Valve cover gasket?
Hi all, Im new here but i have a question. I own a 1993 Subaru Impreza L sedan. I was recently changing the timing belt and noticed my driver side valve cover has oil and gunk all over it. I feel that the cause is that the valve cover gasket has kicked the bucket but could it be anything different?
thanks!
This is beyond my expertise but I wonder if some of that sealant goo specifically meant for gaskets would help in this case?
thank you
I hope you don't have to redo it, but best of luck to you as you sort it out. It sounds like you made good on your first attempt.
