles.Replaced by dealer, leaked again at 6000. CTS has same problems. It's shame that I can buy a BMW, Toyota and beat the heck of it and an american luxury performance has a problem in thousands of miles that never show up after hundreds of thousands of miles in other cars. CUE is truly terrible but overall ( I don't know how that much engineering could go into something so bad), assuming the rear doesn't go out on me, the car was a bargain for what they give you. Handling is better than other cars at $20k more (although none of them approach the balance and handling of my old 335i when they still had hydraulic assist and sport tuning) leather is great, little hidden compartment behind the radio is cool. Trunk is terribly small but it's a sports car. Mileage is not great but I get 23-24 mixed according to the computer and i drive it very hard.
    edited May 2015
    You, along with the history of this board, are monuments to the notion that the many posters are people with "issues." Until yours, there wasn't a post on this board for over a year. It's not as if a multitude of happy people are letting us know how wonderful the ATS is, all exchanging happy anecdotes. This board is deader than Elvis, like many of the Edmunds boards. Or, maybe it's the car. Either way, you're probably talking to a vacuum.
    Welcome.
13»
2013 Cadillac ATS - Page 3 - Car Forums at Edmunds.com
